Go Back   E46Fanatics > Other BMW Models > General BMW Model Discussion
All non E46 BMW model questions in here. Look below for E36, E90 and F30 specific forum. For additional model specific forums check out bimmerfest.com!
Old 07-14-2013, 12:24 PM   #1
220k330
My Ride: 2001 330ci ZSP
91 525i question, M50 motor seized
Yea yea...I know this is out of place but you guys have always been on the money! So I bought a 91 525i today that had been sitting for 5 to 7 years, I can get the crank to turn....bought her from an older lady,
220k330 is offline   Reply With Quote
Old 07-14-2013, 01:01 PM   #2
dirty vert
My Ride: 2001 330ci
Put diesel into the cylinders and let it set. Without the plugs in, and try and turn it after it sits a while. If it still doesn't turn, you might have to remove the oil pan and look for a broken conn rod.
dirty vert is offline   Reply With Quote
Old 07-14-2013, 01:02 PM   #3
dirty vert
My Ride: 2001 330ci
Worst case is you are out about a grand for another engine....assuming you do it yourself.
Old 07-14-2013, 01:05 PM   #4
220k330
Oh she's not worth a motor....how long should it soak?
Old 07-14-2013, 02:01 PM   #5
jdstrickland
My Ride: '94 325iC & '00 323i
I'm confused. You bought a 5 Series that's not worth the price of a new motor? That does not make sense.
Old 07-14-2013, 02:03 PM   #6
220k330
Would you put an engine in a 91 525?
Old 07-14-2013, 02:04 PM   #7
220k330
I'm soaking it in marvel oil as we speak
Old 07-14-2013, 03:52 PM   #8
220k330
update guys: pulled the plugs and they looked awful. cleaned them up
Old 07-14-2013, 04:09 PM   #9
dirty vert
My Ride: 2001 330ci
If there is water, that would be a cracked block or head.... engine time. If you don't want to put the $$ into it, part it out or sell it whole.
Old 07-14-2013, 04:11 PM   #10
dirty vert
My Ride: 2001 330ci
As far as diesel sitting in the cylinders, 30-to an hour to help break down the oils and gunk.. but it won't help a cracked head or block.
Old 07-14-2013, 04:16 PM   #11
220k330
Yea but the water was outside of the plug....
Old 07-14-2013, 04:26 PM   #12
dirty vert
My Ride: 2001 330ci
Well, that is a good sign. With the plugs removed have you tried to turn over the engine by hand?
Old 07-14-2013, 05:58 PM   #13
220k330
im bout to check that
Old 07-14-2013, 06:50 PM   #14
220k330
got it! starter is screwed though...ughhhhhhhhhhhhhh
