Old 07-03-2013, 04:48 AM   #1
BKz325xi
My Ride: 2001 325xi
Flickering head lights
Hi I just bought a 01 325xi. When I turn on the head lights they would not stay on . They would flicker...please help! It's my first BMW thanks!
BKz325xi is offline   Reply With Quote
Old 07-03-2013, 05:42 AM   #2
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Both of them flicker?
Old 07-03-2013, 05:47 AM   #3
BKz325xi
My Ride: 2001 325xi
Yes both
Old 07-03-2013, 06:45 AM   #4
BKz325xi
My Ride: 2001 325xi
Originally Posted by BKz325xi View Post
Yes both
Is there anyone in NYC that can help take a look??
Old 07-03-2013, 09:20 PM   #5
tomoyer
My Ride: 03 325xi, 01 325xi
Send a message via Yahoo to tomoyer
Quick thing to check, make sure that the bulb holders are correctly installed and seated completely in the headlight assembly as it is very easy to remove them to replace bulbs and not get them seated correctly. This will "break" the ground, and can cause the lights to flicker or not work at all and in extreme cases, the bulbs can melt the headlight area in which the bulb holder seats meaning that you would have to spring for NEW or USED headlight assemblies. Since the area is tight, it may well be easier for you to check this by partly removing the headlight assemblies so that you can get a better look.
tomoyer is offline   Reply With Quote
Old 07-04-2013, 03:50 AM   #6
Solidjake
Zero. Leaks.
Solidjake's Avatar
Another thing to look at are the rear tail lights. If the grounds are faulty there they can affect the headlights.
Old 07-04-2013, 09:24 AM   #7
BKz325xi
My Ride: 2001 325xi
Hmmm the previous owner had aftermarket led tails in the back. And one side is out.
Old 07-04-2013, 03:05 PM   #8
Solidjake
Zero. Leaks.
Solidjake's Avatar
Might possibly affect it. As stated, check for any wire damage going to the headlights from the harness.
Old 07-12-2013, 07:13 AM   #9
BKz325xi
My Ride: 2001 325xi
Ok I installed the stock tails back on n everything works fine. Headlight dint flicker nomore BUT when the headlights are off the sensors come in for the headlight n when u turn them on the sensor would go off... What I do!!!
