Go Back   E46Fanatics > Classifieds > For Sale, For Trade or Wanting to Buy > Parting Out
Parting Out
Parting out your car? Post your entire list of BMW parts for sale in one forum. Single items should be posted in one of the other classified forums.
Old 06-25-2013, 08:24 AM   #1
Snipez4664
My Ride: '00 328i
E46 rear parts- brakes, diff, 5 speed swap
I recently did an E46M3 rear subframe and 6 speed swap, leaving me with many spare parts. Everything worked great before the swap. I am willing to ship most items, offer pickup in northern Delaware, or meet you a reasonable distance away. I did not clean the items before the pictures, but will do so before shipping. Thanks!
Link to photobucket album if the pictures arent working on here: http://s5.photobucket.com/user/Snipe...?sort=3&page=1
E46 5 speed swap parts (not complete) - $600 OBO
5 speed ZF transmission - 120k miles. very smooth, no problems
clutch - 120k miles
flywheel - 120k miles
transmission brace
transmission mounts
slave cylinder
master cylinder with reservoir
stock e46 shifter
shift knob (not stock)
e36m3 pedal box (not sure of e46 compatibility)
Other E46 parts
rear rotors (10k miles) \
akebono ceramic rear pads (10k miles) > $140 shipped
rear calipers with brake lines /
rear subframe
2.93 open differential - $140 + shipping
upper and lower rear control arms
rear sway bar
rear trailing arms and hubs
axle shafts
emergency brake
speed sensors
drive shaft for e46 M3 rear subframe swap (needs to be resized)
323ci rear brake lights (some scratches)
Fuel pump assembly (<5k miles, but has broken plastic tabs. Fuel pump unit can be easily swapped into original plastic assembly)
DSC control unit
328i intake manifold and DISA valve
power steering pump
6 ignition coils
E46M3 differential fluid castrol XJ + FM (2.5 bottles, more than enough for complete fluid change) - $120 shipped
E36 parts
UUC Short shift kit for e36m3 6 speed swap
e36m3 pedal box
custom adjustable length drive shaft for e36m3 6 speed swap (4 bolt rear)
e36m3 stock driveshaft
6 speed slave cylinder
I will work on prices tomorrow and will get more pictures of the remaining items including rear subframe, differential, etc
Snipez4664 is offline   Reply With Quote
Old 06-25-2013, 01:03 PM   #2
z69ss
My Ride: 2000 323i
Do you have your factory driveshaft?
z69ss is offline   Reply With Quote
Old 06-25-2013, 04:27 PM   #3
jimmyloose
My Ride: Der Kombi.
How much for the 2.93 E46 rear differential?
jimmyloose is offline   Reply With Quote
Old 06-25-2013, 07:25 PM   #4
Snipez4664
My Ride: '00 328i
I do not have my factory driveshaft. The rear section was cut to combine with an E46M3 shaft. I ended up not using either, so i have both of them cut at the rear tube. I will sell these dirt cheap if anyone can use them for a project.
jimmyloose- 150+ shipping for the differential
Old 06-28-2013, 01:09 PM   #5
SSB Z4
My Ride: 325xiT, Z4 race car
How much for rear calipers?
SSB Z4 is offline   Reply With Quote
Old 06-28-2013, 09:36 PM   #6
220k330
My Ride: 2001 330ci ZSP
I need a flex plate --- I know I get one for $50 new..but...thought I would ask. What shift know do you have?
220k330 is offline   Reply With Quote
Old 06-29-2013, 09:24 AM   #7
Snipez4664
My Ride: '00 328i
geoffriehl - Are you refering to the guibo (between driveshaft and transmission)?. If so, i have a couple, but they are used - you might be better off buying it new TBH. I'm not sure what kind of shift knob it is, it may have come stock on some e30s. Feels much better than stock shifter. It can be seen in this picture: http://s5.photobucket.com/user/Snipe...ml?sort=3&o=15
SSB Z4 - $85 shipped obo but would prefer to give a deal on calipers, lines, pads, rotors.
Old 07-03-2013, 07:43 AM   #8
Snipez4664
My Ride: '00 328i
prices added but will continue to update. all offers will be entertained on anything without a price
Old 07-03-2013, 01:16 PM   #9
Panda330
My Ride: 330CI
How much for rear akebono brake pads to 91722?
Panda330 is offline   Reply With Quote
Old 07-04-2013, 06:06 AM   #10
Snipez4664
My Ride: '00 328i
$35 shipped for the brake pads. For $80 shipped i will throw in the rotors
Old 07-13-2013, 06:45 PM   #11
Snipez4664
My Ride: '00 328i
bump
Questions about M3 subframe/LSD swap in your non-M? Feel free to PM me...i has all teh answers
