E46 Convertible
Old 07-06-2013, 05:06 PM   #21
Blueandwhite85
My Ride: E46
Originally Posted by sakumaxp View Post
The verts didn't get an "upgraded sub frame" but since there is no top, the chassis lost a lot of its rigidity. So to make up for it they added reinforcements to compensate for not having a top, hence the heavier weight for the verts which comes from the reinforcements.
Sounds like an "upgrade" to me.
Go home.
Blueandwhite85 is offline   Reply With Quote
Old 07-06-2013, 08:47 PM   #22
sakumaxp
My Ride: 02 M3 convertible
Cracked subframe ( Horrible)
Go home.
The sub frame itself is still the same
Go home, youre drunk.
Carbon Black Metallic
SMG II
Verttttt
VCSL Front Bumper
VCSL 1 Piece Splitter
VIS GTR Hood
6K Angel Eyes
VMR VB3 19's
KW V2 coilovers
sakumaxp is offline   Reply With Quote
Old 07-06-2013, 09:04 PM   #23
Snik
Snik's Avatar
My Ride: IR M3 Vert.
That's not a rear subframe failure. That's a rear floor completely fell the fvck out. Even the worse rear end failures I've seen don't look like that.
I'm with this other. The accident def caused that.
Do you ride a sportbike?
Snik is online now   Reply With Quote
Old 07-06-2013, 09:13 PM   #24
taylor192
My Ride: 2003.5 M3
Re: Cracked subframe ( Horrible)
Stop trying to pretend to be smart, you're not helping and only making yourself look bad.
Members have adopted the term "sub frame" to mean the mounts in sheet metal that crack, not the metal frame that supports the diff. When people say "check the sub frame" they don't mean check the metal frame that supports the diff, they mean check the sheet metal around the mounts for the sub frame. It may be incorrect to say, yet we all know what is meant, so give it up.
Sent from my Nexus 7 using BimmerApp mobile app
Old 07-06-2013, 09:20 PM   #25
Snik
Snik's Avatar
Well if you wanna get technical. It's a diff carrier that is mounted to the rear floor.
Not a subframe. Technically. There is no subframe.
Old 07-06-2013, 09:22 PM   #26
jeton_g
My Ride: 2003 e46 m3
Wink
I think its just easier to say subframe rather than
Subframe unibody floor pan...etc... But u know what
We mean
jeton_g is offline   Reply With Quote
Old 07-06-2013, 10:50 PM   #27
taylor192
My Ride: 2003.5 M3
Old 07-06-2013, 11:23 PM   #28
Brevik
My Ride: Tiag M3
Holy **** that is tore up. Please post progress photos.
Brevik is offline   Reply With Quote
Old 07-06-2013, 11:53 PM   #29
mkodama
mkodama's Avatar
Originally Posted by taylor192 View Post
Let's not mix words.
- The actual sub frame (that the diff mounts to) is the same for coupe and vert.
- The body structure with the 4 mounts for the sub frame are different for the coupe and vert. This has been confirmed. This is what cracks around the 4 mounts. This is what the OP is replacing.
The frame sheet metal that the subframe mounts to are the same on all E46 aside from the compact. Look up part no. 41117000246
Old 07-07-2013, 03:41 AM   #30
taylor192
My Ride: 2003.5 M3
That's the superseded part number used in the 06 coupes and verts, as that was the year the coupe got the reinforced vert floor. The previous part numbers were different for the coupe and vert.
Thanks for coming out. This is all documented on M3F.
Old 07-07-2013, 04:33 AM   #31
mkodama
mkodama's Avatar
link?
Old 07-07-2013, 04:51 AM   #32
TerraPhantm
My Ride: M3 & ZHP
link?
Only way to confirm would be to check old versions of the ETK. I think I have a copy from 2004 somewhere... I guess I could install that and see
Old 07-07-2013, 09:51 PM   #33
sakumaxp
Ok? Thanks for joining in? I'll give it up when you prove my statement incorrect.
Go home, you're drunk.
SMG II
Verttttt
VCSL Front Bumper
VIS GTR Hood
6K Angel Eyes
VMR VB3 19's
KW V2 coilovers
Old 07-08-2013, 12:24 AM   #34
taylor192
My Ride: 2003.5 M3
Hope you never need help with the convertible top. Being an ass is a sure way to not get the help you need.
Old 07-08-2013, 12:57 AM   #35
sakumaxp
you came off a little harsh, by telling me "stop acting smart and im making myself look bad" you should reevaluate yourself first before you start calling people names.
SMG II
Verttttt
VCSL Front Bumper
VIS GTR Hood
6K Angel Eyes
VMR VB3 19's
KW V2 coilovers
Old 07-08-2013, 01:17 AM   #36
morningisbad
My Ride: E46 M3 Vert
Originally Posted by Mango View Post
For that to happen on both sides indicates it's probably not due to drifting into a curb. Of course that probably didn't help but this is a known mode of failure for subframe mounting areas on the E46, especially the M3 convertible. In fact, this extreme failure mode has only been seen on the M3 convertible to my knowledge. To say that verts aren't vulnerable to subframe mounting damage is ignorant.
I highly recommend any E46 owners, especially M3 convertible owners, to periodically check for popped spot welds in the wheel well area especially. Once one weld pops, the weld spots next to it tend to pop and it's a chain reaction after that. Then eventually that lower section separates from the unibody.
Is there a good way to check the subframe without lifting the car? I've got an M3 vert, and I was under the impression that subframe issues are much more rare because of the added rigidity.
"When makin' a questionable decision, sometimes the only way to find the answer is to shut your eyes & mash the pedal to the metal, you guys."
-Karl Welzein
morningisbad is offline   Reply With Quote
Old 07-08-2013, 02:16 AM   #37
mkodama
mkodama's Avatar
+1
Old 07-08-2013, 02:18 AM   #38
mkodama
mkodama's Avatar
Unless you want to cut open your bodywork from above, no, you have to look at the subframe mounting points from under the car.
Old 07-08-2013, 06:37 AM   #39
taylor192
My Ride: 2003.5 M3
You should check who's written the stickies about the convertible and you'll realize the difference between being helpful and being a smart ass nit picking the definition of words.
It may be harsh, yet you made the bed you'll lay in. I won't be helping someone I have to argue terms with when everyone what knows what is being discussed.
Old 07-08-2013, 08:31 AM   #40
jeton_g
Hopefully its not really bad...if it is u can check from the trunk if u remove everything and see how solid it is
