Sponsored by BimmerWorld
Old 06-25-2013, 01:31 PM   #1
Jat007
My Ride: 99' 323i
Replacing Rear Shocks and Rear Coil Springs
-Hello gang,
I finally got the front-end suspension work done this past weekend (Struts, Struts Bearing, Bump-stop, etc). Well worth the money and wait. The mechanic that I had it done quoted 2.5 hours to replace the rear shocks and springs. After he had done the fronts, he stopped and told me if I want the rear suspension done, I would have to paid for 5 hours of labor. He doesn't seem like he want to do the job... He told me to go get an estimate somewhere else or have someone else do the work.
Before I go get another estimate, what or how much should I be looking at? I saw a video on youtube from a guy in Canada and it wasn't too bad to do...
Any ideas guys?
Thank you,
Jay
Jat007 is offline   Reply With Quote
Old 06-25-2013, 02:40 PM   #2
LeMansteve
My Ride: '04 330i 6mt ZSP ZPP
I have done the rear shocks. You will have to crawl into the trunk, pull away the carpet and cut a hole in the insulation. It was kind of a pain to do cleanly, but certainly not a significant amount of time. Other than that, the rest of the shock replacement is fairly straighforward.
Can't comment on replacing the rear springs, though.
Old 06-25-2013, 02:49 PM   #3
CharlzO
My Ride: 2000 328ci
Yeah, I didn't do springs on mine, can't imagine they would add TOO much time to it. I replaced both rear shocks in about a half hour for both sides with hand tools. The carpet was more annoying than anything, but wasn't too much to deal with. I can't imagine it would take anywhere near 5 hours for the full rear, unless he didn't even look, and was just guessing based on what he did for the front. Save yourself some bucks, and diy, and treat yourself to a nice drink afterwards with your savings!
CharlzO is offline   Reply With Quote
Old 06-25-2013, 06:39 PM   #4
Red 90
My Ride: 325i
The rears are much easier to do than the fronts. My mechanic lets me use his lift and tools. So in his shop I'm able to change out both rear shocks and springs in an hour to an hour and a half. I'm sure mechanics will charge more hours for it, but 5 might be a bit too much to change the rear shocks and springs. With the rears you don't need use a spring compressor, don't have to deal with the brakes, sensor etc. Just two bolts at the top on each of the shocks, one at the bottom. The springs are just a matter of prying the suspension down a bit, pull the spring off, insert the new one.
Red 90 is offline   Reply With Quote
Old 06-25-2013, 07:12 PM   #5
aarondb4
My Ride: 2002 BMW 330CI Vert
Do it yourself. I just did all four corners in far less than 5 hours. The rear is easy peasy, don't let some mechanic rape you.
2002 BMW 330CI Convertible
aarondb4 is offline   Reply With Quote
Old 06-25-2013, 10:07 PM   #6
Jat007
My Ride: 99' 323i
Thanks guys!!
I will attempt this work on the 4th.
Old 06-26-2013, 07:44 AM   #7
LeMansteve
Werd to everyone that pointed out it should not take 2x as long to do the rear shocks.
Old 07-03-2013, 10:12 AM   #8
CharlzO
My Ride: 2000 328ci
Just for the sake of demonstration, here's a video that shows just how simple the springs are to replace.
And as for shocks, basically, there are two nuts on each mount, on each side of the trunk. Peel the liner back, expose that, remove nuts, done. If you have the bottom bolt off (like in the video), they will likely just literally drop out of the car. If not, a tiny wiggle, and they're out. I'd recommend new mounts, and whatnot, but you put it back the same way the old ones come out. Even without ever doing it before, assuming you have the tools on hand, and a jack and stands, I'd say you can probably easily do both sides in well under 2 hours yourself. So make sure you report in after tomorrow and let us know how it went for you, and how long it took!
Old 07-03-2013, 01:16 PM   #9
steifan
My Ride: 325i '06, 323 Ci '00
The rear shocks can be replaced without even lifting the car or even taking the wheels off..
I'd recommend a helper for the spring the spring removal though.
Raise the car (not the rear axle) until the rear axle is hanging free (remove wheels, then use body weight to compress the rear axle end on either side
while the 2nd person just yank the spring out while the axle is pushed downward.
Easy
The jack-version is probably safer..
BMW 323Ci '00, Eibach/Bilstein Pro-kit/B12
BMW 325i '06, M-Sport
steifan is offline   Reply With Quote
Old 07-03-2013, 01:26 PM   #10
Jat007
My Ride: 99' 323i
That looks easy... Ok, I am going to do this tomorrow morning (4th of July) and report back.
Thanks, guys!!
Old 07-04-2013, 11:42 PM   #11
Jat007
My Ride: 99' 323i
Happy 4th!!
You guys were right, it took me last then 2 hours to do the springs and shocks. I had a lot of confident after watching the video - Thanks, CharlzO!! It's possible to replace the rear shocks without removing the wheel, but you'd if you're replacing the coil spring though...
Thanks guys!!
Old 07-06-2013, 05:17 PM   #12
CharlzO
My Ride: 2000 328ci
Re: Replacing Rear Shocks and Rear Coil Springs
Glad you got it done! It's like a lot of diy's with these cars, follow the step by steps, and you'd be surprised at how much you can accomplish! I haven't had anyone else touch my car since I got it, and it's refreshing for me to get back to doing my own work. You learn your car in the best way possible when it's your own hands turning the wrench!
Old 07-06-2013, 06:51 PM   #13
littlegti
My Ride: 2002 330ci conv
Ummm...a couple of comments on the video. Use jack stands when working on your car, not a jack. Use a torque wrench when replacing the bolts. The lower shock bolt should be torqued down when the weight of the car is loaded on the wheel.
littlegti is offline   Reply With Quote
Old 07-06-2013, 07:21 PM   #14
CharlzO
My Ride: 2000 328ci
Yeah I noticed that in a few of the videos that guy had done, he doesn't use stands. No way am I that trusting, especially those jacks he was using. I've thrown away so many of those over the years due to them losing their ability to hold weight. Can't imagine putting my faith into them the whole process, especially with my hands in where they can get squished.
Old 10-02-2013, 04:02 PM   #15
Bino5150
My Ride: 99 323i
I did both sides, rear shocks/springs in less than 20 minutes. Kinda ironic, I figured the rear was going to be the problematic part, but it really doesn't get much easier/faster than that.
Bino5150 is offline   Reply With Quote
