///M3 Forum
Old 07-07-2013, 09:53 AM   #1
Dan04E46
My Ride: '04 S54B32 Coupe
DIY: Reinforcing Swaybar Bushing Mounting Points
So the other day, I heard a loud knocking while I was turning. As it turned out, I had somehow managed to rip my swaybar mounting studs straight out of the body's sheet metal on the passenger side. Check out the following pics.
What should look like this...
... looked like this.
Now apparently, after doing some research on the topic, it's happened on other E46 M3s and a lot on autocrossed Z4s. Solutions included welding on a new body section which BMW actually sells or reinforce the area and weld in new studs. The latter sounded more appealing so I found some flat bar I had lying around and proceeded to make a template of the flat area and of the through holes for the studs. I made the cuts and did a fit up over the existing studs on the other side.
Perfect! So in my case, I welded the heads of a couple bolts to the top of the plate, then welded that assembly over the area of failure, and finally painted the area. As for the second plate I made, I just painted it then sandwiched it in between the swaybar bushing bracket and the body to reinforce the area. Hopefully that'll do the trick.
Its a schitty looking weld (it's actually my first structural weld ever) so I'm glad you can't see it too well in the pic. Anyways, this could happen to anyone just like every other failure with these cars (rear subframe mounting tears, VANOS woes, etc.). I saved the template and can reproduce these reinforcement plates fairly easily if anyone is interested in a set. They can be welded or just used as an in-between plate. Stock studs are still long enough for proper thread engagement. Boom.
DAN WAS HERE
2001 330Ci= Sold :(
2004 M3 coupe= Mine! :D
Dan04E46 is offline   Reply With Quote
Old 07-07-2013, 10:07 AM   #2
Matty47
My Ride: 02 M3
That's good to know! Thanks for the info.
Matty47 is offline   Reply With Quote
Old 07-07-2013, 10:30 AM   #3
Dan04E46
Additionally, I was running Hotchkis swaybar kit set to medium stiffness when the failure happened. And its been about a month or so (~1k miles) since I did the diy. So far, so good.
DAN WAS HERE
2001 330Ci= Sold :(
Old 07-07-2013, 10:35 AM   #4
wilsel
My Ride: 05 AW M3 ZCP
Uh Oh.. I also have the hotchkis swaybar kit set to medium in the front. How long have you had the sways? Done any track days with it since adding the swaybars?
wilsel is offline   Reply With Quote
Old 07-07-2013, 10:46 AM   #5
Dan04E46
I had the swaybars on for over three years. Basically, from what I understand, the failure happens from years of torsion forces applied to the same area. Take for example a paperclip. You bend it once, no problem. But keep bending it on the same spot and it'll eventually break from being gradually weakened. Unfortunately the thickness of the sheet metal in the area has been compromised by design and engineering for cost. At least the failure happened with over 130k on the odo, so it did last quite a while before finally giving out.
DAN WAS HERE
2001 330Ci= Sold :(
Old 07-18-2013, 12:37 PM   #6
Dan04E46
So, is anybody interested in a these on the cheap if I made a couple sets?
Help support a fellow fanatic trying to help fellow fanatics!
DAN WAS HERE
2001 330Ci= Sold :(
Old 07-18-2013, 04:56 PM   #7
Moosecakes
My Ride: 02' SMG M3
I might be interested once I get some money together from my damn financial aid lol.. School is taking forever to finish my ****.. shoot me a pm for price
Moosecakes is offline   Reply With Quote
Old 08-02-2014, 05:50 PM   #8
DLag
My Ride: is slow.
Are you selling the plates? Mine just ripped out using the medium setting on hotchkis also
DLag is offline   Reply With Quote
