E46 Convertible
Old 06-27-2013, 06:37 PM   #1
Drexellake
My Ride: 05 330ci Convertible
Scanner and Codes
Does anybody know how to get the windows to close when the top goes up using the key remote? Unable to find searching, so there!
Drexellake is offline   Reply With Quote
Old 07-03-2013, 07:15 AM   #2
E46DrEaMeR
My Ride: 2004 330ci
iirc once the roof is coded for use with the key the windows should go up on locking/unlocking, my windows go up after the roof closes/opens whether I use the switch or the key to open/close it
Its a ragtop thing! you wouldn't understand
E46DrEaMeR is offline   Reply With Quote
Old 07-03-2013, 03:30 PM   #3
bigguy
My Ride: 2001 330ci vert
Are we talking with the fob or with the key in the door?
bigguy is offline   Reply With Quote
Old 07-03-2013, 03:34 PM   #4
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Searching results in PA soft 1.4
Old 07-03-2013, 03:37 PM   #5
Drexellake
I would have thought so too. When I put the top up with the remote it closes but the windows stop half way.
Old 07-04-2013, 11:25 AM   #6
E46DrEaMeR
My Ride: 2004 330ci
if you press the remote again do they go all the way up? I say this because on a few occasions I've had to press the remote button again when opening/closing the roof, for some reason the roof just stops at some point in the opening/closing sequence and does nothing....another press finishes off the operation
Old 07-04-2013, 12:13 PM   #7
E46DrEaMeR
My Ride: 2004 330ci
this is what I mean
http://smg.photobucket.com/user/a93d...tml?sort=6&o=0
Old 07-04-2013, 02:33 PM   #8
Drexellake
I've tried it. I'll set it back to default, then set it again and try. Even with the windows half way it better than not at all. I was wanting this option due to the frequent afternoon thundershowers we have during the summer. It would be great to put the top up from the office without having to get soaked.
