Old 06-29-2013, 08:05 AM   #1
Monte330i
My Ride: 01 330i
Little help! Embarrassed to drive my e46... Pic inside.
Hey all. This is how my car looks in the evening:
Not so bad but notice that the right turn signal is on. It doesnt blink. It just stays on constantly if the headlights or parking lights are on. If the headlights and parking light are off then the signal operates normally. All bulbs are good and I have excluded the tail lights as the problem.
When the parking lights are off and I turn on the right turn signal I have noticed that the signal works fine but the amber backlighting in the dash blinks along with the green right signal arrow on the dash.
I obviously have a short circut that is connecting the right turn signal to whatever power wire that operates the parking lights. I figure its either in the LCM or in the stalk itself or in the wire loom. Any suggestions?
Anyone in the NC/SC beach area willing to let me test with thier LCM?
Where can i find a color code for the wires going to the tail light harness?
Is the LCM servicable?
Any help is appreciated. This problem is gonna get dangerous at night as the rear signal stays like this and wont blink for right turns. Front and side marker operates normal under all conditions. Help!
Monte330i is offline   Reply With Quote
Old 06-29-2013, 08:15 AM   #2
Lionelski
My Ride: 325CIc
Fog light option?
'Ski
www.WarrenvilleRailroad.com
2001 325ci Convertible - Titanium Silver
Sport Package, Premium Package
Racing Dynamics Strut Tower Brace
Conforti Shark Injector, Conforti CAI
Interior: Leather, Euro Tray, M3 Dead Pedal
Lionelski is offline   Reply With Quote
Old 06-29-2013, 08:16 AM   #3
mjpgolf1
My Ride: 00 328i,05 745,03 X5
Dont take this the wrong way but It looks like you are running cheap aftermarket led tail lights. If you still have your factory lights I would hook them up and see if the problem is in your cars wiring or the aftermarket tails. Just a suggestion to try to pinpoint the problem and eliminate the actual lights as being the issue. Good luck.
mjpgolf1 is offline   Reply With Quote
Old 06-29-2013, 08:50 AM   #4
jfoj
My Ride: 330CiC, M5, X5, E93
OE LED tail lights did not come out much later, after facelift.
So you do have aftermarket tail lights and there may be a wiring or controller problem??
Old 06-29-2013, 08:52 AM   #5
Monte330i
My Ride: 01 330i
Fog lights operate normal and dont seem to factor into my problems. Tail lights are decent quaility and have been swapped from side to side and swapped back to my OEM incandecent bulb taillights with no difference in the problem. I am positive the problem is before the harness to the tail lights. Im leaning towards the LCM. Thanks in advance guys!
Old 06-29-2013, 09:14 AM   #6
2003 325i
My Ride: '03 Orient Blue 325i
Trying to remember... ground wire recall for tail lights?? Forget how they acted up... was a couple years ago when I had the issue.
Originally Posted by MTA330ci View Post
Does anyone have a recommendation on which is the best high performance valve stems?
Old 06-29-2013, 10:47 AM   #7
Monte330i
My Ride: 01 330i
Does anyone have the pinout code for the harness?
Im about to remove the lcm and try to clean it and check the connections.
I wish some fanatics lived around here...
Old 06-29-2013, 12:06 PM   #8
iRide113
My Ride: 2004 M3
You're embarrassed to drive it because of that? Wow, imagine if your car had a scratch or one of your Angle Eyes were out!
iRide113 is offline   Reply With Quote
Old 06-29-2013, 12:26 PM   #9
Alex323Ci
My Ride: M3 & 323Ci (sold)
well obviously he has aftermarket LED tail lamps, bmw never made E46 sedan LED tails.
OP I would try swapping out from side to side to see if its that right side LED lamp or that right side wiring.
Old 06-29-2013, 12:46 PM   #10
3coupe
My Ride: 330Ci
When You say no difference when you swapped, do you mean the right side was always on or the right tail light?
My guess is the wire for the turn signal and tail lights is touching somewhere. I'm not too familiar with the wiring in the e46, but the backlight blinking when the turn signal is activated seems like a clear sign that the power between the two are crossing somewhere. I would check the connectors and harness in the trunk first.
For wiring check out this site http://www.bmw-planet.com/diagrams/
The info you'll need is under components and signal information->components->E47
3coupe is offline   Reply With Quote
Old 06-29-2013, 05:19 PM   #11
Monte330i
My Ride: 01 330i
yeah i switched the lamps and tried my old oems and the problem was always on the right side of the car . Im going to search the wiring diagrams and try to locate the crossed wires. I found a lcm for $55 but it has a position for autolights. my 2001 doesnt have the feature but i wonder if the harness will still plug in and work?
Old 06-29-2013, 08:35 PM   #12
Snik
Snik's Avatar
My Ride: IR M3 Vert.
Lol@ all those knocking aftermarket LED tails. :smh:
The problem is likely the wiring where it enters the trunk.
That bend you see by the trunk hinge on the side. Remove the cover. Bet, those wires are damaged. Common on verts. Sometimes others. Check for ruptured wires. I'm told the best fix is to cut out broken wire. Replace with fresh wire. Solder. Cover. Then recover the loom.
Do you ride a sportbike?
Old 06-29-2013, 08:53 PM   #13
TnT817
My Ride: 01 330ci
There should be a ground right by the tail light. Loosen that up then put a little dielectric grease on it and tighten it back down. Had a similar issue with mine.
TnT817 is offline   Reply With Quote
Old 06-29-2013, 09:05 PM   #14
JS330
My Ride: '01 330Ci 3 Pedals
if its coming on with the interior lights, id be willing to bet that there is a frayed or burnt connection in the lcm or behind it where the rear right indicator is coming into physical contact with a 12v live wire in thats connected to the interior dash lights
Originally Posted by DeclanM3 View Post
I hope he isn't using Pirelli condoms..
JS330 is offline   Reply With Quote
