Old 06-29-2013, 08:34 PM   #21
jared_wiesner
My Ride: 1999 328i (M54b30)
jared_wiesner Shark Injector PAYPAL FUND
Originally Posted by lui328i View Post
Cool put me down
project in motion aluminum lip and canards
Looking good,
Now just to get those tires to fit
jared_wiesner is offline   Reply With Quote
Old 06-29-2013, 09:04 PM   #22
TnT817
My Ride: 01 330ci
Will he be driving around for the computer to "learn" the tune first? Then have it switched back to factory and drive it around to get back to a baseline and then install the epic tune and drive on it for the computer to learn? Without doing that there will be no real data. The data will be off.
TnT817 is offline   Reply With Quote
Old 06-29-2013, 11:05 PM   #23
jared_wiesner
I would plan on flashing the shark on a few days prior to the test. Then test with it and then flash on the epic.
Old 06-29-2013, 11:07 PM   #24
jared_wiesner
Originally Posted by jared_wiesner View Post
I would plan on flashing the shark on a few days prior to the test. Then test with it and then flash on the epic tune during the dyno. I will clear adaptations in between. There's no way i can afford multiple dyno visits.
Old 06-29-2013, 11:17 PM   #25
TnT817
My Ride: 01 330ci
There was a thread not too long ago with someone doing a similar test, but with just epic tune and stock. He went to the dyno on the epic tune then switched to stock while he was there and hardly anything changed because the car still technically had part of the epic tune on it due to the adaptations in the computer. I don't think you will be able to erase it completely without doing 2 different dyno sessions. I'm not real sure but you may be able to pull the battery cables off to clear out the computer in between tunes but then the epic tune will have the advantage due to the computer adapting to it. You put a new tune on a cleared computer you may not see the whole gains available. Just some food for thought. I'd be interested in donating but for real numbers I think 2 dyno sessions is what would be needed.
Old 06-29-2013, 11:55 PM   #26
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
Cool put me down
Thank you.
$6 Dollar List:
1) Rob43 $10
2) Afrodeezyak
3) RBbimmer
4) Iceman00 $20
5) Steven747
6) TrippinBimmer
7) BMW WHP
8) Maxwelljuppercut
9) lui328i $10
10)
SUMMIT POINT WV 1:24:229 SCCA
Old 06-30-2013, 12:17 AM   #27
Rob43
Rob43's Avatar
What actual Dyno experience do you base these statements on ?
Or is this just Supposition based on some reading you've done here & there.
We'd all like you to post up any & all dyno's you've personally done that shows this tune/adaptations data.
I know I've dynoed with & without my Shark Injector many times, I've never cleared my adaptations and always see a gain or loss of 6 WHP. But based on your supposition, I would still see some or all of that 6 WHP just after I've pulled the Shark off; but yet never have.
This is what "Iceman00" says about adaptations, I believe Iceman00 to be the E46Fanatics resident Dyno Expert:
http://forum.e46fanatics.com/showpos...&postcount=144
TnT817, you should sign up, it's worth your $6 bucks to find out.
Old 06-30-2013, 12:24 PM   #28
jared_wiesner
That thread was mine... The shark will have a week at least to adapt before the dyno. The epic will have a previous dyno to compare to, we should have similar numbers after it is flashed on.
Old 06-30-2013, 07:34 PM   #29
Steven747
My Ride: 05 330ci
put me down for 10
Old 06-30-2013, 07:51 PM   #30
TnT817
My Ride: 01 330ci
I have never had a dyno done to my e46 but I had a turbo e36 that was dynoed multiple times. The adaptations was impossible to check on that car because the tune had to be there or the car ran like dog shit obviously. I was just stating the adaptation stuff because I read through the other thread about the epic tune and stock and it looked like that the tune still somewhat stayed on the car after it was switched to stock. That is why I asked about it. Not trying to be a know it all and if I am wrong that is perfectly fine. Just didnt want to donate money to a lost cause basically since the numbers wouldn't be real data. If you guys don't think the adaptations are going to change numbers between tunes I'm down for the 6 bucks.
Old 05-19-2014, 01:09 PM   #31
imagine-02
My Ride: 330i
What happened with this?
imagine-02 is offline   Reply With Quote
Old 05-19-2014, 01:17 PM   #32
Rob43
Rob43's Avatar
Nothing.
Jared needed to take care of more important things,........Family.
Buy a Shark Injector, trust me; it's a very good way to spend $350 dollars.
Rob43
Old 05-19-2014, 01:38 PM   #33
imagine-02
My Ride: 330i
It's looking like that's still the best bang for your buck option (even though it's a very small bang).
Feeling a little miffed about the whole Shark Edit thing and MAP reflashes via USB never happening.
Is the USB feature useful for anything ATM?
Old 05-27-2014, 04:01 PM   #34
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
I'm never here anymore. Fund still going? PM me and I'll put in $6
Old 05-27-2014, 04:20 PM   #35
Rob43
Rob43's Avatar
Thanks for the thought , but I'd say this one is dead.
I would've really liked to see the outcome on this one.
Rob
Old 05-28-2014, 04:16 PM   #36
HakenTT
My Ride: 323i with S54
guy ran a scam. People sent him money, then when it came to last $6 he just claimed he has family emergency. Who ever sent money to that scammer is a fool.
HakenTT is offline   Reply With Quote
Old 05-28-2014, 04:26 PM   #37
Rob43
Rob43's Avatar
What the Hell are you talking about ?
No one ever sent any money,.....I really hope you're joking around.
Rob43
Old 05-28-2014, 04:45 PM   #38
erickonphoenix
My Ride: 2004 325i Touring
I believe I read somewhere (maybe here or bimmer forum) the Shark Injector just removes the lag in throttle input and bumps the RPM range to 7k. There is no horsepower gain.
However I also read the change in throttle response is a positive improvement. I have one sitting on my parts shelf at home with an intake, an under drive pulley and a throttle body spacer I just have to find time to install. I'll write something up on it when I get around to putting it on. Maybe next oil change.
erickonphoenix is offline   Reply With Quote
Old 05-28-2014, 04:50 PM   #39
//Maxwelljuppercut
My Ride: e46
Rob43
+1 lies and heresy
no money was ever sent
there was no scam
nice try
//Maxwelljuppercut is offline   Reply With Quote
Old 05-28-2014, 05:34 PM   #40
BMW WHP
My Ride: 01 330Ci w/ stick
You are totally full of shat. I'm number 7 on the list, no one sent any money in.
You're an instigator and a liar.
BMW WHP is offline   Reply With Quote
