E46 Convertible
Old 06-26-2013, 07:00 AM   #1
mag48
My Ride: 330ic
Anyone Tried Converting to Manual the Roof to Windshield Latches?
$800 vs $280. If anyone has a manual roof. .. how does the roof to windshield latching work?
mag48 is offline   Reply With Quote
Old 06-26-2013, 07:59 AM   #2
R1200RT
My Ride: 2004 330CIC
They are manual on the removable hardtops. You press a button and the closing lever pops out. The lever is then moved to unlatch or latch the roof.
Nick
'04 330CIC, 3 pedals, M Sports\Aerodynamics Packages
'05 BMW R1200RT
'00 BMW R1100S
'04 BMW R1200C Montauk
'95 BMW R100R Classic
R1200RT is offline   Reply With Quote
Old 06-28-2013, 10:00 PM   #3
JFH325CIS
My Ride: 2002 BMW 330CIC
That I have an power convertible top, and I have a vague idea of what you're referring to, but more clearly, what is the reason for converting roof latches to windshield latches?
JFH325CIS is offline   Reply With Quote
Old 06-30-2013, 01:50 PM   #4
cityjohn
My Ride: 2001 M3
I think the reason would be that the motorized latches are expensive and can break; the manual latch found on semi-automatic tops is cheaper and more reliable.
cityjohn is offline   Reply With Quote
Old 07-07-2013, 11:23 PM   #5
c stockwell
My Ride: 2002 330ci
can anyone tell me how to open my vert top when only the right side unlatches from the windsheild the driver side does nothing.
also iv tried to open it manualy with no results...sounds like something is broken and not allowing the driver side latch to open...any help would be great.my ride is a 2002 330ci
c stockwell is offline   Reply With Quote
Old 07-14-2013, 05:49 PM   #6
mag48
My Ride: 330ic
Broken Latch
You have same problem!!! Broken latch ...know problem plastic parts break.
Old 07-14-2013, 06:19 PM   #7
taylor192
My Ride: 2003.5 M3
Re: Anyone Tried Converting to Manual the Roof to Windshield Latches?
The only way is to cut the plastic cover.
Sent from my Nexus 7 using BimmerApp mobile app
Old 07-14-2013, 06:54 PM   #8
wildirish317
My Ride: 2004 325Ci vert
I have a completely manual top. The windshield latching is done by a handle as shown below: (The handle is item 12. BTW, I've never had any issues with the top.)
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.”
Originally Posted by Mike Miller
I just don't know what I'd do with 560 hp that doesn't involve getting arrested.
wildirish317 is offline   Reply With Quote
