Go Back   E46Fanatics > Classifieds > For Sale, For Trade or Wanting to Buy > Miscellaneous BMW and E46 Parts
All other BMW and E46 Parts. Random car parts, BMW posters, lifestyle items, etc.
Old 06-27-2013, 12:29 PM   #1
msane3
My Ride: 2007 335i
OEM BMW structural foam
Hey everybody, I'm selling a box of the oem structural foam that bmw uses to reinforce the e46 subframes. This is done via injection through the trunk. I believe bmw discontinued this foam but it sold for upwards of 180 dollars. I was going to use this in my m3 but I chose to weld in plates instead.
I'm not a qualified engineer yet, but from my opinion the foam could be a better option strength wise as it makes the whole subframe more rigid, instead of just the mounting points for the carrier. You can choose to do both but, in case of subsequent failure, additional welding could be required and I don't know how this foam would react to the extreme heat once added to your subframe.
I'm selling this kit for 130 shipped in the U.S. PayPal only please.
Local pick up also accepted. I'm in the San Diego area.
P.m. If interested. Thanks
msane3 is offline   Reply With Quote
Old 06-27-2013, 12:32 PM   #2
msane3
My Ride: 2007 335i
ID:	513324Click image for larger version
Old 06-28-2013, 03:20 PM   #3
sonnybobiche
My Ride: '99 323i
Unfortunately I don't think this stuff has a very long shelf life. Please correct me if I'm wrong.
sonnybobiche is offline   Reply With Quote
Old 06-28-2013, 03:34 PM   #4
mkodama
mkodama's Avatar
So long as it is unopened and unmixed, it has a very long shelf life.
Old 06-29-2013, 12:06 AM   #5
msane3
My Ride: 2007 335i
Thanks mkodama. I believe he is right. These are completely sealed. Each dispenser has 2 compounds that react when mixed. I see no reason why it should "go bad". I bought this kit from the last of a BMW dealers stock just a year ago.
If they still had it for sale a few years after the date on it, I'm sure it must be ok.
Old 06-29-2013, 07:56 AM   #6
trive2
My Ride: 1989 BMW 535i
To do a full repair you should weld the plates in and also use the foam afterwards man.
trive2 is offline   Reply With Quote
Old 06-29-2013, 12:37 PM   #7
msane3
My Ride: 2007 335i
Yes, both would be ideal. I had an m3. With more power comes a greater risk of failure. I did develop more cracks around the plates I welded in. I wanted to have the option to reweld in the future.
I think a non boosted non m would be trouble free after performing both to it.
Old 07-09-2013, 01:10 AM   #8
msane3
My Ride: 2007 335i
Bump!
Old 07-11-2013, 07:58 AM   #9
BDUB328I
My Ride: bmw 328i S54 sedan (
It has a shelf life and an experasion date on it. Looks like yours says 09. They wouldn't put a date on it if it was good until opened....when I ordered mine from thebmwpartstore.com mike (the owner) mentioned to me he was going to make sure it wasn't expired before he sold it to me because he was aware of the shelf life also.
That being said I have some that is expired 2012 and I was thinking I might use it anyway... I only got about half of one injected into the cavity now but I was holding off because i started considering future welding...
Glws, im not trying to put anyone down just hoping to educate or maybe become educated if someone knows more than I do.
BDUB328I is offline   Reply With Quote
Old 07-17-2013, 12:58 PM   #10
msane3
My Ride: 2007 335i
The way I see it, it's more of a "best if used by" date on it.
Anyways. Price is negotiable. Come guys, throw some offers!
Old 07-17-2013, 02:33 PM   #11
mkodama
mkodama's Avatar
That's debatable. Welding in plates causes you to lose rust protection in an inaccessible part of your car. For people in high salt and/or high humidity areas, that means once you weld down those plates, you just started a countdown until it fails again from but from rust.
Part of the reason BMW picked the glue repair is likely for this reason, it's permanent and there is no loss in corrosion protection, not to mention there are no additional costs from welding.
Old 08-12-2013, 12:03 AM   #12
msane3
My Ride: 2007 335i
Bump
Old 08-12-2013, 12:21 AM   #13
Llink78
My Ride: 2002 330i
I think I'm your only offer. $60 shipped to 14210
Llink78 is offline   Reply With Quote
Old 09-03-2013, 02:20 PM   #14
msane3
My Ride: 2007 335i
Bump
Old 09-18-2013, 10:08 PM   #15
Mtype
My Ride: E46 m3
70 picked up in SD?
Mtype is offline   Reply With Quote
Old 09-19-2013, 01:21 AM   #16
msane3
My Ride: 2007 335i
I will do 90 picked up
Old 10-12-2013, 03:02 PM   #17
kidplatinum
My Ride: 330I zhp
Check your PM please...in about 5 minutes that is
Bahn Burner
kidplatinum is offline   Reply With Quote
Old 10-22-2013, 02:29 PM   #18
msane3
My Ride: 2007 335i
bump
Old 02-15-2015, 01:11 PM   #19
jirro22
My Ride: M3
is this still available? shipped to 91709 thanks
jirro22 is offline   Reply With Quote
