Sponsored by BimmerWorld
Old 06-28-2013, 11:41 AM   #1
Benny Minn
My Ride: 2004 325xiT 5-speed
Performance rear sway bar with stock links?
Does anyone run a rear aftermarket sway bar with the stock links?
I see that the factory bar has two long ends that simply press into the link bushings, but the H&R bar that I bought from a fellow fanatic here has ~11mm holes. The OEM links on the car currently are in good condition. Is it absolutely necessary that I get adjustable aftermarket links to attach to this bar? It seems like if I find the right bolt/washer/nut combo I might be able to make what I have work.
I defer to the wisdom of the board.
Benny Minn is offline   Reply With Quote
Old 06-28-2013, 12:59 PM   #2
SpoiledBrat
My Ride: 330Ci zhp
You need adjustable links if the sway bar is loaded when not cornering. So when you're connecting the bar to the links, if you have to push the bar in anyway to get it to align with the links, then you should get adjustable links. As to how important this is, I'm not sure.
Edit: Just read your post again and this probably doesn't help lol.
SpoiledBrat is offline   Reply With Quote
Old 06-28-2013, 01:13 PM   #3
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
You can use stock links. I did on a very large bar with a lowered car and clearance is fine. The only thing that adjustable links help with is clearance.
Old 06-28-2013, 01:37 PM   #4
Benny Minn
I guess the real question then is, what hardware did you use (should I use) to connect the stock links to the bar? Also, when you say clearance, do you mean ground or CV joint? Thanks for your input, guys.
Old 06-28-2013, 02:57 PM   #5
peytonracer4
:D
My Ride: '00 328i
The sway bar should come with the hardware you need. With the stock bar the bar physically goes through the busing. With the new one, they should provide a bolt that will go through the bushing. This design allows for adjustment.
By clearance I mean the half axles and control arms.
Old 06-28-2013, 03:40 PM   #6
Stinger9
My Ride: '04 330Ci
I used Turner H&R sways with new stock rear links and followed the included instructions.
All is well for the last 10K miles.
Old 06-28-2013, 10:15 PM   #7
Benny Minn
Guys, I think you're missing my new conundrum.
I bought the H&R bar used. It didn't come with any hardware or instructions. That's why I'm on here asking what the hardware is. I will have to assemble my own bolt/washer/locking-nut combo. If someone can tell me what size bolt at the very least, that would be a huge help.
Old 06-28-2013, 10:29 PM   #8
Stinger9
My Ride: '04 330Ci
Hardware is specially made for this install and HD at that.
I'd try to give Turner a call and see if they could hook you up with the kit that comes with the bars they sell.
Old 06-28-2013, 10:32 PM   #9
bimmernate
My Ride: 2003 330i ZHP
I can't do that, but I can show you a pic of my rear TMS bar installed (H&R) for funzies (it's not completely tightened up yet). You can use your existing end links, but they are a pain in the .... to get off the original sway bar which is why a lot of people just buy new ones to make it easier. I don't know the size of the bolt....does the existing one fit?
*EDIT* also, when you use stock links, load the suspension before you tighten the bar...which is why I had ramps in the picture too. I jacked the car up, removed the jack stands, and loaded the suspension on the ramps to tighten the bolts completely.
2003 330i ZHP 6MT
Performance: Koni Sport Struts/Shocks, Eibach Pro-Kit, 17x9 Apex ARC-8, TMS F&R Sway bars, M3 RTABs w/ Vorshlag Limiters, M3 Strut Brace
Aesthetics/Functionality: TFX Projector retrofit by lightwerkz, 20% Tint, OEM Aux Input, Clear corners, LED taillights, M3 Steering wheel, Black kidney grills, mobius dash cam
bimmernate is offline   Reply With Quote
Old 06-28-2013, 11:01 PM   #10
Benny Minn
Thanks for the pic, bimmernate.....and for the tip about tightening under load. The heads on those bolts look really big considering the size of the actual bolt, so maybe it is custom. I'll call Turner on Monday, but I'm thinking if that doesn'work, I'll have to stop by the hardware store for some high grade stainless steel M10 bolts (assuming it's metric) since that looks to be the biggest bolt that will fit through the sway bar holes. Unless H&R's kit came with a metal sleeve to go between the bolt and the link bushing, I think it should be pretty straightforward to piece together a substitute for experimentation. Self-locking nuts seem like an obvious ingredient.
Thanks for the quick responses.
Old 06-28-2013, 11:09 PM   #11
Stinger9
My Ride: '04 330Ci
I don't think so. There is no sleeve. The bolts are custom for the job with a long smooth shaft of just the correct dimension to fit into the oem rubber bushing of the link. Then the required threads. And you are correct, these are high grade due to the really high stess on them.
Wonder if you could get the correct one here: http://www.mcmaster.com/#hex-head-sh...screws/=nebvz2
Best if Turner has them for you separately.
And by the way the handling is amazing with the two bars.
Old 06-29-2013, 12:54 AM   #12
MJLavelle
My Ride: 2001 BMW 330ci
I would use the turner mounts, because there is no sense upgrading the sway bar, without upgrading its interface with the car.
Old 07-18-2013, 06:01 PM   #13
Benny Minn
Not sure I follow your reasoning. It's not like the stock links are interfering with the performance of the bar. The height of the links doesn't need to change, so buying adjustable links would be a waste. Also,the bar normally comes with hardware that works with stock links, so it would seem to me that this interface between car and bar would be perfectly acceptable.
Old 07-18-2013, 06:05 PM   #14
Benny Minn
UPDATE: Called turner 3 times and another distributer as well. Everyone said they'd check and get back to me, but no one ever did....which is pretty disappointing given that my request was fairly simple. I also called H&R directly who said that there is a hardware kit for what I was attempting to do, but that I had to get it through one of their distributers. So, yeah, I'm just going to get my own stuff from the hardware store or McMaster Carr and see if that works.
Old 07-18-2013, 06:10 PM   #15
peytonracer4
:D
My Ride: '00 328i
Do you need sizes for anything? I can try to help by getting under there and getting the fastener sizes for you since no sponsors can help you. I can also try to take pics.
Old 07-18-2013, 06:29 PM   #16
Benny Minn
Man, that would be a huge help. I'm pretty sure it's an M10, but if you can verify that and measure the length of the bolt, or tell me about the washers I'd be eternally grateful. A picture of the end of the bolt would tell me what grade I need.
Old 07-18-2013, 06:30 PM   #17
peytonracer4
:D
My Ride: '00 328i
I'll do my best. Might not get all measurements until tomorrow. My car is kinda low and I'm not raising it up until tomorrow
Old 07-18-2013, 06:44 PM   #18
peytonracer4
:D
My Ride: '00 328i
Yeah this is the best pic I can get at the moment. Doesn't really help at all. I'll get the measurements for you tomorrow when I swap out my wheels.
Old 07-18-2013, 06:44 PM   #19
peytonracer4
:D
My Ride: '00 328i
Old 07-22-2013, 05:51 PM   #20
Benny Minn
peytonracer4, did you get any sway bar hardware measurements this weekend?
