Sponsored by The Tire Rack
Old 07-01-2013, 12:17 PM   #1
ajai
My Ride: 330ci***65104; 328i
tire size needs to match neg camber????
I have rear 18x9 on 225/40/18
The tires are pretty stretch , and I have neg -2.4 camber
will the cause it to be unstable on high speed corner or instance highway speed?
which size tires are best of my rims
missed the ci, welcome the i
ajai is offline   Reply With Quote
Old 07-01-2013, 02:37 PM   #2
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
What offset are your wheels? Are your fenders rolled at all?
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 07-02-2013, 02:39 AM   #3
ajai
ET 35 18x8. 18x9. 225/40/18 all around
front and rear both -2.4 camber. The rear is stretched tires, front is perfect size.
the car handle like crap on high speed.
if I keep -2.4 in front and -2 in rear, does that make sense?
or front n back should have same camber
Old 07-02-2013, 01:07 PM   #4
VMRWheels
VMRWheels's Avatar
You might be able to get away with a 255/35/18. Your car looks pretty low though so I'd recommend a fender roll if you go that route.
Old 07-03-2013, 02:31 AM   #5
ajai
so I should get wonder tires on rear to get more stable, instead of get les neg camber?
Old 07-03-2013, 12:36 PM   #6
VMRWheels
VMRWheels's Avatar
The reason you may be experiencing unstable handling at higher speeds could be a few things. I would check your alignment first, and then order wider tires in the rear, if you can.
Old 07-03-2013, 07:46 PM   #7
Minnoe07
My Ride: 2004 BMW 330Ci
Definitely get an alignment check. -2.4 degrees of camber in the front sounds you are maxed out on camber.
2004 330Ci 6 Speed; UUC Sway Bars; Powerflex RTAB's and FCAB's; KW V2 Coilovers; 3.38 OS Giken LSD
Z4 Finned Diff Cover; Headers; M-Tech II Rear Bumper and CF Diffusor; CF Trunk; CSL Front Bumper
M3 CF Hood; DICE I-Pod Kit; JTD Rear Shock Mounts; UUC Front Strut Bar; O2 Simulators
ESS TS2 Twin Screw Supercharger
Minnoe07 is offline   Reply With Quote
Old 07-08-2013, 08:00 AM   #8
ajai
I was thinking about the rear tires too. But as lots of people got stretch rims here , they don't seems to cause problem for them.
-2.4 camber all around, I am on coilover with camber plate.
I call up the shop, I said small corner and low speed corner is sharp, but high speed is bad.
They said -2.4 seems correct camber to him......
He suggest me to stiffen up the front coil.
I really don't think that has to do with it
