///M3 Forum
Thread Tools Search this Thread Rating: Thread Rating: 2 votes, 3.00 average. Display Modes
Old 06-25-2013, 08:43 PM   #1
Ballerbrian4u
My Ride: 2004 BMW m3
Smg shifting rough
Hey guys my smg is acting weird for a while now. The shifts are not smooth and crisp. When auto downshifting into 2 it jerks. In s4 s5 when shifting at low rpms around 2k I hear it slam into gear and clunk from the rear of the car.Also when downshifting in any gear it delays in grabbing the gear. It is not the same as day one. Any tips? I did the Adaptaion 4 months ago should I try that again?
Ballerbrian4u is offline   Reply With Quote
Old 06-25-2013, 08:49 PM   #2
Redman M3
My Ride: M3 - Individual -
Smg shifting rough
First thing to do is an SMG reset, using your shifter paddles.
The symptoms of the clunk noise can be due to the propshaft coupling located by the gearbox which requires changing as these tend to crack a lot hence mechanical sounds and clunks when changing up or down.
If you are experiencing any juddering this will mean a new flywheel is required and while you are at it maybe beat to change the clutch.
All of the above changes will bring your car back to the way the m3 SMG should operate.
HTH
BMW M3 - Individual Atlantis Blue
Redman M3 is offline   Reply With Quote
Old 06-25-2013, 08:52 PM   #3
Ballerbrian4u
Hey thanks. My car just hit 50,000 miles. I do the reset 1 everyday if No traffic.
Old 06-25-2013, 09:53 PM   #4
Moosecakes
My Ride: 02' SMG M3
My car "slams" 1st to 2nd shift too in s5. I daily in it and if you regulate your throttle a bit you can fix most of it, not lifting causes a louder harsher clunk. But Driveline bushings and rubber is always a good thing to check I need to do my guibo, csb and bearing one of these days.
Definitely reset it and your throttle adaptions so you have a clean driving slate to go from. I just reset both my smg and throttle adaptions and holy hell it made a very nice difference in shift speed, gear grabbing on downshifts and I swear 1st to 2nd shifts smoother without lifting.
Moosecakes is offline   Reply With Quote
Old 06-26-2013, 08:08 PM   #5
djantlive
My Ride: E46 M3
how do you reset the smg?
djantlive is offline   Reply With Quote
Old 06-26-2013, 08:35 PM   #6
Moosecakes
My Ride: 02' SMG M3
Driving 40mph+ move stick to N, pull both paddles back at the same time for 10 seconds, release, and put stick back in gear. No indicators will flash, some people say 4-5 seconds, some say 10, I just did it for 10 seconds and definitely noticed a change, my wife did as well, she said it felt quicker when I shifted and the rough 1-2 shift wasn't quite as harsh.
Old 06-27-2013, 01:26 PM   #7
Ballerbrian4u
HTH
I think I might have a bad propshaft coupling. I say this because the is a loud vibration at 1900 rpms. How can I check it? Is it under the heat shields.
Old 06-28-2013, 02:14 PM   #8
Moosecakes
My Ride: 02' SMG M3
Yes you'll have to drop section 1 and 2 I believe then remove the heat shields to get to your driveshaft. Speaking of, I need to put that on my list of **** to order for a quick maint, run when I get some money together haha.
Old 06-28-2013, 03:42 PM   #9
new//M3fan
My Ride: 77' 924 87' E30
not true, it simply means that the clutch slip point needs to be relearned and the clutch curve adaptation reset with Gt1 or autologic equipment.
<-- Mango *F-BOMBS IN SIGS*PRIUSCRISIS
Bilstein HD's | E30 M3 FCAB's | H&R OE Sports | F+R strut bars | Self tuned 027 93 octane chip | KoseiK1's on R888's | + crazy OCD maintenance
new//M3fan is offline   Reply With Quote
Old 06-28-2013, 07:57 PM   #10
Ballerbrian4u
Hey do I need to do those in any specific order? Adaptaion first?
Old 06-28-2013, 08:17 PM   #11
turbo_f22_pilot
My Ride: 2 pedals - 2 paddles
You perform the basic SMG reset with the paddles first. If that doesn't correct shifting, then try the adaptation reset (GT1 / AutoE / ...). Followed by a clutch relearn is studder is still present. Also if doing a relearn, might as well clear throttle adaptations while you're at it.
In order to finish FIRST, you MUST first FINISH !
Joy is future proof
Get your "M" on . . .
Reading is FundaM3ntal
CAR:
2003 TIAG Coupe / Blk Interior / SMG / HK Premium
MODS:
EU-CSL Coded / Macht Schnell intake / OEM CSL Wheels / OEM CSL Diffuser / Dinan Exhaust
Full LED Conversion / HID fog / Aurora AE / RE RTAB FCAB
BMWCCA NCC
turbo_f22_pilot is offline   Reply With Quote
Old 06-28-2013, 08:48 PM   #12
Ballerbrian4u
One question I just orders a guibo because of the vibration and couch noises. Do I also need to replace my center support bearing? What is that?
Old 06-28-2013, 09:02 PM   #13
Ballerbrian4u
Also what's a cv joint ? Witch one do I need to replace?
Old 06-28-2013, 11:55 PM   #14
turbo_f22_pilot
Here ya go . . .
RealOEM is your friend
http://realoem.com/bmw/showparts.do?...00&hg=26&fg=05
http://realoem.com/bmw/showparts.do?...97&hg=26&fg=10
Joy is future proof
CAR:
MODS:
BMWCCA NCC
Old 06-28-2013, 11:57 PM   #15
Moosecakes
My Ride: 02' SMG M3
You can replace the CSB and mount if you want to, personally I'm going to because i'll be in there anyway doing the guibo. It's like 80$ or something for the mount and bearing I think.
Dont worry about CV joints and ****, guibo, csb and mount are the big driveline items that need addressing.
Old 07-05-2013, 05:43 PM   #16
M3/805
My Ride: 2003-M3
I just did my center support bearing and drive shaft plate(guibo) to trans,it was $200.00 for parts at turners!!!
M3/805 is offline   Reply With Quote
Old 07-07-2013, 01:53 AM   #17
BioHazard2312
My Ride: BMW E46 M3
I'm having a similar issue with rough shifting. If I have an evolve SMG tune will it affect that when I do the SMG reset?
BioHazard2312 is offline   Reply With Quote
Old 07-08-2013, 08:03 PM   #18
turbo_f22_pilot
No, it will not. A reset will only reset the learned values. (the adaptation values, what the system uses to mimic your driving style)
Joy is future proof
CAR:
MODS:
BMWCCA NCC
Old 07-08-2013, 08:23 PM   #19
BioHazard2312
My Ride: BMW E46 M3
Thanks.
Old 02-07-2014, 11:31 PM   #20
crossle23
My Ride: Audi A6, '02 M3
Moosecakes thanks for the tips on the adaptive reset! Just bought an'02 smg and that definitely helped it shift better.
crossle23 is offline   Reply With Quote
