Shifts getting tough when I parked; when I came back the car wouldn't start - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 07-02-2013, 06:16 PM   #1
McSpeed
My Ride: 2005 ZHP TT Stg 1
Hey guys! Long time. The car's been awesome until the other day:
As I was maneuvering to park at a grocery store I noticed that getting into first gear and reverse was suddenly tough. I knew this meant the clutch wasn't disengaging fully and figured I'd put it up on jackstands for a looksee when I got home. But when I got out of the grocery store 30 minutes later, the car wouldn't start - just as if I wasn't pressing the clutch pedal down (I believe this is due to the 'clutch safety switch'). I knew that taking the clutch stop out might get me enough travel to start the car, but I'd also heard that it wasn't good for the clutch master cylinder seals so I opted to have AAA flatbed it back home. So now the car is on jackstands.
Notes so far:
  • the slave cylinder looks fine
  • the clutch master cylinder looks fine
  • the brake fluid is at max
  • there are no visible leaks
  • the clutch pedal arm doesn't look bent and the linkages seem ok
  • peering through the slave cylinder hole with a flashlight I confirmed that all 6 pressure plate bolts are in place (it's the SRE PP)
  • I replaced the rubber hose to the slave cylinder about a month ago because the original had a bulge in it. The whole brake and clutch system was flushed at that time.
I was about to bleed the clutch hydraulics again and go from there but I wanted to see what you guys thought first. What causes the the clutch switch to not trip and the clutch to drag slightly when the pedal essentially feels normal? I was thinking maybe the clutch release lever/fork could be bent *gulp*, but then why would that prevent the clutch switch from tripping? That makes me wonder about the clutch master cylinder...a part I have never had to mess with.
SOLD but fondly remembered...
Technique Tuning Stage 1 Turbo w/ Greddy Profec B Spec II | 3.07 Quaife
ATI Super Damper | Vaio Oil Pump | VAC Pan Baffle | SRE Organic Clutch
Turner Reinforcements | SPC Camber Arms | Powerflex FCABs & SFBs
Turbo Driveability Video
Horsepower vs. Torque
McSpeed is offline   Reply With Quote
Old 07-03-2013, 02:12 AM   #2
HakenTT
My Ride: 323i with S54
connect it to the INPA and watch live data, and see if you can see clutch pedal signal.
Siemens MS43 tuning master
HakenTT is offline   Reply With Quote
Old 07-03-2013, 08:36 AM   #3
McSpeed
Interesting! What if I did that and there was no clutch pedal signal? Would that imply that the clutch master cylinder is faulty?
Old 07-04-2013, 03:25 PM   #4
McSpeed
Update:
  • When I remove the clutch stop, the car will crank. I only let it crank for a split second, but that's enough to establish that the clutch switch works.
  • When I screw the clutch stop back in and try to start, there is no cranking.
Since the issues of the clutch switch not tripping AND the clutch dragging were simultaneous, it's as if the the clutch master cylinder piston is not getting pushed far enough, pointing to wear on the clutch pedal bushings and/or a bent clutch pedal arm, correct?
Here's the clutch stop:
Old 07-05-2013, 12:11 AM   #5
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
It almost sounds like the pivot point on the clutch pedal has changed.
As both the clutch dis-engagement, and the sensor are saying the same thing.
Old 07-05-2013, 12:36 AM   #6
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
Ok...I dug out a picture of a removed pedal set....including the brake switch mounting bracket. This is really confusing me now, because the only way the pivot position would change is if the composite clutch pedal broke....and it would basically fall off it that happened. Both the brake and clutch share the same pivot pin.
I think you may have had 1 problem and caused the other.
First, I think there is an issue with the clutch. By pressing down the clutch pedal further, you've actually moved the brake position switch. (It has a ratcheting mounting mechanism) You'll need to look under there to see what I mean. I think when you were moving the car around before going into the store, was the initial "extra" pedal movement that moved the switch.
The real issue may be related to either the throw-out bearing, pressure plate, or there's a plastic pivot point on the far side of the transmission that the clutch fork sits on. I've heard of those getting worn out...breaking...or even falling out.
Old 07-05-2013, 09:33 AM   #7
McSpeed
changed.... like THIS?? :
here's what the pin that connects the pedal to the master cylinder arm is supposed to look like:
(taken from this thread which has great pics that match my car: http://www.chitownm.com/forums/showthread.php?t=3694.
this one is also good: http://m3forum.net/m3forum/showthread.php?t=88857)
As soon as I pulled the spring off, I noticed some considerable play in the pedal. The busted pin was just floating in there loose.
Earlier the day the problem initially arose I thought I heard some kind of snap when I put the clutch in at the same time as I rolled over the bump that marks the beginning of my driveway. The combined force of the my foot and the bump, along with some uncontrolled twist, may have finally overwhelmed the pin. In my research I hadn't seen anyone who'd had this happen, but then again the Sachs Race Engineering pressure plate makes for some unusually high pedal resistance.
Old 07-06-2013, 06:07 AM   #8
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
That would do it.
Here's the picture I was referencing above:
Any thoughts on making it out of some other material?
Edit: I see now that I was talking about the wrong pivot pin. On earlier cars, there is a pressure switch for the clutch, on later cars there is a magnetic switch for the clutch. I had the magnetic switch like you have on my 330Ci, and ended up grafting the entire OEM clutch assembly into a Tilton pedal box. I'll dig up the picture just for S&Gs...
Smart find on the research!
Old 07-06-2013, 06:24 AM   #9
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
I realize this is a bit OT, but I figured the OP wouldn't mind.
The joke was that I realized afterwards all I needed to do was add a Hobbs switch on the hydraulic line, and I could have kept the Tilton MC.
Old 07-06-2013, 07:12 AM   #10
McSpeed
Neat - so those two brake cylnders eliminate the big flying saucer OEM master cylinder? Bummer it didn't work out though; it's so nice and tidy.
ha as luck would have it BMW made a new, superseding, part # with new material. Feels tougher:
With the replacement of this pin, which connects the clutch pedal to the arm of the clutch master cylinder, my car's issue has officially been resolved. Ahhh, off the jack stands at last...
Old 07-06-2013, 08:14 AM   #11
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
Good news on the updated part!
On the next race car, I'll probably be doing a Tilton 600 series pedal box.
The P54 intake manifold hits the OEM brake assembly (BIg disk)....one of a few reasons why I didn't put it on the 330i.
Old 07-09-2013, 08:35 AM   #12
Hornung418
My Ride: '04 MB ZHP
Re: Shifts getting tough when I parked; when I came back the car wouldn't start
Excited to finally see the famed P54 intake mani on your next build.
Good work on the fix McSpeed. Glad to have you back. Hope you are doing well!
Hornung418 is offline   Reply With Quote
