Old 07-11-2013, 02:13 PM   #1
Stevo77101
My Ride: 2000 328i
Cold air intake and the mass air flow sensor
So Im wanting to install a CAI and I'm confused on the mass air flow sensor. Do I need to buy one that fit the CAI, or will the CAI come with an adapter of some sort? By the way it's a 2000 328i
Stevo77101 is offline   Reply With Quote
Old 07-11-2013, 02:26 PM   #2
LeMansteve
My Ride: '04 330i 6mt ZSP ZPP
Your car already has a cold air intake.
Old 07-11-2013, 02:37 PM   #3
TopasE46
My Ride: 2001 325Ci
Re: Cold air intake and the mass air flow sensor
There should be a silicone boot that adapts the Maf sensor to the new intake tube.
TopasE46 is offline   Reply With Quote
Old 07-11-2013, 04:36 PM   #4
YYCZHP
My Ride: 2005 330ci zhp
This is gunna sound counter intuitive but completely disregard the MAF and install the intake how you thing you would. WAY simpler than you think. If you really want to understand what is what starting at the front you have your intake scoop behind the grill -> intake box -> intake boot with MAF -> lower intake boot -> intake manifold. Basically after your intake box there is a tube with a lip and a wire going off of it. The wire is your MAF and your new intake bolts onto the lip closer to the front of the car.
YYCZHP is offline   Reply With Quote
Old 07-11-2013, 05:58 PM   #5
LeMansteve
If it's a CAI that was designed to fit properly, it should come with an adapter or fit right onto the MAF. It should also come with proper installation instructions.
Note that you are basically wasting your time installing a CAI - unless you just want that cool induction sound and/or bling under the hood. Power gains are extremely small, if any. Also know that more air = more crap accumulating onto your MAF sensor = early MAF failure.
