Old 07-05-2013, 08:30 PM   #1
jmb
My Ride: an old wagon
Removing paint from the bumper
Any recommendations for removing white paint from the front bumper of a blue E46? The PO got too close to another car messed up the bumper. I am planning to replace it with an MTech II bumper, but that won't happen for a few months. I have read a number of pages on the net about how to remove paint. Each one seems different and none appear to have worked well.
jmb is offline   Reply With Quote
Old 07-05-2013, 08:43 PM   #2
tock172
My Ride: '12 135i DCT
I would wash the entire car and then clay that area. Different methods using clay, polish and even some simple spray waxes can remove paint transfer.
Past: 1999 Techno Violet Metallic M3
Present: 2012 135i DCT Dinan S2
Old 07-05-2013, 10:26 PM   #3
saxual328ci
My Ride: 2004 325ci
I have something similar on my car. I'm not sure how it got there because its from the previous owner. Clay bar did not remove it. From what I was told, I'm probably gonna have to use a polishing compound or something that's not as abrasive as a simple compound.
saxual328ci is offline   Reply With Quote
Old 07-05-2013, 10:37 PM   #4
vermi1ion
My Ride: 99 323i
thinner will clean up any paint transfer, rinse clean, buff with compound and some polish. or pick up a 12 pack and hit your local body shop, should take them less than 5 minutes, always leave detail work to professionals!
vermi1ion is offline   Reply With Quote
Old 07-05-2013, 10:38 PM   #5
zabalzae
My Ride: 01 330ci
^^^+1
zabalzae is offline   Reply With Quote
Old 07-05-2013, 11:52 PM   #6
jmb
I got it off...most of it anyway. I tried a clay bar (Zaino Z-18) in that area when I detailed the entire car 2 weeks ago. At the time I was focused on the rest of the car and did not try too hard to fix this. This time after a hell of a lot of elbow grease with soap and water I was able to remove 90% of it. I followed it with the clay bar (which helped a little) and a round of wash/polish/buff. It is not perfect, but it is good enough for now and will stay that way until an MTech II takes its place.
Old 07-07-2013, 04:25 PM   #7
scrace
My Ride: 03.5 M3
A white terry cloth towel (nothing dyed) and non chlorinated brake cleaner. Rub gently. Due to how abrasive terry cloth is it will probably mar the surface a little bit so you may need to polish if you scrub.
2001 Topaz Blue 325Ci 64-120k miles SOLD
2003.5 Silver Gray M3 70k miles
scrace is offline   Reply With Quote
Old 11-17-2013, 11:29 AM   #8
SanAntonioMobil
My Ride: 2003 Benz C230 Komp
My trick is rubbing Auto Magic's No. 40 Multi-Purpose Solvent with a microfiber towel. It removed about half of the scuff on this example. To remove the rest of the ground in paint, I used Auto Magic's No. 77Basecoat/Clearcoat Cleaner with a microfiber towel. Works great for me.
Name:	67399_10151426610643834_616754114_n - Copy.jpg
ID:	535130   Click image for larger version
Name:	67420_10151426610603834_375377576_n - Copy.jpg
Martin Hernandez
San Antonio Mobile Detail
www.saMobileCarWash.com
SanAntonioMobil is offline   Reply With Quote
