Sponsored by BimmerWorld
Old 07-06-2013, 10:56 AM   #1
Jat007
My Ride: 99' 323i
Is It possible to replace just the Outer Ball Joint?
Just found out that my front lower outer ball joint went bad. The PO had replaced the entire lower control arm assembly right before I bought the car, which is about 8 months ago. He must have bought some cheap control arms off Fleasbay or something like that... Anyways, is it possible to replace just the lower outer ball joint instead of the entire lower control arm? I see that some online places sells just the ball joint.
How much work would it be just replacing just the outer ball joint??
Thank you,
Jay
99' 323i e46
Jat007 is offline   Reply With Quote
Old 07-06-2013, 12:36 PM   #2
Tangent_
My Ride: '01 330i, '11 Z435i
Re: Is It possible to replace just the Outer Ball Joint?
On some aftermarket control arms like the Meyle HD you can replace the ball joints, but if what you have is like the OEM you can't; you have to replace the entire arm. If it is a cheap part like you suspect that might be a better idea anyway. Get yourself a pair of Meyle HD and know you have good parts.
http://forum.e46fanatics.com/signaturepics/sigpic70081_4.gif
Tangent_ is offline   Reply With Quote
Old 07-06-2013, 01:35 PM   #3
Jat007
My Ride: 99' 323i
Where can I buy a pair of Meyle HD at a reasonable price?
Thanks,
Jay
Old 07-06-2013, 03:54 PM   #4
TiALT6
My Ride: 2000 328Ci
Swiftmotorworks.com sells em for a good price.
TiALT6 is offline   Reply With Quote
Old 07-07-2013, 12:32 PM   #5
wasp9166
My Ride: 04 330i jet black
Send a message via Yahoo to wasp9166
Thanks,
Jay
bma parts
http://www.bmaparts.com/item.wws?sku...D&weight=17.69
add to cart, use spece30 code
"if polarity comes from protons, does morality come from morons?"
Originally Posted by russ330 View Post
"Mommy and Daddy are getting a divorce now because wasp9166 had to piitb with Mom."
wasp9166 is offline   Reply With Quote
Old 07-07-2013, 08:14 PM   #6
teamdfl
Slow in, slower out
My Ride: 325it
You can change just an outer ball joint in OE and aftermarket Meyle control arms. The hard part is pressing out the old one and pressing in the new one without removing the control arm from the car. Whacking a pickle fork in near the inner ball joint to yank the control arm can result in a torn boot requiring replacement. I have seen an E36 specific ball joint tool for removal/replacement on the car but not an E46 tool.
Mod the driver. Participate in your local BMWCCA autocross or driving school. Have you joined BMWCCA yet?
teamdfl is offline   Reply With Quote
Old 07-08-2013, 11:19 AM   #7
Jat007
My Ride: 99' 323i
Thank you and special thanks to wasp9166 for the link.
Jay
