Go Back   E46Fanatics > Other BMW Models > General BMW Model Discussion
All non E46 BMW model questions in here. Look below for E36, E90 and F30 specific forum. For additional model specific forums check out bimmerfest.com!
Old 07-08-2013, 02:32 PM   #1
zhenkaaaM3
My Ride: Fst'r then your e46
Car running with A/C
This is for an e36 m3.
I used A/C again today with no issues of overheating like last time. My next issue is that why does the car feel so sluggish?
It speeds up fine but when I am doing some city driving at 35mph at 3000 rpms and keep it at that, I am feeling some sluggish performance. Its as if that car is struggling to keep the car at 3000 rpms. I feel some slightly noticeable jerking. If I wasnt so anal with the car, I would not have picked up the jerking.
There are no codes. The car runs good without the A/C. I was thinking to have my A/C system professionally flushed out, cleaned out and refilled. I dont know if that would do anything to fix the issue. But I work at a dealership so I can take advantage of all the tools present.
Where to go from here?
Eugene
Former E36 M3 Owner + E46s
zhenkaaaM3 is offline   Reply With Quote
Old 07-08-2013, 03:34 PM   #2
jcns
My Ride: California
if you overheated the engine, you probably have some damage that may be causing the sluggishness you are noticing. Compression loss comes to mind and may not necessarily throw a code.
jcns is offline   Reply With Quote
Old 07-08-2013, 04:09 PM   #3
zhenkaaaM3
Re: Car running with A/C
I didnt overheat the engine. The temp moved a little past 12 o clock when a/c was on. I turned ac off and temp went back to 12 o clock
Sent from my SGH-T999 using BimmerApp mobile app
Eugene
