Old 07-03-2013, 11:25 AM   #21
cak323i
My Ride: ///M3 & 330i ZHP
Originally Posted by MercForHire View Post
Just start the car. It's practically brand new
oh no....here we go....
2004 TiAg ///M - 171,000 miles.......................2003 Imola ZHP - 180,254 miles
cak323i is offline   Reply With Quote
Old 07-03-2013, 11:45 AM   #22
awesomechinz
My Ride: 1999 BMW 323i sedan
How do i prep an e46 prior to starting it up after 9 years in storage?
Place bets on if the ET is good or not.. I say nay
awesomechinz is offline   Reply With Quote
Old 07-03-2013, 11:52 AM   #23
zander271
My Ride: 6spd ZHP/5sp XI
Where was this car stored at?
ZHP Mods: JB Lightweight fly wheel (10.5 pounds), Koni FSD ProKit, Supreme Power Drop Hats, Hotchkis front(30.2mm)/rear(25.4mm) sway bars, Sprint Booster, AFE Stage 1 Intake, Morimoto EvoX-R Headlights, Orion V4 Angel Eyes, Satin Black 18x9 ET42 APEX ARC-8 Wheel
330xi Mods:Front Koni Yellow Struts and Rob43 Rear 9 Way adjustable Rear Dampers,Custom Sport Springs,Supreme Power Drop Hats,ZHP 5 speed shift knob
Old 07-03-2013, 12:02 PM   #24
iRide113
My Ride: 2004 M3
In for epic video.
iRide113 is offline   Reply With Quote
Old 07-03-2013, 12:05 PM   #25
Zell
Zell's Avatar
My Ride: so turbo wow
You've got a lot to do...battery for starters, then drive it to the nearest shop if you even can and get all the fluids changed.
Old 07-03-2013, 12:09 PM   #26
awesomechinz
Then get your vroom vroom on and drive at WOT
Old 07-03-2013, 12:11 PM   #27
Patton323I
My Ride: R1100GS E46 E53
Re: How do i prep an e46 prior to starting it up after 9 years in storage?
In for results
Sent from talking rock device
Patton323I is offline   Reply With Quote
Old 07-03-2013, 12:16 PM   #28
Riverbmr3
My Ride: MB E350 & BMW 325i
check for spiders and snakes
Riverbmr3 is offline   Reply With Quote
Old 07-03-2013, 12:30 PM   #29
johngreaver
My Ride: 02 325i
One of the most important things I cant believe no one has mentioned is check all the wiring you can fine to make sure nothing has chewed it up and shorted it out. Starting a car with a bunch of gnarly wires can cause massive damage and potential fire.
johngreaver is offline   Reply With Quote
Old 07-03-2013, 01:46 PM   #30
jgold47
My Ride: 2004 X5 3.0
and brake flush/fill at a minimum. May even want to pull the calipers and disassemble them. Brake fluid absorbs water which corrodes the **** out of everything. If 5 spd, same with clutch lines. Those things could be corroded solid.
Religion, Politics, and which oil is the best to use. Three things never to be discussed in polite company...
my about me link
http://forum.e46fanatics.com/showthread.php?t=791566
jgold47 is offline   Reply With Quote
Old 07-03-2013, 02:30 PM   #31
My Ride: Lexus
Originally Posted by braymond141 View Post
I'd be far more concerned with the mold than the fluids. You'd be surprised how long all that stuff lasts.
Pull the fuel pump fuse and crank the engine over till oil pressure rises (after you've decided to flush it or not). After that you should be fine to start it.
This is the best tip in this thread. Personally I'd do this after changing the oil. Check coolant levels, run the ac, and of course monitor the cooling system temps. At some point, you'll put fresh gas into it. Take a video!!!
Old 07-03-2013, 03:07 PM   #32
BimmersGarage
My Ride: E46 330i
Start with a new serpentine belt!
But, in all honesty > Most if not all of the rubber O-rings & seals are weakened/deteriorated. I would be very considered. You got a lot of work ahead of you.
Need to drain ALL fluids and replace Before attempting to start it.
Sub'd for more pics & VIDEO : Time capsuled E46!
Please.. with double sugar on top.
BimmersGarage is offline   Reply With Quote
Old 07-03-2013, 03:14 PM   #33
My Ride: Lexus
Originally Posted by mce46 View Post
with cobwebs, molds and mildewly ...currently being detailed but with no attempts to starting...
just noticed the pic now. wow that thing needs to be attacked with steam. several passes. more pics please! was it sitting out in the sun??
Old 07-03-2013, 03:37 PM   #34
braymond141
My Ride: 96 M3, 02 M3, 01 M5
Unfortunately that car will be an asthmatics nightmare unless every bit of the interior was replaced. Been there done that with other cars. You cannot get rid of the mold; it will always linger.
braymond141 is offline   Reply With Quote
Old 07-03-2013, 03:43 PM   #35
My Ride: Lexus
Well that sucks. I would steam/shampoo the sh!t out of it then let it sit in the sun for a couple days with the windows down.
Old 07-03-2013, 04:11 PM   #36
aahmed2016
My Ride: 2003 330i ZSP/CP/PP
IN FOR VIDEO.
I love how Mango didn't mention anything about cooling system here, haha.
Spends $2000 on car DVD + stereo -> Running 25000 mile oil changes and 87 gas with blown shocks
aahmed2016 is offline   Reply With Quote
Old 07-03-2013, 04:13 PM   #37
My Ride: Lexus
Originally Posted by aahmed2016 View Post
IN FOR VIDEO.
I figure at this point, it's a given. If OP starts mentioning mods, filterz, intakez, stancing, popping, pants sagging, etc., then I'll bring up the cooling system.
Old 07-03-2013, 04:23 PM   #38
trizzuth
My Ride: 231k, 16yr old B3AST
In for vids of epic cold start!
trizzuth is offline   Reply With Quote
Old 07-03-2013, 04:31 PM   #39
Zell
Zell's Avatar
It's probably literally worth hiring someone to professionally clean the car, and then ozone it. Like no joke, I would definitely do that if my car got that gunky after sitting for so long.
Old 07-03-2013, 04:38 PM   #40
My Ride: Lexus
I think OP may have been in prison for 9 years.
