Thread Tools Search this Thread Rating: Thread Rating: 143 votes, 4.69 average. Display Modes
Old 07-10-2013, 04:27 PM   #1
My Ride: 2016 Lexus
Exclamation So you want full reliability, huh? Reliability Super Suite (Part#s included!)
You want full reliability for your E46? Follow these tips. I realize some may think these are excessive but hey. You're the one who wants maximum reliability, right? Of course, nothing is absolute. But follow these tips to greatly improve your odds of reliability.
Of course you should follow all the other information in my thread for great performance, efficiency, and cooling.
Some of the information overlaps my other links, but if you want to concentrate on reliability, listen up!
Electrical and Ignition
This is by far the most important part of the list!
Battery, BMW part# 61218381749
If your battery is five years old or older, or you don't know - replace it. This will cost between $90 and $200. Try Autozone, Walmart, Costco, etc. Make sure the battery you purchase comes w/ a vent tube kit.
Voltage regulator, BMW part #s 12317559183 Square plug voltage regulator or 12317515319 Round/oval plug voltage regulator
You may suddenly get a battery light while driving down the road one day. It may flicker or stay on. Either way, your voltage regulator is toast. Expect to pay between $40 for a Bosch VR or $120 for a Valeo VR. You can also get a new alternator (remanufactured) which will have a rebuilt VR from alternatorpros.com. Those will run around $130. If you have a Valeo alternator, it makes sense to just replace the entire alternator. You will have to look with your eyes to see which voltage regulator you need.
Final Stage Resistor, part number 64116920365
Expect to pay about $55
Starter, manufacturer (Bosch) reman part number 70306010103
You can also try alternatorpros.com for a reman starter.
Expect to pay about $120
Key, part number 66126955748 (from 9/99)
Bring your registration and driver's license to the local BMW dealer. Order a new key. They've been known to fail and all the new parts in the world won't mean anything with a busted key. Plus a new one looks so nice. Expect to pay around $160-200.
Ignition coil spark plug boots, for Bosch coils part number 12131740477 or for Bremi coils: part number 12139067831
Ignition switch, part number 61326901961
These can sometimes go bad on BMWs. Intermittent electrical errors when you turn the key. Expect to pay about $67
Crankshaft Position Sensor, part number 12141709616
Expect to pay about $100
Camshaft Position Sensor (Intake), part number 12147539165
Camshaft Position Sensor (Exhaust), part number 12147518628
Fuel
Fuel pump, part number 16146766942
*Buy a universal clamp! A member recommended size 1/4-5/8"*
Expect to pay about $130
Fuel pump sealing ring, part number 16111184084
Expect to pay about $17
Fuel pump relay, part number 61368373700
Critical Vacuum
Crankcase vent system (complete)
You can buy them separately or as a kit. Your call. Make sure you buy ALL Genuine BMW. Do not skimp on this. Expect to pay $150.
Crankcase vent valve 11617501566
Vent pipe (attaches to valve cover) 11611432559
Vent pipe #2 (attaches to top of CCV valve) 11617504535
Vent pipe #3 (attaches to bottom of ccv and dipstick tube) 11157532649
Vacuum hose 11727545323 (attaches to side of ccv)
Vent pipe #4 11617504536
Manual cars/Clutch Hydraulics
Clutch line, part number 21526774267
Expect to pay about $50
Clutch master cylinder, part number 21526773670
Expect to pay about $50-100
Clutch slave cylinder, part number 21526785966
Grand total manual cars: $1,096-$1,306 (depending on where you shop)
Grand total automatic cars: $956-$1,156 (depending on where you shop)
Bonus:
DME compartment. Remove cover, clean/vacuum/condition seal w/ gummipflege. Inspect for any leaves, dirt, or debris or anything weird with the wires. Never know what previous owner junked up the wires doing teenager angel eye wiring! Make sure any splices or cuts are properly joined/repaired, well protected, and insulated.
General wiring Inspect all wiring harnesses and plugs for damage or exposure. Re-wrap any exposed wiring harnesses with new loom if the loom has broken off or disintegrated. Remove all sensors and clean with electrical contact cleaner then apply dielectric grease to the pins/contacts.
If you like this thread and/or if it has helped you: remember to rate it a full five stars by clicking on the rating stars on the upper right corner!!
Old 07-10-2013, 04:28 PM   #2
Nickvjr
My Ride: 2004 330Ci Conv.
Send a message via AIM to Nickvjr Send a message via Yahoo to Nickvjr
First! All joking aside sweet thread Mango and what a wealth of information. This is going to be something that will be referenced for years to come.
Thank you for sharing your knowledge and attention to detail with is! :0)
-Nickvjr
2004 BMW 330Ci Convertible
Nickvjr is offline   Reply With Quote
Old 07-10-2013, 04:38 PM   #3
My Ride: 2016 Lexus
No problem. Continuing to add to it and fix stuff.
Old 07-10-2013, 04:39 PM   #4
My Ride: 2016 Lexus
Ugh i forgot to add fuel. working on it now.
Old 07-10-2013, 04:49 PM   #5
Efekkt
My Ride: 02 330ci
I just got a key today and it cost $220+tax. I asked if they could do it for cheaper and they said no, hope that contributes.
Efekkt is offline   Reply With Quote
Old 07-10-2013, 04:51 PM   #6
trj
My Ride: 325Ci
Mango, great work.
Just adding something to the list, if someone bothers to type the part numbers and put a picture go ahead.
Edit: sharing screenshots of my excel worksheet of the repairs I did since September 2011 along with vendors and price(may vary now). Couldnt get to attach the excel sheet for some reason.
Name:	Screen Shot 2013-07-10 at 3.19.57 PM.png
Name:	Screen Shot 2013-07-10 at 3.20.31 PM.png
Name:	Screen Shot 2013-07-10 at 3.20.52 PM.png
Old 07-10-2013, 04:52 PM   #7
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Fuel filter you mean?
How about tossing in mention of cleaning stuff for icv/tb/maf/disa? Techron ftw
But, I think you got the biggies at least for the ordinary mileage e46's. I know I'll be coming into the period where I'll have things to get to behind the intake manifold that I didn't last time...like an idiot...the knock sensors, crank position sensor, vac hoses down there.
Anyway, kudos on another great thread!
Facebook.com/DMAXstandup
Mangofy your E46!
Old 07-10-2013, 04:52 PM   #8
My Ride: 2016 Lexus
Thanks. My key (won't say which dealer) was $149 + tax. I asked for a discount and I got one. Originally $191.
I told them I'm the Dark Knight of the E46 world. He goes "ok, in that case."
Old 07-10-2013, 07:20 PM   #9
trive2
My Ride: 1989 BMW 535i
In Australia, key costs $700. We rebuilt mine when I cooked it in the dryer.
trive2 is offline   Reply With Quote
Old 07-10-2013, 08:15 PM   #10
My Ride: 2016 Lexus
Thanks. And nope. Those things do not directly affect reliability. I am talking items directly responsible for starting and charging of the car and keeping the pistons firing so the vehicle can drive. That's why I said the other items are for efficiency and performance while this list starts the car.
Old 07-10-2013, 08:50 PM   #11
beasted86
My Ride: '02 BMW 325i
I was full on expecting this to be a rehashed cooling system overhaul nagging-to-death.
beasted86 is offline   Reply With Quote
Old 07-10-2013, 09:40 PM   #12
dmax
dmax's Avatar
Fair enough...then when you wrote 'fuel' you meant fuel. That probably would help a car start!
Fuel filters, though, will stop the car, I've heard, at 130K miles or so if it's never been changed...maybe sooner for some and later for others.
Mangofy your E46!
Old 07-10-2013, 10:05 PM   #13
johngreaver
My Ride: 02 325i
Yo mango I would like to see a DIY of how you get your engine compartment so clean. I clean mine my 11' ride doesn't look that good. the DME compartment pick made me sick it was so clean.
Pre 03 AUX IN DIY
"Also I seen a honda with an intercooler on the front that i wanted on my car. I know i dont have a turbo or supercharger ,but can I still but one on my car , I think it would atleast get me 10 or so hp."
johngreaver is offline   Reply With Quote
Old 07-10-2013, 10:19 PM   #14
My Ride: 2016 Lexus
Originally Posted by trj View Post
Mango, great work.
Attachment 515756
Attachment 515757
Attachment 515758
Thanks. While your list is great, it has nothing to do with reliability.
I don't make these threads for nothing.
This thread has an extremely specific purpose.
The parts listed are critical and likely to prevent a vehicle from starting or maintaining explosions within the cylinders (you know that thing an engine does when it runs) to keep the piles of meat in the interior (driver/passengers) moving to their intended destination.
Oh that's not my engine. I just pulled that pic randomly off the internet. I'd be embarrassed if that was my engine.
This is my engine:
Old 07-10-2013, 10:31 PM   #15
mjpgolf1
My Ride: 00 328i,05 745,03 X5
This is my engine:
Nice. By the way I got the parts you pointed out missing under my hood installed so I appreciate the constructive criticism.
Before
Now
Thanks again for the part numbers.
mjpgolf1 is offline   Reply With Quote
Old 07-10-2013, 10:34 PM   #16
My Ride: 2016 Lexus
lookin tidier my friend. what did you put in place of the left radiator mounting bolt?
Old 07-10-2013, 10:51 PM   #17
ed17331
My Ride: 2002 BMW 325i Sedan
In. Thx Mango.
ed17331 is offline   Reply With Quote
Old 07-10-2013, 10:57 PM   #18
mjpgolf1
Good eye. My local dealer didn't have the bolt in stock so I just put a rubber stopper in there until I get the bolt. I got everything installed and I had that one stupid bolt missing and it was driving me crazy so I put the stop in there until I get it. Unfortunately the closest BMW store is an hour away and I haven't been back up in the last week to get It. That partition in the back on the drivers side that was missing was a pain in the a$&. Once I started digging around in there I had to reroute a couple of the harnesses that whoever was in there before I bought the car didn't bother putting back in the proper place, like the one that routes over the engine and is clipped to the front of the cabin air filter assembly. It was tucked down behind the motor which is why you can't see it in the first pic. It turned into a bigger project than I expected however I am now glad I got in there and fixed what was out of place and missing. Also was able to do some cleaning down in spots that are usually hard to get to.
Old 07-10-2013, 11:12 PM   #19
My Ride: 2016 Lexus
^ nice good job. get it. it's important because it holds the radiator down.
Old 07-10-2013, 11:21 PM   #20
mjpgolf1
I will be picking it up this weekend for sure. It never ends man. Lol. There is always something to do. Thanks again.
