Old 07-12-2013, 02:39 PM   #1
jamex
My Ride: 2005 325Ci
Exclamation Innovate LC-1 and Gauge mounting options
Going to place the order for my LC-1 soon and thinking I might go ahead and order the gauge with it even if I don't end up using it full-time. After checking out more pics of the gauge it looks like it needs to be surface mounted or a case of some sort would need to be made for it as its just an open back with wires coming out it.
Anyone actively using their gauge and have pics of how where they mounted it? Is AFR even useful to know on non-boosted cars?
Or should I just skip the gauge as I'll probably never use it after the initial install and testing? I see there's an LC-1 that comes with NO sensor. Can you use one of your existing O2 sensors with it?
jamex is offline   Reply With Quote
Old 07-12-2013, 10:15 PM   #2
F1004fun
My Ride: '02 330Ci
Though the gauge would be nice, one thing to think about on a street car is that the gauge will constantly be swinging back and forth a bit. This is due to the nature of narrow our narrow band oxygen sensors and engine management.
F1004fun is offline   Reply With Quote
Old 07-12-2013, 11:42 PM   #3
jamex
My Ride: 2005 325Ci
Appreciate your input especially since you pioneered this solution here or at least brought the most attention to it. I read a post where someone regretted not getting the gauge but didnt go into detail why. I think it only adds maybe $15 to the lc-1 package so it's a cheap gamble as far as whether I'll use it or not. Wasn't sure if more people were actually using the gauge or not.
What about using existing o2 sensors? Can I skip the gauge and the sensorand just get the LC-1 and plug my own o2 into it or are they different from the Bosch sensor included in the kit?
Old 07-14-2013, 10:45 PM   #4
F1004fun
My Ride: '02 330Ci
Their different, the LC-1 uses wide band.
Old 07-14-2013, 10:57 PM   #5
mkodama
mkodama's Avatar
I used my LC-1 with the Innovate Auto Timer. It's a pretty nifty device that does a lot of things in an extremely small package (3"x1.25"x0.5"). I didn't bother with the turbo timer function since my car doesn't have a turbo, but the voltage readout and air-fuel ratio are pretty neat features to have. The unit is so small I just mounted it in my ash tray so I can hide it when not in use, but this was my 190E and not my E46, so not sure if it'll fit in the E46's ash tray.
Just as useful as on a turbocharged car as naturally aspirated. It's not necessary with a stock E46 though since the ECU will detect a problem before you even notice something with the AFR gauge.
