Go Back   E46Fanatics > BMW Regional Forums > Regional Forums > Mid Atlantic
Mid Atlantic
DC DE MD PA VA WV
Old 06-29-2013, 09:34 AM   #1
Snipez4664
My Ride: '00 328i
FS Northern DE - 5 speed swap, full rear, etc
I recently did an E46M3 rear subframe and 6 speed swap, leaving me with many spare parts. Everything worked great before the swap. I am willing to ship most items, offer pickup in northern Delaware, or meet you a reasonable distance away. I did not clean the items before the pictures, but will do so before shipping. Thanks!
E46 5 speed swap parts (not complete) - $600 OBO
5 speed ZF transmission - 120k miles. very smooth, no problems
clutch - 120k miles
flywheel - 120k miles
transmission brace
transmission mounts
slave cylinder
master cylinder with reservoir
stock e46 shifter
shift knob (not stock)
e36m3 pedal box (not sure of e46 compatibility)
Other E46 parts
rear rotors (10k miles) \
akebono ceramic rear pads (10k miles) > $140 shipped
rear calipers with brake lines /
rear subframe
2.93 open differential - $140 + shipping
upper and lower rear control arms
rear sway bar
rear trailing arms and hubs
axle shafts
emergency brake
speed sensors
drive shaft for e46 M3 rear subframe swap (needs to be resized)
323ci rear brake lights (some scratches)
Fuel pump assembly (<5k miles, but has broken plastic tabs. Fuel pump unit can be easily swapped into original plastic assembly)
DSC control unit
328i intake manifold and DISA valve
power steering pump
6 ignition coils
E46M3 differential fluid castrol XJ + FM (2.5 bottles, more than enough for complete fluid change) - $120 shipped
E36 parts
e36m3 pedal box
e36m3 stock driveshaft
I will work on prices tomorrow and will get more pictures of the remaining items including rear subframe, differential, etc
Snipez4664 is offline   Reply With Quote
Old 07-09-2013, 05:31 PM   #2
Snipez4664
My Ride: '00 328i
pictures fixed. everything still available
