Sponsored by BAVSOUND
Old 07-08-2013, 03:32 PM   #1
hinds90
My Ride: E46
Need a little help
Okay I purchased a m3 and most of the wires for the amp connector have been cut. The big issue is a lot of the wires are the same color. I'm wondering would it be easier to up grade to aftermarket speakers and amp then run new wires or just try to match the wires back up for the connector
hinds90 is offline   Reply With Quote
Old 07-08-2013, 04:24 PM   #2
markusmarkus
My Ride: 2001 330Ci
Need a little help
I would search this and E 46fanatics forums for the color code. I installed a new amp last year and I can assure you that all of the wires are color-coded. Perhaps better light would help.
Old 07-08-2013, 04:33 PM   #3
hinds90
My Ride: E46
I can tell the colors problem is a lot of the wires are the same color.
Old 07-08-2013, 05:15 PM   #4
jeffb325@NavigationSolutions
J&T Distributing
My Ride: BMW
a lot of them may be the same color but they should have a stripe on them of different colors.... Unless you are looking at the wiring from something else that was not stock.
jeffb325@NavigationSolutions is offline   Reply With Quote
Old 07-08-2013, 05:45 PM   #5
hinds90
My Ride: E46
No its the factory wiring. If you look at the harness there are several wires the same color and strip.
What I'm dealing with. Just going to upgrade to aftermarket speakers and amp then run my own wires.
Old 07-08-2013, 10:59 PM   #6
esberelias
My Ride: '03 325i
I hope my factory HK amp never failed on me lol
Check out my ride
esberelias is offline   Reply With Quote
