Old 06-30-2013, 04:29 PM   #1
Twin_Turbo_S54
My Ride: M3
Billet S54 block
Can someone find a billet block manufacturer?
If we can get 10 orders this Project may come through.
La ilahe illallah = God is one and only
Twin_Turbo_S54 is offline   Reply With Quote
Old 06-30-2013, 06:25 PM   #2
zurus
My Ride: Interlagos Blue Z4M
why
zurus is offline   Reply With Quote
Old 06-30-2013, 06:36 PM   #3
Davconelectric
My Ride: Mainly cars
Originally Posted by zurus View Post
why
+1
Davconelectric is offline   Reply With Quote
Old 06-30-2013, 07:05 PM   #4
Sedan Hussein
My Ride: e46
because racecar
Sedan Hussein is offline   Reply With Quote
Old 06-30-2013, 07:08 PM   #5
TnT817
My Ride: 01 330ci
Billet S54 block
Because NASCAR!
TnT817 is offline   Reply With Quote
Old 06-30-2013, 10:44 PM   #6
Twin_Turbo_S54
My Ride: M3
the "weakest" point on S54 i the block.
rods/pistons/bearings/valves/head studs and other internals can be modified up to high power levels but the block remains weak.
lately the number of 900 whp M3s increased. all these 900 + whp M3s will soon discover the weakest point as the block itself.
a billet block will help us to put 1000 + whp reliable.
Old 06-30-2013, 11:10 PM   #7
zurus
how many have you broken? and pics?
Old 07-01-2013, 12:53 AM   #8
daniel_f.
My Ride: 330iC
so billet means forged?
Im currently at baby vacancy!
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 07-01-2013, 12:58 AM   #9
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
Mert,
If I was to do something like this, the first thing I would change would be the deck height. (Improve the rod ratio, and give space for larger crank strokes)
Secondly, I would want to run sleeves...not because a sleeve alone is better, but because you can control the metallurgy better for advanced coatings to be applied. There is a reason why Capricorn only applies their best coating system to their own sleeves. (Previously known as Perfect Bore) The better coatings involved heat to apply, and I would venture that most billet alloys used for block manufacturer, would probably start to anneal with the heat. (Softens the aluminum)
Third, the oil system for an extreme build should be dry sump. (This precludes being a "street" car, which most people seem to be focused on.) I would revise the oil system so that the block and cylinder head had separate HP feeds, and a common drain back. This would allow volume control for the bottom end, which requires most of the oil volume, and pressure control for the top end which likes higher pressures.
$10k is a starting point......but from experience the cost of the block isn't the expensive bit. It's all the other things you plan to change...because the block now allows it, that add up. A good crank/rod/piston package will be another $10k...then the dry sump which with 2 pressure stages, 3 scavenge...easily another $10k with all the trimmings.
And then you get into heat management. Most built-for-purpose high-hp engines need heat in them to be at proper clearances. Problem is, when they are cold, those clearances in some places will destroy the engine if you try to idle it up to temp. This is why it takes 2 hrs to start an F1 engine, because you need to pre-heat everything before it starts. Heat management in this case is the ability to externally cycle oil and coolant to bring everything up to temp before starting. Those systems are silly expensive.....
I would not do a billet block unless I was going to take advantage of ALL of the tricks....and that's an expensive question to answer.
Old 07-01-2013, 01:14 AM   #10
DavidDee
My Ride: 2004 325xi
Re: Billet S54 block
Subbed for curiosity.
Sent from my SCH-I545 using BimmerApp mobile app
"It has a radio and speakers but it's kinda hard to hear over horny bitches moanin in the back when I start it up.."
DavidDee is offline   Reply With Quote
Old 07-01-2013, 11:53 AM   #11
Cipri
My Ride: E46 M3 2002
How did the sweeds hit 1200hp on the stock block?!
Sent from my GT-I9505 using BimmerApp mobile app
Cipri is offline   Reply With Quote
Old 07-01-2013, 02:48 PM   #12
m3micke
My Ride: e46 m3
1260 whp on stretcar
m3micke is offline   Reply With Quote
Old 07-01-2013, 03:13 PM   #13
FragNasty
My Ride: Car
Mert,
Before all else, I don't put myself in the same league of knowledge as PIE330Ci or any other hard core wrencher. In fact I consider the following to be the equivalent of stating the obvious for anyone who really is into these sorts of things.
Anyway, I'd be honored if any correction or comments.
There are other optimizations with the S54 platform that ideally could be addressed:
1. The wall clearances between cylinders is very tight, changing that would mean necessarily new heads and a new crank at the very least. Such a modification could just be a requisite for changing the alloy used in the block.
2. Some speculation suggests the main caps and center journals on the lower end should be beefed up for high HP applications.
3. Being a cast iron piece, it's quite heavy. Newer materials could be employed in a rebuilt block, that could mean working out all the metallurgy calculations to meet the requirements of internal forces, vibrations, friction and cooling requirements. Basically engineering a new engine from ground up.
If someone is serious about rebuilding a beefed up version of the platform it makes sense to examine whether grabbing something already baked would be enough reach performance goals. LSX probably being the cheapest option. For the BMW purists maybe the S85 is appealing.
My guess is going the route of an engine swap would be much more cost and time effective simply because your project starts with parts that is already engineered for high performance and readily available for purchase.
All the performance options continue to be on the table: Dry Sump, boring and stroking, and maybe even sleeves (if you want to ignore the alusil related issues in the S85 and go with sleeves) and you would have saved yourself all the time associated with ironing out design, material and fabrication related bugs.
The question I have for Mert is: Do the limitations that cause you to consider a billet block get addressed by simply transplanting?
FragNasty is offline   Reply With Quote
Old 07-01-2013, 03:40 PM   #14
Twin_Turbo_S54
My Ride: M3
I cannot speak on behalf of Swedes. All I know is about my experience.
Dyno numbers mean nothing, we need to see either 1/4 mile times or 60-130 and 100-150 mph times.
I think as more people will push the S54 envelope more block related issues will arise.
Old 07-01-2013, 03:50 PM   #15
Twin_Turbo_S54
My Ride: M3
Mert,
Adam,
I would like to meet you in person one day in my life.
Thank you very much for the detailed write up.
Old 07-01-2013, 04:19 PM   #16
Twin_Turbo_S54
My Ride: M3
Very nice write up.
I built my own billet main caps 3 years ago and still the block remains the weakest link.
lsx based engines will make 2-3 times more power but wont make me happy.
just saw a supra thread 1300 whp dyno Dynamics, thats like 1500 dyno jet...
Supra platform has been pushed a lot throughout the years so we also need to work on the S54.
Old 07-02-2013, 01:38 AM   #17
02PRUV
My Ride: E46 M3 Turbo
Very nice write up.
Mates of mine have a Torana setup with a 2JZ for drag week that's going on the ship this weekend. It's a N/A block with billet main caps, stock crank, N/A stock head with stock size good valves, good valve springs with stock N/A exhaust manifolds turned upside down, a modified stock N/A intake manifold. It makes 1300rwhp @ 60psi on a Dyno Dynamics through a turbo 400 and a 9inch. That is crazy power for a 186ci engine
Rides:
BMW E46 M3 Turbo 570rwhp @18psi (old setup)
BMW E46 M3 LSX 427ci 800hp N/A
Ultima GTR LSX 440ci 800hp N/A
VY SS Ute Turbo 1004.6rwhp @ 28psi E85
Ford Escort Mk2 2JZGTE 600rwhp @14 psi
04 Yamaha R1 154.3rwhp
ISUZU FZR550 tilt tray (GT35 Turbo)
02PRUV is offline   Reply With Quote
Old 07-02-2013, 01:41 AM   #18
MarcusLSB
My Ride: X5, CT200h, CLK63 BS
Good luck with this Mert... But I think my wallets going to sit this one out.
Old 07-02-2013, 02:17 AM   #19
Twin_Turbo_S54
My Ride: M3
Allan, I saw it over Suprafrms. In shoot out mode that 2JZ made 1300 whp, this is 1500 whp on dyno jet.
Dyno graph shows 60 psi as well
I ve asked the max engine speed and was told it was 9500 rpm.
Serious power out of 186 cid.
Marcus, if you are out of game WHO will be in
Old 07-02-2013, 02:20 AM   #20
MarcusLSB
I think the blocks hold enough power for the majority of the crowd as they stand.. its going to be hard to sell a billet block for those looking for more than 1200rwhp or so.. just not enough market for it.
