Old 07-12-2013, 06:33 AM   #1
bjzwart
My Ride: 330cD
Port matching of cast iron 330d manifold to cylinder head?
I'm currently in the process of upgrading my 330cd of 2003. Since it's got the stainless steel crappy manifold, I'm going to swap to a cast iron manifold when I'm installing my new hybrid turbo.
The apperture in the manifold connecting to the turbo is easy to grind to shape when the new turbo is on the bench and can be measured with callipers etc.
However, I've bought new exhaust manifold seals (between cylinder head and manifold) and the opening is much bigger than the ports of the manifold. Does anybody know how the exhaust seals match with the exhaust ports of the cylinder head? Are these ports much smaller than the seal, just like the manifold? If not, I guess there's much to gain when the cast iron is grinded away so the flow will be more smooth.
Has anybody got pictures of the exhaust ports of the M57 or M47 engine with an exhaust seal held in front of it? Or maybe anybody with a pair of callipers and unassembled manifold that could measure the max height and width of the port?
Any help would be appreciated. My car's still assembled and I use it everyday, so I would like to prepare everything and change all in one weekend.
bjzwart is offline   Reply With Quote
Old 07-12-2013, 01:54 PM   #2
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
Port Match It.
Port matching is critical for optimum performance, it can't be overlooked. If your exhaust manifold has smaller ports than your cylinder head, the exhaust manifold needs to be opened up. I'd cut into it between a 1/2" to 1" (12.7mm to 25.4mm) in depth, the deeper the better. Meaning, cutting into each port of your exhaust manifold up to 25.4mm deep.
In a perfect world you'd like the exhaust manifold ports to be slightly larger than the cylinder head ports. If you have enough material on the exhaust manifold to do this, I would.
Good luck.
SUMMIT POINT WV 1:24:229 SCCA
Old 09-14-2013, 08:50 AM   #3
Ultracharger
My Ride: 330D -04 & 745iA E23
Why not get someone who can make a proper manifold for you? The stock manifolds are not made for especially good flow.
Ultracharger is offline   Reply With Quote
Old 10-04-2013, 05:44 AM   #4
andersDK
My Ride: E46 330d touring
There is no room for a proper manifold.
andersDK is offline   Reply With Quote
Old 10-05-2013, 10:58 AM   #5
bjzwart
My Ride: 330cD
I've measured the standard opening in the cylinder head and checked against the opening in the cast manifold. They match up pretty well. The manifold ports are a little larger actually. All I did is cleaned up the inside of rough surface and restrictions at the locations where the bolts are:Click image for larger version
When I take off the old staiess steel manifold, I'll try and make a tubular similar length system. It'll be a tight fit but interesting to do!
Old 10-12-2013, 12:27 PM   #6
Ultracharger
Smile
It's tight in there but I recon one could build a compact manifold with better flow than stock and set the turbocharger a bit forward in the engine compartment where there is a little more room.
If I decide to keep my 330d and tune it more I will make a custom intake manifold as well and change to the 535d injectors + walbro fuelpump thus making 400+hp possible with my setup.
Old 10-16-2013, 04:54 PM   #7
bjzwart
My Ride: 330cD
Sounds interesting! What ideas do you have regarding the inlet manifold and why change it? Do you think it will improve flow?
In contrary to what people say, I found that the standard exhaust is pretty restrictive. With an open 2,5 inch system there's quite a noticable improvement. Next is changing the downpipe from 2.25 inch to 3. Will also help a bit since gas temperatures there are still high, so need more volume than at the back of the exhaust.
Old 10-17-2013, 03:39 PM   #8
Ultracharger
First of all I think that the stock intake manifold can be greatly improved in flow. Also it can't handle high boost pressure because it can split in two (plastic). Mine boosts about 1.6Bar ~ 23psi ish. That's just above stock but with greatly improved flow due to big intercooler, egr delete, swirlflap delete (a must) and larger diameter pressure pipes. With a manifold in metal it would be possible to boost much more and with greater efficency.
Changing the downpipe (also deleting the dpf if you have one) greatly improves turbo spool up. Difference is big even on a stock car. I have a 3" system from turbo. One muffler. Works fine and sounds nice.
