Old 07-05-2013, 10:20 PM   #1
Blackbeamer00
My Ride: BMW 323i 2000
Nuetral to auto
Many of you know what im alking about that drives an automatic e46, you cannot throw from nuetral to drive on high RPMs. I would like to know is there any way i could remove that safety or get rid of it. Yes i know its bad for youre transmission and all that but i just want to know how to remove it. Help would be really apricciated thank you!
Blackbeamer00 is offline   Reply With Quote
Old 07-05-2013, 10:52 PM   #2
lszlszx
My Ride: 1.8T, XC70
There is a solenoid by the shifter, I'm sure it's possible to eliminate that function by disconnecting, or removing the solenoid.
I thought of it because I like to put the tranny in neutral as I wait at a stoplight and shift back to drive without pressing the brake.
However, I advise you against shifting to neutral while moving at a high rate of speed.
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 07-05-2013, 11:07 PM   #3
Guest021715
Account closed.
A 323i owner asking how to do a neutral drop.
Old 07-05-2013, 11:13 PM   #4
stevenluczynski
My Ride: Is Steel Blue
I'm just going to go out on a limb here and say Op is under 18 years old...
stevenluczynski is offline   Reply With Quote
Old 07-05-2013, 11:13 PM   #5
BeMyWhip
My Ride: 01 BMW 330ci
neutral drop at 8,000rpm... yeaaaaaaaaah boooooooy!!!
just do it!
Always Mod!!!
Founder: 330Ci The 3 litre coupe
BeMyWhip is offline   Reply With Quote
Old 07-05-2013, 11:14 PM   #6
dwtaylorpdx
My Ride: 2005 330xi
WHo makes the Auto in the E46 ? I swear I've seen it.. I thought they were a special unit from GM, if they share much with the new tech GM autos there might be some interesting hacks to be had by cross breeding...
Dave
dwtaylorpdx is offline   Reply With Quote
Old 07-06-2013, 01:55 AM   #7
Saintluk2
My Ride: 2000 323i sedan
rainbows
Last edited by Saintluk2; 07-10-2013 at 08:20 PM. Reason: op is not peeling out in his 323
Saintluk2 is offline   Reply With Quote
Old 07-06-2013, 02:11 AM   #8
CharlzO
My Ride: 2000 328ci
I'll admit though, there are times when I have been at a light, and either bumped it into neutral, or other times where I'd hit neutral, and hate having to hit the brakes just to get it to shift back into Drive. I always feel like a tool when there's someone behind me, and suddenly I have to light up the tails just to get moving again. recently, it was because I was fighting a seizing caliper so coming to lights, I would dtep it down all the way to first, then jump it to neutral so I didn't have to use the brakes. But then even just sitting there, having to hit the brake anyway to release it to shift back. Admittedly, very few and far between circumstances, but one of those "if only" times when it happened. (especially since I can be doing 60, pop it into neutral just fine, and back into drive, but can't do it sitting still, at idle, at a red light? lol)
CharlzO is offline   Reply With Quote
Old 07-06-2013, 08:53 AM   #9
Blackbeamer00
Well my mission isnt to nuetral drop. Just like every other automatic drive i like to put in in nuetral while at a stop light. It would be nice if someone can give me an actual how to do it instead of bitching about it.
Old 07-06-2013, 08:53 AM   #10
Blackbeamer00
Do you know how to do it or what i have to remove?
Old 07-06-2013, 09:09 AM   #11
jfoj
My Ride: 330CiC, M5, X5, E93
SMG launch control!
Old 07-06-2013, 09:55 PM   #12
lszlszx
My Ride: 1.8T, XC70
If you lift the shifter surround, you'll see the solenoid on the passenger side. The gearshift assembly needs to be removed to get to whatever is holding it. I disconnected it, it worked initially, but then the transmission light came on, the "electronic nannies" intervened.
If the solenoid is removed, but stays connected, the computer may be tricked into thinking it's working.
automatic, nuetral, transmission
