Old 06-30-2013, 12:28 AM   #1
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
Guibo Guide (Flex Disc): Non-M, M3, & F/I
The Guibo Guide (Flex Disc).
So you need a new Guibo, because your old one is shot or you destroyed yours with more WHP, this guide will help you make the best choice for your application.
Non-M, if you drive a stock or lightly modded N/A Bimmer on the street or for track days, your best choice is number one (1).
Non-M, if you drive a F/I Bimmer, give great consideration to upgrading to a M3 Guibo, choice number two (2).
Non-M, if you drive a F/I Bimmer & occasionally drag race it at the track, give great consideration to upgrading to a Solid Guibo; choice number three (3).
M3, if you drive a stock or lightly modded N/A Bimmer on the street or for track days, your best choice is number two (2).
M3, if you drive a F/I Bimmer on the street or for track days, you could use either choice number two (2), or upgrade to choice number three (3).
M3, if you drive a F/I Bimmer & occasionally drag race it at the track, give great consideration to upgrading to a Solid Guibo; choice number three (3).
1) Stock, ALL Non-M E46
Part # 26117511454
http://www.realoem.com/bmw/partxref.do?part=26117511454
2) Stock, ALL M3 E46
Part # 26112226527
http://www.realoem.com/bmw/partxref.do?part=26112226527
3) REVSHIFT (Solid) BMW Flex Disc, # FLX-9612 $129.99
https://www.revshift.com/shop/index....975f4m6oe9u8g2
OR
FUNCTION-7 (Solid) BMW Flex Disc, # F7E46MDC $249.99
http://www.function-7.com/products/e46m3-guibo
http://www.jhpusa.com/store/pc/viewP...1&idcategory=0
Good luck.
SUMMIT POINT WV 1:24:229 SCCA
Old 06-30-2013, 02:39 AM   #2
TerraPhantm
My Ride: M3 & ZHP
I think M3 guibo would be appropriate for 330s. E36 M3 gets the M3 Guibo, and it has almost identical power characteristics to the 330, specifically the ZHP
Old 06-30-2013, 02:53 AM   #3
Rob43
Rob43's Avatar
OK.
I certainly have no problem with that in anyway. But if I had a 330Ci/i with a 100K mile Guibo on it, and were driving it normally with N/A mods, I'd still buy a stock OE guibo; because I'd expect to see another 100K miles out of it.
But if I were being rough on the car, it's upgrade time.
Old 06-30-2013, 03:41 AM   #4
TopasE46
My Ride: 2001 325Ci
Re: Guibo Guide (Flex Disc): Non-M, M3, & F/I
What purpose does the guibo actually serve? Just a vibration dampener? I would consider the solid one on my 325ci to get rid of a maintenance/wear item.
TopasE46 is offline   Reply With Quote
Old 07-03-2013, 09:08 PM   #5
Rob43
Rob43's Avatar
This is something you should Google.
