Sponsored by BimmerWorld
Old 06-25-2013, 08:27 PM   #1
MisterrrYu
My Ride: 2003 330ci
Rookie Brake Mistake = Losing Faith
So ever since getting an 03' 330ci as a college kid I've been trying to get more "in-touch" with my car and taking care of it personally.
My first project this summer would be changing out the pads and rotors. After learning all the necessary tools from scratch and what not (I didn't even know what allen or torque wrenches were before) and taking 5 times longer than most people, I succeeded in changing out the front two brakes and rotors. Every wall I encountered along the way made me almost choose to take it the shop, but I never had to.
After testing out the car I noticed the driver side rotor heated up a lot hotter than any of the other 3 rotors. I tried re-assembling this front right brake and double-checking the fittings. This is where my rookie mistake happened. While rescrewing the caliper back into the caliper boot with the 6mm slider/guide bolt, I made the dumbest mistake of cross-threading the caliper boot's thread with this pin. Now the caliper can't screw in tightly into the caliper boot.
I'm losing faith and I don't know what to do exactly. Are calipers expensive to replace? Should I just take it to the shop? Can I even drive my car to the shop when one of the caliper pins aren't tightened? Should I just buy a replacement caliper and continue on this DIY project? I really could use some guidance here
MisterrrYu is offline   Reply With Quote
Old 06-25-2013, 08:32 PM   #2
inlinesicks
My Ride: E46, Jeep, Subaru
So the hole you stripped is where the caliper bolts to the caliper bracket right?
inlinesicks is offline   Reply With Quote
Old 06-25-2013, 08:33 PM   #3
MisterrrYu
My Ride: 2003 330ci
Yes
Old 06-25-2013, 08:35 PM   #4
inlinesicks
You could either drill and tap new threads or get a new caliper. I wouldn't drive it until its fixed because if the caliper falls off and breaks the line you lose all your brakes.
Old 06-25-2013, 08:37 PM   #5
MisterrrYu
My Ride: 2003 330ci
Wouldn't drilling or tapping new threads weaken the structure of the bolt overall? Do you have any suggestions on where to buy new or used calipers?
Old 06-25-2013, 08:42 PM   #6
inlinesicks
I think maybe I'm not correctly understanding the part you stripped, can you take a picture of it?
Old 06-25-2013, 08:45 PM   #7
MisterrrYu
My Ride: 2003 330ci
I stripped one of the smaller holes in this image. I believe the word is "cross-threaded" while stripping is messing with the screw?
Old 06-25-2013, 08:48 PM   #8
CharlzO
My Ride: 2000 328ci
Depending on where you get it, a replacement caliper would run 2-300 I would say, tops? Mine in my 328 can be had for about 150 at Napa, 50ish of which is a core. That's probably their cheap version, but does come with a new bracket anyway. But that's Napa. I think you can get them elsewhere, for about double, for the good stuff. Still though, if your one corner was heating up THAT much more than the others, then it may have been sticking anyway, and you'll need to replace it regardless. I imagine most replacements would include the bracket too. It COULD be something else doing it, but the caliper sticking seems to happen more than other things it could be. I wouldn't drive it with only one holding it in, personally.
CharlzO is offline   Reply With Quote
Old 06-25-2013, 08:49 PM   #9
WDE46
My Ride: '13 128i, '04 330Ci
You cross-threaded a hole in the caliper carrier, not the caliper. No big deal. Buy a new one along with some extra caliper pins (the thing you screwed in).
I have a dream that one day our children will live in a
nation where they will not be judged by the color of
their skin but by the color of their coolant.
Old 06-25-2013, 08:53 PM   #10
inlinesicks
Oh ok. So you need a new caliper bracket not a new caliper. Call your local junk yards or ebay since new ones will be pretty expensive. Also I think technically BMW calls them caliper carriers.
Old 06-25-2013, 08:55 PM   #11
MisterrrYu
My Ride: 2003 330ci
Ok so it looks like I should just try finding a new caliper carrier one way or another and I should be back in business? Thanks for all your guys help and opinions. Looks like the caliper potentially sticking will be a whole another issue.
Old 06-25-2013, 08:55 PM   #12
WDE46
Damn they run around $150. I would source one from a junkyard as well. It's probably one of the most robust parts on the car so I'd just find one with no rust and take it apart.
Old 06-25-2013, 08:57 PM   #13
CharlzO
My Ride: 2000 328ci
I'd still say you need to check that caliper regardless. I just changed mine this morning for this exact reason. It'll heat up after you hit the brakes the first time when driving, and can lead to some nasty vibrations while driving. Though at least a new carrier would allow you to at least get the caliper back on to drive it elsewhere if needed. But definitely check it out, and make sure it's not sticking. That heat is brutal coming off one that is.
Old 06-25-2013, 08:58 PM   #14
WDE46
You probably just need one of these:
Part # 34116750151
You take the piston out of the caliper, clean it all up. Maybe use some fine grit (800) sandpaper and smooth out the piston and reinstall it with the new O-ring after lubing it up with some brake fluid.
http://www.ecstuning.com/Search/Site...50151/ES59746/
Old 06-25-2013, 09:08 PM   #15
CharlzO
My Ride: 2000 328ci
Part # 34116750151
Or that I never bothered with a rebuild myself, since I got a replacement cheap through my step-brother (lifetime warranty, so worst case, I take 20 mins and change it out if it ever goes again). But good call on the rebuild option!
Old 06-25-2013, 09:09 PM   #16
BeMyWhip
My Ride: 01 BMW 330ci
did you try to clean up the thread by maying trying this....
that hole seems to go all the way through to the back, SO, why not turn it upside down and use a new bolt (greased up) and screw it in from the rear.
This may correct the threads. Give it a try.
Always Mod!!!
Founder: 330Ci The 3 litre coupe
BeMyWhip is offline   Reply With Quote
Old 06-25-2013, 11:54 PM   #17
MisterrrYu
My Ride: 2003 330ci
I can't turn the part upside down because it needs to be fit in a specific way
Old 06-26-2013, 12:00 AM   #18
inlinesicks
He meant take it off the car and thread the bolt in the other side where the threads are not damaged. This is actually a very good idea
Old 06-26-2013, 12:00 AM   #19
MisterrrYu
My Ride: 2003 330ci
Thanks for everyone's help btw!
Old 06-26-2013, 12:02 AM   #20
MisterrrYu
My Ride: 2003 330ci
Sorry.. I'm sort of dumb when it comes to visualizing this, it's still not fully clicking with me, if the entire hole is cross-threaded how does it change if I put the screw in an opposite way?
