E46 Convertible
Old 06-29-2013, 12:47 PM   #1
pcdriver
My Ride: 05 330cis Convertibl
Replacing Antenna
Does anybody have any idea how to replace my broken stock antenna? I bought a stubby and would like to install this myself. Thanks for the input.
pcdriver is offline   Reply With Quote
Old 06-29-2013, 05:26 PM   #2
Jimjar
My Ride: 2006 325Ci
Turn the old antenna counterclockwise and it should unscrew at the base. You should be able to do this with bare hands.
Jimjar is offline   Reply With Quote
Old 07-01-2013, 11:34 AM   #3
aarondb4
My Ride: 2002 BMW 330CI Vert
If it is just the antenna then just grab it and twist and it should come off the base. The base is about 2 inches tall and is bolted to the car, the antenna is a separate piece and just screws into the base. I figured this out the hard way when I destroyed my base trying to get the antenna off.
If you need a new base then you have to go into the trunk, remove the lining on the left, remove the bracket that holds the hydraulics and then look up and you will see a circuit board looking thing with wires going into it. There is a nut in the middle of that board that is holding the board to the antenna base. Remove that 8mm nut and the board will come down, then pry the antenna base out and replace it. ECS tuning sells the base if you need one.
2002 BMW 330CI Convertible
aarondb4 is offline   Reply With Quote
Old 07-01-2013, 01:38 PM   #4
johnrando
My Ride: '06 330 CIC ZHP
Yup, very straight forward. The stubbys look great on the verts IMHO.
John '06 330 Cic ZHP
Southern California
ZHP, Cold Weather Pkg., Leather, Jet Black/Black/Black Cube, NAV
AA Tune, Sprint Booster, BMW Perf. Intake, Magnaflow Exhaust, Dinan STEP S/W & TB, TMS Pulleys, H&R Touring Cup Kit
BMW Perf. Strut Brace, Orion V2 Angel Eyes, No-holes License Plate, SMG Paddle Shift Mod, Besian VANOS, Gold DISA, Fan delete
Old 07-01-2013, 01:46 PM   #5
aarondb4
Forgot to add. Don't be afraid of the BMW stubby antenna. I haven't noticed any difference in sound quality by having the short antenna. And yes, it looks much better!
Old 07-02-2013, 09:43 AM   #6
hagsdg7
My Ride: 2004 325ci
You can also replace the base without removing the bracket and board by using a very small hex bit on a vey long extender- there's a small set screw that holds the base onto the car- the screw is barely visible but with a hand mirror and a few minutes of concentration you can take the base off that way- snapped my stock antenna off while changing to a stubby- threads were seized. Had to replace the base too. Good luck!
hagsdg7 is offline   Reply With Quote
Old 07-02-2013, 09:31 PM   #7
Bmill160
My Ride: 2001 M3 Vert
Re: Replacing Antenna
I threw a stubby on a few years ago, LOVE the look but getting sh*t reception. I was told its probably a euro adapter that came unplugged or might be missing altogether?
Sent from my DROID RAZR using BimmerApp mobile app
Bmill160 is offline   Reply With Quote
