Closed Thread
Old 08-16-2013, 05:26 AM   #21
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
Custom tubular bottom mount turbo manifold being fabricated?
Eye candy for someone like me!
PEI330Ci is offline
Old 08-19-2013, 09:01 AM   #22
MisterM
My Ride: 03 M3
Originally Posted by Radium View Post
We tested our injector pulse dampers in E98 (98% ethanol) alcohol fuel, unleaded gasoline and leaded race gas. These are OEM fuel dampers and have performed very well.
Does the pulse damper impact the gauge at the end of the rail?
I ran the rail without the damper for a few weeks and have since added the pulse damper over the weekend. Now the gauge readings are definitely lower at idle.
No leaks. Runs fine.
Thoughts?
MisterM is offline
Old 08-19-2013, 11:29 AM   #23
Radium
Past Site Sponsor
My Ride: RadiumAuto.com
No. The BMW S54 M3 engine utilizes a 5 BAR (72.5psi) fuel pressure regulator and is vacuum referenced. At idle you should see 60-64psi of fuel pressure (depending on coolant temp which dictates idle speed thus determines vacuum).
Radium is offline
Old 08-19-2013, 07:05 PM   #24
02PRUV
My Ride: E46 M3 Turbo
The DME also adjusts voltage to the fuel pump as well.
Rides:
BMW E46 M3 Turbo 570rwhp @18psi (old setup)
BMW E46 M3 LSX 427ci 800hp N/A
Ultima GTR LSX 440ci 800hp N/A
VY SS Ute Turbo 1004.6rwhp @ 28psi E85
Ford Escort Mk2 2JZGTE 600rwhp @14 psi
04 Yamaha R1 154.3rwhp
ISUZU FZR550 tilt tray (GT35 Turbo)
02PRUV is offline
Old 08-19-2013, 07:25 PM   #25
Commanderwiggin
My Ride: 900rwhp Turbo M3
Yup, see page 33 for more details:
http://www.unofficialbmw.com/images/...lectronic2.pdf
900+RWHP, PT6870 w/ Custom FSR Turbo Kit, AEM Infinity, Lab22 Motor
Commanderwiggin is offline
Old 08-20-2013, 09:19 AM   #26
MisterM
My Ride: 03 M3
Originally Posted by Commanderwiggin View Post
Thanks Kenton. That document explains the discrepancy. I may have been comparing a stone-cold idle to a warmed up idle on the gauge.
To all of those on the fence - it is awful nice to have this dedicated pressure gauge on the fuel rail with a modified S54. Its a nice looking gauge that compliments the engine bay as well - not easy to do in the aftermarket world.
MisterM is offline
Old 08-31-2013, 12:23 PM   #27
Radium
Past Site Sponsor
NOTE: The RADIUM 0-100psi (0-6.9Bar) Fuel Pressure Gauge is silicone filled to dampen injector pulsations and to protect the acrylic lens from excessive vibrations.
Radium is offline
Old 11-04-2013, 12:53 PM   #28
Tiago
My Ride: M3 e46
The Walbro 255 would likely suffice but it would be running on the edge at that power level. If you want a quieter pump, use the Walbro 400 gas pump.
Just when i was ready to make a order i found this:
This Walbro 400 LPH Fuel Pump is a universal intank high flow, high pressure fuel pump which can be used in many applications.
Important information for the Walbro F90000262 fuel pump:
Designed for engines with more than 500hp
Award-winning OE technology
High-pressure, high-flow performance
Outperforms all current market in-tank fuel pumps
Requirements for installation:
Modification to wiring, fuel lines and fuel module
Upgraded Aftermarket Fuel Pressure Regulator
Larger Fuel Supply and Return Lines
14 Gauge or Larger Electrical Wiring
15 Amp Fuse, 20-25 Amp Recommended
Professional Installation Recommended
NOT endorsed by Walbro for use in E85 fuel
Failure to follow the above noted suggestions while using this pump in a stock factory fuel system will cause severe drivability issues and could lead to damage of the vehicles fuel system
Do i need to worry about? Stock system has 5bar FPR. My car has 3.5bar FPR that came with ESS VT2-550 kit.
ESS VT2-575 / AEM WMI / Supersprint Race System / 3.91 Diff / Stoptech ST60 and ST40 / Bilstein PSS9 / UUC Sways
CLICK HERE FOR PICS OF MY CAR
Tiago is offline
Old 11-04-2013, 01:03 PM   #29
quick108
My Ride: BMW
LAB22 had Dallas Berry's M3 (when stock) running the higher flowing Walbro 416LPH using the BMW wiring, plumbing, and FPR at OEM fuel pressure.
quick108 is offline
Old 11-04-2013, 04:53 PM   #30
Tiago
My Ride: M3 e46
Do you know if he had any issues with that setup? How many miles did he made?
Tiago is offline
Old 11-04-2013, 05:40 PM   #31
dallasberry
My Ride: ///M3
As far as I know it ran great! I never drove the car after the catch can was installed before we boosted it so I can't really say how it did. I am currently running the Walbro 400 E85/Flexfuel setup in my surge tank and all it's still all the oem lines. I'm in the process of upgrading all of the lines for more powa!
Custom Turbo Build By Lab22
815whp @ 625wtq 27psi E98
dallasberry is offline
Old 11-04-2013, 06:40 PM   #32
Tiago
My Ride: M3 e46
You are convincing me to go forward but i will wait a feedback from radium before making any move.
Tiago is offline
Old 11-04-2013, 07:38 PM   #33
dallasberry
My Ride: ///M3
I wouldn't worry too much. Radiums products are very well engineered.
Old 11-05-2013, 06:09 AM   #34
Tiago
My Ride: M3 e46
I dont doubt from radium products quality. But you dont buy just because is good. You have to make sure that it will work on your car with the parts that you have on mind to achieve an overall goal. In my case i want to upgrade the worn oem parts to accomplish the ess vt2-550 kit without going beyond what ess develop for this kit, specialy to a point where it need a custom tune. I want to have a solid kit but with all the support from ess if anything goes wrong in the future.
Tiago is offline
Old 11-05-2013, 10:05 AM   #35
quick108
My Ride: BMW
FYI: The WALBRO 400 (Ti Automotive pump) is what BMW used in the Z4 (S54 Engine).
quick108 is offline
Old 11-05-2013, 01:24 PM   #36
Tiago
My Ride: M3 e46
So the Z4M has a better fuel pump than the M3... Good to hear that.
Tiago is offline
Old 03-10-2014, 01:13 PM   #37
MisterM
My Ride: 03 M3
Radium goodies on an N/A build
I have the full suite of Radium gear on my N/A S54 and love it (OCC, Rail/damper/gauge, Fuel pump kit).
-The FP gauge is invaluable for troubleshooting vacuum or fueling issues.
-The ethanol pump/sleeve setup has worked flawlessly as we've tuned for E85 (up to e60 currently).
-The OCC has kept my throttle bodies and CSL aribox filter sparkling clean since install. Intake charges must be cleaner as well.
Don't sell yourself short N/A S54's, Radium's gear is not just for the snail and hairdryer fed S54's.
MisterM is offline
Old 03-15-2014, 02:24 PM   #38
lrinco01
My Ride: 01 Turbo M3, 10 'X5M
Send a message via Yahoo to lrinco01
I Too am Convinced.
Going with all of Radium Goodies for the E46 M3 also (OCC, Fuel pump Install kit, FST, Performance Fuel Rail w/guage & Dampener) mated with two Walbro 400e pumps i will get separately (one in-tank, one in the Surge tank kit )
Leonel Aka " Rico"
BMWCCA # 403748
01 BMW E46 M3 / 6 SPD / Tiag / Imola
HPF Turbo....
Custom Built S54
Flex fuel
8XX rwhp
FOR SALE:
http://www.m3post.com/forums/showthread.php?t=727953
Custom Silver CF 6Speed E46 M3 sport steering wheel
http://forum.e46fanatics.com/showthread.php?t=1051908
lrinco01 is offline
Old 03-18-2014, 11:05 AM   #39
tikamak
My Ride: Z4M Roadster
Where did you get this information ?
tikamak is offline
Old 03-20-2014, 10:24 PM   #40
quick108
My Ride: BMW
Ironically I just saw one come out of an M Coupe last week. I originally witnessed this pump in a different M Coupe 3 years ago.
quick108 is offline
Closed Thread
