E46 Xi Forum
Old 07-13-2013, 07:19 PM   #1
vman88888
My Ride: 01 LSB M3 / 01 330Ci
very annoying belt squeal/squeak
when i start up my 01 330xi on a cold start it doesn't usually immediately start to squeak right then, but after about 1-3 mins of driving i get an awful sounding squeal form the belt that can be heard in china.
i have tried belt dressing spray with no success i am hoping that someone out there has manage to resolve an issue such as this because im seriously getting really annoyed with it
i have done a little research and have found that it might be the idler pulley or belt tensioner(also the belt is relatively new but the squeaking didnt start immediately after it was put on so i sorta ruled that out) also the belt seems quite snug but not too tight so i think its all good there correct me if im wrong
i did replace the alternator with a 120amp that i have noticed has slightly larger pulley than the original 90amp but i just dont want to jump to conclusions and start buying a bunch of stuff i might not need
plz help!
thanks in advance
vman88888 is offline   Reply With Quote
Old 07-14-2013, 09:42 AM   #2
Foxtrot_Uniform
My Ride: 325Xi
I would replace the idler pulleys. They can squeal upon startup and then quiet down over time. They are going bad and you don't want them to fail 100% when you are on the road! I would replace the belts too since you have sprayed them down with belt dressing. This is an easy job!
Foxtrot_Uniform is offline   Reply With Quote
Old 07-14-2013, 08:06 PM   #3
vman88888
how many idler pulleys are there? and is it an easy diy job or hard? also the belt tensioner is that a hard job as well?
Old 07-14-2013, 11:06 PM   #4
Foxtrot_Uniform
My Ride: 325Xi
There are 3 total... Two tensioners (one for the main belt and one for the AC) and one idler. It is an easy DIY and there are several posted here and on Google.
Old 07-14-2013, 11:53 PM   #5
e46alfonso
My Ride: 330xi MT, mustang gt
15-20 min if you know what you're doing.
Old 07-15-2013, 02:09 PM   #6
vandentr
My Ride: 2004 325xi Auto
Chirping?
FYI, my 325xi would start "chirping" after it got warm and it wound up being the tensioner bearing (NOT the pully) for the power steering/alternator/waterpump belt loop. The spring-loaded pivot bearing had basically dried up and began complaining at annoying levels when idling.
For reference, it was this tensioner:
vandentr is offline   Reply With Quote
Old 07-15-2013, 02:25 PM   #7
2002topasblueM3
My Ride: 2002 M3
I had an 01 330i and had a similar issue. Except mine was the fan belt pulley and the actual bolt was bent so the pulley started to wobble, and that's what was making the noise. As long as you hear the noise you have time to fix it.... It's when the noise stops you gotta start worrying cuz then your engine overheats lol at least that's what almost happened to me. I was about 2 seconds from warping my head gasket, thank god I shut the car off before that happened
2002topasblueM3 is offline   Reply With Quote
Old 07-15-2013, 06:42 PM   #8
vman88888
i just asked my uncle who has a 2002 330ci about it and he said he had the same thing with his car and at a certain angle you can spray wd40 behind the tensioner pulley and it went away he said he did that maybe 3-4 times then it never came back
(im assuming the pivot bearing had dried just as vandentr said and the wd40 is starting to bring it back to life)
so unless this comes back, the problem seems to be solved thankfully
Old 07-26-2013, 07:15 PM   #9
vandentr
For the record, I tried that with a variety of lubricating sprays and nothing worked.
After a while my patience ultimately ran out and it just wasn't worth messing with anymore...
