E46 Convertible
Old 07-07-2013, 04:02 PM   #1
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
Anyone Running The Magnaflow 16533 Cat-Back Exhaust ?
Like the title says, who is running a Magnaflow Cat-Back on their CONVERTIBLE Bimmer ?
Is there anything Different on the underside of a vert that makes things different from a coupe or sedan ?
Does the Magnaflow 16533 FIT on a Vert ?
Thanks.
SUMMIT POINT WV 1:24:229 SCCA
Old 07-08-2013, 12:01 PM   #2
Rob43
Rob43's Avatar
Anyone ?
Who knows some forum member that might have the Cat-Back exhaust on a vert ?
Old 01-29-2014, 11:29 PM   #3
shibblez
My Ride: 2004 325cic 5spd MT
i have the same question
shibblez is offline   Reply With Quote
Old 01-30-2014, 02:00 PM   #4
///Rome
My Ride: 2003 BMW M3 Vert
Just take it to a shop and have them make any modifications if it doesn't fit. There's no reason why it shouldn't though. Doing mine sometime in February. Or just buy a magnaflow muffler and straight pipe the res.
///Rome is offline   Reply With Quote
Old 01-30-2014, 06:50 PM   #5
johnrando
My Ride: '06 330 CIC ZHP
Officially they are not for verts, but I imagine they could be modified for it. Since you are doing it in Feb., please let us know exactly what the mods entailed. Thanks.
John '06 330 Cic ZHP
Southern California
ZHP, Cold Weather Pkg., Leather, Jet Black/Black/Black Cube, NAV
AA Tune, Sprint Booster, BMW Perf. Intake, Magnaflow Exhaust, Dinan STEP S/W & TB, TMS Pulleys, H&R Touring Cup Kit
BMW Perf. Strut Brace, Orion V2 Angel Eyes, No-holes License Plate, SMG Paddle Shift Mod, Besian VANOS, Gold DISA, Fan delete
Old 01-30-2014, 08:21 PM   #6
Dave
Moderator
Dave's Avatar
My Ride: 323,330,M3,M3,M3
There is no difference between convertible and coupe for engine/exhaust/suspension purposes. It'll fit.
Perhaps you think multi-million dollar ad campaigns make a beer taste better. Perhaps you're mouthing your words as you read this.
Dave is offline   Reply With Quote
Old 01-31-2014, 11:56 AM   #7
johnrando
Just so you know, their website says it's not for verts. Same with the UUC TSE3 (their website says not for verts too). But when I asked about the TSE3, they said it fits but you just had to adjust the spacing around some of the reinforcement bars. I'm guessing the Magnaflow is similar.
Southern California
Old 01-31-2014, 01:10 PM   #8
secono330ci
My Ride: 04' 330ci/15' A3 TDI
On the verts, there's a V-brace going from the diff to the sides of the body frame (under the side skirts) similar to the e46m3. I doubt it would fit considering the way the pipes slope down on the magnaflow near that area. Try test fitting it though.
Oh...and the "$300 here, $600 there" scenario will turn into "$3000 here, $6000 there". I've had an enourmous amount of labor put into my car. (Luckily the majority of it was done by myself) Also, I've spent over $5k on my tool set since I started my project. You've been warned...
secono330ci is offline   Reply With Quote
Old 01-31-2014, 03:47 PM   #9
58ceramicgreen
My Ride: 330Ci Convertible
I know its not a Magnaflow but I put a Dinan exhaust from a Coupe on my Convertible without any issues at all.
58ceramicgreen is offline   Reply With Quote
Old 02-02-2014, 01:40 PM   #10
secono330ci
The Dinan isn't a problem since it utilizes the stock 2" piping. The magnaflow on the other hand has twin 2.5" pipes which are much larger.
Old 02-23-2014, 12:17 AM   #11
devinruss
My Ride: e46 330ci
How many hp would this system boost?
devinruss is offline   Reply With Quote
Old 02-23-2014, 10:57 AM   #12
csa714
My Ride: 2004 330cic
I am curious as well - is it a sound thing or a HP thing....if HP what is the increase?
csa714 is offline   Reply With Quote
Old 02-23-2014, 01:06 PM   #13
///Rome
Its mostly a sound thing. Any hp increase isn't really noticeable.
Instagram: Rome_M3
Old 02-26-2014, 11:38 PM   #14
devinruss
My Ride: e46 330ci
What exactly is a vert?
Old 02-26-2014, 11:46 PM   #15
toekneepark
My Ride: Turbo IS300
Send a message via AIM to toekneepark
Convertible.
toekneepark is offline   Reply With Quote
Old 02-26-2014, 11:46 PM   #16
devinruss
My Ride: e46 330ci
Boy do I feel foolish
Old 03-11-2014, 10:44 AM   #17
johnrando
Any update on confirmation that Magnaflow can fit?
Southern California
Old 03-27-2014, 08:17 PM   #18
johnrando
Just checking in for an update.
Southern California
Old 03-28-2014, 10:35 PM   #19
Huss_tle
My Ride: E46 Vert m3
I have the top speed cat back exhaust all cat back typically look similar and it will fit. The Magna-flow I think have a muffler and the topspeed doesn't so I can't tell you about the sound. But defiantly check topspeed fitment is good sound is great.
Huss_tle is offline   Reply With Quote
Old 05-02-2014, 05:57 PM   #20
johnrando
The Magnaflow fits! Full cat-back exhaust.
Southern California
