///M3 Forum
Old 07-11-2013, 05:24 PM   #1
Laguna01///M3
OG PapaSmurf
Laguna01///M3's Avatar
My Ride: Grigio Medio E46 M3
Rear ST coilovers spring crooked?
Anyone elses spring look like this installed. Only a few thousand miles on them, their not broke, and installed correctly. Lately tire has been rubbing the quarter alot on one side. Thought the shock may have went, but its good.
Took this pick with the car on the ground.. Im not an expert, but it doesnt look right to me... Anyone else? Spring can only go in one way. Its not upside down, and its aligned with the upper, and lower nipple.
Instagram@WBucco
Laguna01///M3 is offline   Reply With Quote
Old 07-11-2013, 05:39 PM   #2
tinman831
My Ride: M3
Who installed them? They shouldn't be compressed like that so all the coils are touching.
tinman831 is offline   Reply With Quote
Old 07-11-2013, 05:42 PM   #3
ModBargains III
ModBargains III's Avatar
My Ride: E46
I had that happen to a customer, it's the wrong spring that was put into a kit. Contact whoever you bought it from or KW/ST, they'll swap out the springs for you.
Sean S. | Sean@ModBargains.com |(714) 582-3330 ext 8009
We Specialize In: BMW Brakes | BMW Suspension | BMW Parts | BMW Exhaust Experts |
BMW Wheels In Stock | BMW Intake Experts
Hours
Check out our Blog for updates & discounts!
ModBargains III is offline   Reply With Quote
Old 07-11-2013, 05:53 PM   #4
Laguna01///M3
OG PapaSmurf
A friend,a dn i who have both done these numerous times without issues. Thats whats puzzleing,,,
The spring can only be installed a certain way. Cant really mess it up.. And the adjuster has plenty of room still. Doesnt make sense..
Instagram@WBucco
Old 07-11-2013, 05:54 PM   #5
Laguna01///M3
OG PapaSmurf
Really!? Oh thats gonna be a pain in the ass...
Instagram@WBucco
Old 07-11-2013, 06:04 PM   #6
Laguna01///M3
OG PapaSmurf
Any way to tell if this is the correct spring?
These are the only numbers on it.
Instagram@WBucco
Old 07-11-2013, 08:19 PM   #7
joeysm3
My Ride: ///M3 02
Re: Rear ST coilovers spring crooked?
I have st's have them installed the same way... But i do not remember the numbering on the springs.
joeysm3 is offline   Reply With Quote
Old 07-11-2013, 08:30 PM   #8
Laguna01///M3
OG PapaSmurf
Emailed ST. Apparently this spring is for a non-M, bu they didnt tell me what to do about it..lol
Id assume its the same spring just different rate
Instagram@WBucco
Old 07-11-2013, 09:22 PM   #9
helmutm3
My Ride: 04 m3
Its not the same spring. What do you mean they didnt tell you what to do about it ? Did you place an order for non M springs ?
helmutm3 is offline   Reply With Quote
Old 07-11-2013, 09:29 PM   #10
Laguna01///M3
OG PapaSmurf
No this was a complete Coilover kit for E46 M3. Someone screwed up, and put non M spec rear springs in the box. Their response to my initial email said nothing about them replcing it. They just informed me it was the wrong spring.
I replied, and waiting for a response.
Instagram@WBucco
Old 07-11-2013, 09:54 PM   #11
helmutm3
My Ride: 04 m3
Well then they have to replace it.
Old 07-16-2013, 02:49 PM   #12
itscoo2pyopants
My Ride: E53 4.8is
Send a message via AIM to itscoo2pyopants
at least the rears are pretty easy to replace. hopefully they'll take care of you
itscoo2pyopants is offline   Reply With Quote
Old 07-16-2013, 02:52 PM   #13
Laguna01///M3
OG PapaSmurf
ST says that is the correct spring, and that is how it sits...
Talked to a few other guys, ang their springs sit the same. so I have no clue why my car is acting the way it is. The height is the same on both sides, nothing has changed, and im getting rubbing from the drivers rear out of nowhere..: banghead:
http://www.m3forum.net/m3forum/showthread.php?t=375086
Instagram@WBucco
Old 07-16-2013, 03:00 PM   #14
joeysm3
My Ride: ///M3 02
Mine does not sit like that at all
Sent from my SGH-T999 using BimmerApp mobile app
Old 07-16-2013, 03:30 PM   #15
tinman831
My Ride: M3
Did you buy it through ST or a vendor? I'd have a talk with the vendor if you got it through them and have them sort it out.
Old 07-16-2013, 04:46 PM   #16
Laguna01///M3
OG PapaSmurf
How is your sitting. Few people ive spoke to said theirs sits the same.
Instagram@WBucco
Old 07-16-2013, 04:48 PM   #17
Laguna01///M3
OG PapaSmurf
Vendor, but i dont know what im supposed tomtell them is wrong, if ST direct ismtelling me it's right.
Car rode fine with thismsetup for over 4k miles. Than one day the driver side rear seems to be traveling too much as the tire is rubbing on sweeping right turns, and most bumps..
Instagram@WBucco
Old 07-16-2013, 08:46 PM   #18
helmutm3
My Ride: 04 m3
I taught they told you its a spring for a non M. Sucks to have the runaround, man.
Old 07-17-2013, 08:32 AM   #19
Laguna01///M3
OG PapaSmurf
They did, than they emailed me back confirming the PN "2003" is the correct spring. I checked the install manual, and that too says it's the "2003" spring.
I'm going to try swapping the rear shocks, see if that helps. Don't know what else could be going on back there. Shock doesnt show any fluid leak, but does seem to rebound slooow. Maybe it's on it's way out?
http://s1240.photobucket.com/albums/...ps6cf5b195.mp4
Instagram@WBucco
Old 07-17-2013, 01:51 PM   #20
helmutm3
My Ride: 04 m3
I dont know man. In my opinion there is no way that spring coils should be touching. That has nothing to do with the shock rebound. I never considered buying ST but if their design includes touching coils (again I really doubt that) then now there would be real reason not to buy them. I dont have them so cannot really say for sure if thats how they are. Just saying I wouldnt like it.
