Sponsored by The Tire Rack
Old 06-25-2013, 06:38 PM   #1
KrasivataSabine
My Ride: 323Ci
Wheel out of round? (Ongoing vibration issues)
So far, I have replaced the FCABs with the MTC poly bushings from ECSTuning, and the FCAs with Meyle HDs. Vibrations persist, so I am looking into other causes.
This is my video:
Intro kind of long, 0:32 onward is what I really wanted to show. Is this wheel out of round?
#BattleBimmer #323RS
KrasivataSabine is offline   Reply With Quote
Old 06-25-2013, 07:34 PM   #2
Foxtrot_Uniform
My Ride: 325Xi
Looks out of round to me... Pothole try to eat you?
Foxtrot_Uniform is offline   Reply With Quote
Old 06-25-2013, 07:38 PM   #3
KrasivataSabine
My Ride: 323Ci
No particular one that I can remember. Then again, I get quite a few shocks and shudders because my suspension is so firm, anyone of those might've done it.
Old 06-25-2013, 10:39 PM   #4
KrasivataSabine
My Ride: 323Ci
Update:
replaced wheel with my OE spare wheel, the off-centered rotation persists. Can this be the bearning? Maybe a poorly mounted spacer? Will check the spacer tomorrow. Until then,
Old 06-25-2013, 10:44 PM   #5
zabalzae
My Ride: 01 330ci
Bad bearing.
zabalzae is offline   Reply With Quote
Old 06-25-2013, 11:50 PM   #6
KrasivataSabine
My Ride: 323Ci
Another update:
I removed my 10mm ECS spacer from that wheel only. Vibrations at all speeds were reduced by about 80%. I will take the spacer off on the other front wheel and see if I can get the vibration 100% gone.
Old 06-26-2013, 01:27 AM   #7
tock172
My Ride: '12 135i DCT
I had a ton of trouble dealing with vibration with my ECS 12.5mm spacers in the front. I installed them 10 different ways and had my tires balanced multiple times and it still persists. I finally just took them off.
Past: 1999 Techno Violet Metallic M3
Present: 2012 135i DCT
Old 06-26-2013, 01:23 PM   #8
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
This may sound strange, but is the wheel sitting flush against the hub or spacer? The reason I ask is because we've found some spacers won't work with our wheels, due to there not being enough hub lip to keep them centered, or they have a chamfered edge/step that is not compatible with our wheels.
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 06-26-2013, 02:15 PM   #9
KrasivataSabine
My Ride: 323Ci
I thought the spacer was flush, but given my results from post #6, there must have been something off.
Felt okay by hand. When I removed the wheel, I noticed that the black coating on the spacer had been worn off around the chamfer. What would that indicate?
