E46 Convertible
Old 06-24-2013, 10:44 PM   #1
jeton_g
My Ride: 2003 e46 m3
Cracked subframe ( Horrible)
Hello everyone, Im a new user here, bought a 2003 m3 a few months ago.
Found out the subframe is cracked like crazy, I have a few pics of it now, saw it better from the trunk today, but wasn't able to take pics...I've received some very helpful advice using this forum thought i'de like to share my pics and story...also more pics will be posted of the work done once is completely re-welded and complete. Should be another couple days considering he had to remove the entire back end in order to weld, since the gas lines are running through there...need i say more...
ID:	512943   Click image for larger version
ID:	512944   Click image for larger version
ID:	512945   Click image for larger version
jeton_g is offline   Reply With Quote
Old 06-24-2013, 11:01 PM   #2
Scooby24
My Ride: '03 330i ZHP Sedan
dude...that's like...a total loss.
Scooby24 is offline   Reply With Quote
Old 06-24-2013, 11:03 PM   #3
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
Bad but fixable.
I'd shop it around for the best price,.........but expect to PAY.
Good luck.
SUMMIT POINT WV 1:24:229 SCCA
Old 06-24-2013, 11:04 PM   #4
jeton_g
Iv been driving around with it like this for several weeks, I have a good welder working on it, wasn't cheap but sure as hell was alot less then i thought.
Old 06-24-2013, 11:08 PM   #5
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
How much?
Old 06-24-2013, 11:09 PM   #6
jeton_g
Originally Posted by peytonracer4 View Post
how much?
1g
Old 06-24-2013, 11:57 PM   #7
sakumaxp
My Ride: 02 M3 convertible
That's horrible, bad luck I guess? Usually vert subframes don't crack
Carbon Black Metallic
SMG II
Verttttt
VCSL Front Bumper
VCSL 1 Piece Splitter
VIS GTR Hood
6K Angel Eyes
VMR VB3 19's
KW V2 coilovers
sakumaxp is offline   Reply With Quote
Old 06-25-2013, 12:34 AM   #8
mkodama
mkodama's Avatar
That looks much more like accident damage...
Old 07-04-2013, 11:04 PM   #9
jeton_g
With my stupidity I did not check any car history, but recently found out the 2nd last owner before me drifted it into a curb, that might have caused this...Right now Its still sitting at the shop, apparently they ordered a whole back end from another model and are going to replace the entire back end frame and reinforce, hoping it doesn't happen again...
Old 07-04-2013, 11:07 PM   #10
davidwarren
Halfway to 2L
davidwarren's Avatar
My Ride: 2010 335i
That's what I thought too.
You down with UCC? Ya you know me!
sowing the seeds of jiggery pokery
davidwarren is offline   Reply With Quote
Old 07-05-2013, 04:34 PM   #11
Lionelski
My Ride: 325CIc
Holy crack!
'Ski
www.WarrenvilleRailroad.com
2001 325ci Convertible - Titanium Silver
Sport Package, Premium Package
Racing Dynamics Strut Tower Brace
Conforti Shark Injector, Conforti CAI
Interior: Leather, Euro Tray, M3 Dead Pedal
Lionelski is offline   Reply With Quote
Old 07-05-2013, 05:33 PM   #12
My Ride: Lexus
For that to happen on both sides indicates it's probably not due to drifting into a curb. Of course that probably didn't help but this is a known mode of failure for subframe mounting areas on the E46, especially the M3 convertible. In fact, this extreme failure mode has only been seen on the M3 convertible to my knowledge. To say that verts aren't vulnerable to subframe mounting damage is ignorant.
I highly recommend any E46 owners, especially M3 convertible owners, to periodically check for popped spot welds in the wheel well area especially. Once one weld pops, the weld spots next to it tend to pop and it's a chain reaction after that. Then eventually that lower section separates from the unibody.
This is all documented
Old 07-06-2013, 12:28 PM   #13
Blueandwhite85
My Ride: E46
Correct me if I am wrong as I am sure all of you will - but didn't the convertible models receive an upgraded subframe over the coupe and sedan models? Especially the M3? Everyone I have ever talked to about these things has said that subframe failure in a convertible is much less likely to occur, considering the reinforcement they receive due to having a mechanical top and being less rigid.
Blueandwhite85 is offline   Reply With Quote
Old 07-06-2013, 12:41 PM   #14
jeton_g
Im not sure but that sounds like it should
Be right...although most of the forums i've
Read it has been majority verts with this issue
Old 07-06-2013, 01:02 PM   #15
taylor192
My Ride: 2003.5 M3
Re: Cracked subframe ( Horrible)
There is a poll M3F that shows 10% of verts have cracked sub crashes, vs a significantly higher % of coupes.
Likewise the poll thread has confirmed the vert sub frame is a different part number and is built stronger.
Sent from my Nexus 7 using BimmerApp mobile app
Old 07-06-2013, 02:10 PM   #16
jeton_g
I think they are pulling a subfrme from a coupe
To replace mine,.. Instead of stitch weld they will
Weld across entire frame.... Do you think the
Full weld will hold this one together in the vert
Old 07-06-2013, 02:30 PM   #17
Blueandwhite85
My Ride: E46
Might be questionable. Certainly have it reinforced as well.
Sent from my SAMSUNG-SGH-I337 using BimmerApp mobile app
Old 07-06-2013, 02:46 PM   #18
taylor192
My Ride: 2003.5 M3
I think that's a bad idea. The coupe sub frames crack at a significantly high rate, and the vert is heavier. I'd spend the extra to find a vert sub frame, have the reinforcement parts welded on, and epoxy the cavities too.
The sub frame usually cracks around the bolts. A "full" weld will prevent the damage you have, yet your damage is unusual, typical of accidents not wear and tear.
Might as well do it right, otherwise you'll be doing it twice.
Old 07-06-2013, 03:01 PM   #19
sakumaxp
The verts didn't get an "upgraded sub frame" but since there is no top, the chassis lost a lot of its rigidity. So to make up for it they added reinforcements to compensate for not having a top, hence the heavier weight for the verts which comes from the reinforcements.
SMG II
Verttttt
VCSL Front Bumper
VIS GTR Hood
6K Angel Eyes
VMR VB3 19's
KW V2 coilovers
Old 07-06-2013, 04:02 PM   #20
taylor192
My Ride: 2003.5 M3
Let's not mix words.
- The actual sub frame (that the diff mounts to) is the same for coupe and vert.
- The body structure with the 4 mounts for the sub frame are different for the coupe and vert. This has been confirmed. This is what cracks around the 4 mounts. This is what the OP is replacing.
