Sponsored by BimmerWorld
Old 06-25-2013, 01:14 PM   #1
stockgp
My Ride: 1999 323i
coilover ride height problem
I recently installed my coilovers and I'm having trouble figuring out why my drivers side it's sitting higher than the passenger side.
It's a ground control kit with koni yellow shocks.
The passenger side dies at the height I'm going for. I'd like to match the drivers side.
The knob on the back of the shocks is in the slot of the spindle, and I've been unable to get the shocks any farther down than they are now.
Any tips on what it could be?
stockgp is offline   Reply With Quote
Old 06-25-2013, 01:21 PM   #2
sjacoby112
My Ride: 2002 325ci
I think the drivers side is supposed to always sit a little higher when you're not in the car so it evens out when you're driving (that's what I've read at least). so that could be one answer.
another would be did you refresh any of your other suspension components when you installed the coilovers? if you are still on the stock from factory suspension parts like control arms and such they might be dead at this point as sagging. so that could also be an answer.
hope that helps a little
2002 325ci | 5MT | SGM/AGM | Varrstoen | RoyalStance | Form Flow & Fitment | Flipzco
sjacoby112 is offline   Reply With Quote
Old 06-25-2013, 01:35 PM   #3
stockgp
My Ride: 1999 323i
Suspension was not refreshed at all. But I measured ride height before the swap, and both fronts and rears were equal with a1/2" rake front to rear.
Old 06-25-2013, 01:53 PM   #4
Sedan Hussein
My Ride: e46
How big is the difference? If you just installed the coilovers, let it settle in and then check the difference again. As said, I believe the driver side may tend to sit a bit higher but it should be discreet.
Sedan Hussein is offline   Reply With Quote
Old 06-25-2013, 02:09 PM   #5
stockgp
My Ride: 1999 323i
5/8 in the front and 3/8 in the rear
