Go Back   E46Fanatics > New Member Introductions
New members check-in, introduce yourselves, and post a picture of your BMW here!
Old 06-27-2013, 05:08 PM   #1
GuidoK
My Ride: Z4 3.0i ESS TS2+
Cool E85 fanatic
Hi,
I'm new here (after reading some years) and own a 2004 E85 Z4 3.0i.
I've done some mods to my car and I get a lot of really insightful information from this forum because the z4 and e46 obviously have a lot in common technically.
So here is the introduction of my car.
the car itself.
What I've done with the car so far (the major upgrades):
  • 1
I installed a Quaife LSD:
  • 2
I Installed an ESS TS2 kit:
  • 3
I installed Schrick FI camshafts (248/256) as part of a ESS TS2+ upgrade:
  • 4
I installed and modified Schmiedmann headers and high flow cats (200cell) (also part of the TS2+ upgrade). These are initially designed for the e46 and have an excellent price/performance. The tube diameter is much larger than stock, so it also uses a different flange between the headers and midsection. The midsection is included because thats where the cathalitic converters are situated (mid muffler delete):
Set (obviously 2 cat's included):
Headers installed (I had them ceramically coated (Cerakote) afterwards
under the car:
  • 5
I installed an ECS Brembo/BMW OEM front BBK set:
  • 6
I designed my own rear Brembo/BMW OEM rear BBK set.
This set consists of a rear 135i/m3 BMW performance (brembo) caliper with some modifications, rear drilled X3 rotors (also with some modifications obviously) and a custom made e-brake (because the x3 rotor has a larger interior drum); a bit similar as a 330i rear brake swap onto a lower model.
Some of these modifications were very easy (like the front bbk; it's bolt on) and others had some more work to it, especially if you have to make something custom from scratch
I have a lot more pictures from the build but that would be too much for 1 post.
And I did some minor modifications like cdv delete, vanos seals/anti rattle, poly fcab's poly anti roll bushings etc.
The next step is probably swapping the rear rubber bushings for poly bushings, as much as possible. But I'm still missing/hesitating over some, especially the diff.
GuidoK is offline   Reply With Quote
Old 06-27-2013, 05:16 PM   #2
wildirish317
My Ride: 2004 325Ci vert
E85 fanatic
Wow! Very nice. Welcome to the forum.
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.”
Originally Posted by Mike Miller
I just don't know what I'd do with 560 hp that doesn't involve getting arrested.
wildirish317 is offline   Reply With Quote
Old 06-27-2013, 05:55 PM   #3
My Ride: Lexus
very nice work. i'll have to look into that bbk
Old 06-27-2013, 06:13 PM   #4
blazedxjan
My Ride: 01 325ci
Re: E85 fanatic
I love those sharks. That BBK is sweet, thats the only color I've seen them in.
Shout Out cowmoo
RIP Edgar F. Glavez 4/19/89-10/19/2014
blazedxjan is offline   Reply With Quote
Old 06-28-2013, 06:10 AM   #5
GuidoK
You mean the front or the rear BBK?
E85 Z4 3.0i | ESS TS2+ | Quaife ATB LSD | Custom Brembo BBK front/rear | Schrick cams | Schmiedmann headers/cats | Powerflex/strongflex PU bushings | Vibra-technics engine mounts | H&R anti rollbars | KW V3 coilovers | Sachs performance clutch
Display Modes
