Old 06-25-2013, 02:28 PM   #1
danleb
My Ride: BMW 325ci
Fuel Level Sensor / Fuel Pump
My fuel pump went out about a year ago on my '04 325CI and I changed it. The pump worked fine and still does but the gas gage was not working all that great. When I filled up it would show half tank for a while then finally get up to full. I just lived with it until recently when the Service Engine light came on. I plugged in my ODB reader and came up with code P0461 (Fuel Level Sensor). So ... my question is .. How can I tell whether the sensor on the fuel pump is the issue or the other one?
Thanks ... Danny
danleb is offline   Reply With Quote
Old 06-25-2013, 04:04 PM   #2
willsbma
My Ride: 99 323i
I'm gonna guess you didn't go oem on the pump when you changed it, right?
Matte Black Kidney Grilles | Smoked Tails & Corners | Mtech II Bumper | Hotchkis Springs | ACS Roof Spoiler | M3 Spoiler | 20% Tint
WTB: Black sun visors & grab handles - PM ME!
I have P.A. Soft and a 20-pin adapter. Only used it a few times but pm me if you need anything coded!
willsbma is offline   Reply With Quote
Old 06-25-2013, 06:19 PM   #3
lszlszx
My Ride: 1.8T, XC70
Make sure all the electrical connections are clean and tight and inspect the
sensors themselves.
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 06-25-2013, 06:21 PM   #4
jfoj
My Ride: 330CiC, M5, X5, E93
Check the 2nd link below in my signature, has a lot of info on the 2 fuel level sensors and how to look at them individually.
But also as mentioned above, sometimes people do not get the connector slide bail latched fully or they bend the fuel level sensor arm when reinstalling the fuel pump/sender unit.
Old 06-28-2013, 07:54 AM   #5
danleb
My Ride: BMW 325ci
No. Ordered one one off of the internet like 90% of the others on this forum. Any suggestions? This morning I got gas and the needle when to 1/2 tank. It is working. It shows when I am getting low and seem pretty accurate on that end. The Service Engine light is what I want to deal with.
Old 06-28-2013, 08:06 AM   #6
danleb
My Ride: BMW 325ci
Thanks for the response. I read your link. Good information but I don't think is answers my question.
I was very careful when putting in the fuel pump and I am pretty sure I did not bend the arm. My question is ... is there any way ... with the on-board computer, or the ODB II cable, to tell which side is sending the signal to turn on the "Service Engine" light. I might just need some better software. Mine just give me a P0461 code with no details.
I have heard of people using the onboard computer in the dash to test things but I can find any data on how to use it with an level of detail.
I really just want the Service Engine light to go off!
Old 06-28-2013, 08:29 AM   #7
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
Go get yourself an OBD2 reader to read your engine codes. You can use it to reset it as well.
Since you put in a new FP, I would check your level sensor on the other side of the tank.
Use your hidden obc menu to verify the level in the 2 sides of your fuel tank.
Engine swaps, HG, GM & ZF tranny rebuilds.
Over 2 Billion Served !
BMWCaptainE46.com
BMWCaptain is offline   Reply With Quote
Old 06-28-2013, 02:13 PM   #8
danleb
My Ride: BMW 325ci
sensors themselves.
Thanks ... Checked the connections and that seemed to fix the erratic Fuel Gage but the light is still on. My question is ... is there any way ... with the on-board computer, or the ODB II cable, to tell which side is sending the signal to turn on the "Service Engine" light. I might just need some better software. Mine just gives me a P0461 code (Fuel Level Sensor) with no details.
Old 06-28-2013, 02:16 PM   #9
willsbma
My Ride: 99 323i
Those 90% use a pump with a proven history in our cars, if you bought X brand and the sensor isn't oem quality it could be the reason for your trouble. Not being a di@k but many before you have made mistakes when it comes to purchasing parts and that's how we learn. What brand is the pump?
Old 06-28-2013, 02:16 PM   #10
danleb
My Ride: BMW 325ci
Got an OBD2 reader but it only said "Fuel Level Sensor" ... I don't see where I have a "hidden obc menu". Maybe my sofware is just not that robust.
Is there any way ... with the on-board computer to tell which side is sending the signal to turn on the "Service Engine" light. Can you recommend better software? Mine just gives me a P0461 code with no details.
Old 06-28-2013, 02:19 PM   #11
danleb
My Ride: BMW 325ci
Not sure the brand of the pump but it seems to be working fine. The car is running great. I check the connetions and cleaned them up and the erratic fuel gage seems to be working fine but the light is still on. I am sure it could be the driver side sensor but I sure would like to know before I pull it out and buy a new one.
Old 06-28-2013, 02:42 PM   #12
jfoj
Read the 4th link below in my signature regarding the Hidden OBC Menu.
A bit tricky to access the first time, timing of the button pushing is key, but you will figure it out, hundreds before you were able to.
Old 06-29-2013, 01:08 AM   #13
BMWCaptain
Reset you engine codes to see if it has reset the error.
BMWCaptainE46.com
Old 06-29-2013, 01:55 AM   #14
Stinger9
My Ride: '04 330Ci
Print out and keep in glove box:
Old 06-29-2013, 02:17 AM   #15
MJLavelle
My Ride: 2001 BMW 330ci
The car is not running great, because you have a fuel sensor that is not working right. Spend $120 at BMA parts, and get the correct, VDO brand pump. Some things just need to come from BMW, or their OE suppliers, if you want them to work correctly or reliably. It is not a conspiracy, and you are not beating the system. It is 15 years of trial and error, that has been passed down from member to member on this forum.
Any part you have thought of buying on eBay has been tried before, and has failed for someone along the line. This is not just the experience of a few members, but the collective experience that has been passed on through the years. 99% of electronic parts need to be OEM or OE supplier, or they will not work properly, or they will fail.
Places on eBay and even the auto parts stores can and do continue to sell crap that does not work because they have that one big "get out of jail free card". It is "No returns on electrical components". That phrase is how and why they can still sell stuff that does not work, because they never have to answer for it.
Just take our word for it, that no-name fuel pump will leave you stranded at some point. It may not even be the source of the fuel level issue, but it is a big problem waiting to happen. Stay the fvck off of eBay when buying any mechanical parts.
Old 06-29-2013, 02:51 AM   #16
dgknight
My Ride: 02 325xi 5sp 120k
Ordered the Beck and Arnley one on Amazon and had this issue. Diagnosed as a sticking float by using the secret menu options listed by posters above (and written in Amazon review in detail).
Now I have an OEM one for just a few $ more from bmaparts.com, and will be switching them out tomorrow.
I was very careful not to bend the float meter arm when I installed, but each time I fill up, the thing sticks until I make a sharp left hand turn.
dgknight is offline   Reply With Quote
Old 06-29-2013, 10:10 AM   #17
Stinger9
My Ride: '04 330Ci
Simple solution to save some bucks: Return the new Siemens pump for refund, then every time you exit gas station, make that hard left turn to put things right with the world!
Old 07-01-2013, 12:00 PM   #18
danleb
My Ride: BMW 325ci
After further checking (old reciept) I found that the fuel pump is an OEM fuel pump. I guess I just need to assume that it is fine and change the driver side sensor. I am not eager to do that without knowing for sure but I have not heard from anyone how to definitively tell what the light is referring to.
Old 07-01-2013, 12:02 PM   #19
danleb
My Ride: BMW 325ci
I did that. Code just comes back.
Old 07-01-2013, 12:05 PM   #20
danleb
My Ride: BMW 325ci
Ok ... I checked the hidden codes and as far as I can tell they seem to be reading normal. The gas gage is working perfectly now and the fuel pump is working perfectly. I really don't understand why ... if everything is working fine ... I am getting a fuel sensor error that is causing the light to come on.
fuel, fuel level sending unit, fuel level sensor, fuel pump
