///M3 Forum
Old 07-16-2013, 02:49 PM   #1
BrandXTC
My Ride: 2002 E46 M3
Cool My take on a side grill badge (interested?)
Hey guys, as some of you may be aware, my side badges look like they got in a fight with a maple tree. (thick sappy glue covers my emblems)
I am a product engineer by trade, and I came up with an idea for a new badge.
Basically it is a laser cut front plate, backed by a brushed stainless back plate, the back plate has vinyl (outdoor? chrome?) stripes to fill the empty space.
Also, I took some artistic license with the 3 as frankly, I never liked the floating 3 that was there. (I know BMW pisses perfection, however... )
I have a laser cutter making me samples now, once I have them, I'll show some actual examples.
Is there any interest in this? Should I do a short production run? I'll sell them at cost here. If there is dramatic interest, I may get with some distributors and see if they want to sell them.
ID:	516760   Click image for larger version
BrandXTC is offline   Reply With Quote
Old 07-16-2013, 03:27 PM   #2
Firstboost
My Ride: 2006 Tiag ZCP
To be perfectly honest, I feel that too much dirt/grime would build up in the corners of that design. Unless it was super easy to pop the entire housing of the emblem off, remove the back plate, and clean JUST the plastic portion, it might work, but that's a lot of work to clean them.
Just my .02, but it's cool that you're trying to find a good alrternative.
Firstboost is offline   Reply With Quote
Old 07-16-2013, 03:39 PM   #3
Marshmallow
My Ride: Ehhh...
^^ Perhaps is they were coated in a dome of resin you wouldn't have to worry?
Marshmallow is offline   Reply With Quote
Old 07-16-2013, 04:59 PM   #4
BrandXTC
Good point! - I didn't even think about the dirt aspect.
I thought about making it clip in, but then I saw a flash from the future of some kid in my neighborhood wearing an o-so-stylish M3 Necklace. lol
Marshmallows Idea is a good one, plus it would make it look glassy. As a side benefit, I could have it cut out of much less thick material. (We use the thicker stuff here all the time, so it was mostly just convenience. )
The other thought I had was to use the piece as a negative to emboss some thick foil, drop in resin.
I'm having the laser house save the drop from the inside as an option as well.
Third option - Buy some OEM and use this as a keychain. lol
Old 07-16-2013, 05:11 PM   #5
Moosecakes
My Ride: 02' SMG M3
maybeeeeee... if coated in resin... yes
Moosecakes is offline   Reply With Quote
Old 07-16-2013, 05:37 PM   #6
Swater330i
My Ride: 2003 BMW 330i 5MT
I really like the thickness of the original design, I suggest you keep it the same, but fill the holes and surround the badge with resin. That'd make it last forever and still look amazing.
Originally Posted by phenom323ci View Post
I am going to install M3 fender grill on my 323ci.
Originally Posted by futureSubie View Post
IMO, the euro clear corners looks too aftermarket/ricey.
Originally Posted by Davconelectric View Post
This 323 would most likely handle and drive better than a stock e46 m3.
Swater330i is offline   Reply With Quote
Old 07-16-2013, 05:39 PM   #7
cold m3
My Ride: E46 ///M3
Looks decent man! Improve on the ideas that have been said and keep us updated.
I may be interested as mine are faded after a few years. I would just super glue mine in~ Im just not understanding the space in the middle of the 3 should either be filled in or look more like this:
Photos of My ///M3
cold m3 is offline   Reply With Quote
Old 07-16-2013, 05:48 PM   #8
BrandXTC
The space was simply a design cue carry over. I wanted to add more slashes. I think I will design it both ways.
My GF said the space looked dumb too.... I told her to go drive her Pontiac. lol
I have a feeling the reason BMW made the 3 the way they did is because it was easy to get an endmill in there to make the embossing die.
Old 07-18-2013, 04:39 PM   #9
BrandXTC
Updated
Okay, so with the constructive criticism I've received, I updated the design a bit. I've decided if I go full bore, I'll have them cut both OEM and my design, though I will probably go for a 80/20 split on the material with OEM being primary.
Take a peek. In the render I've shown a resin fill. (keeps the dirt out; Marshmallow)
I think I prefer the brushed stainless front plate with a black backing, from every angle it's more visible, I like the look of the black front plate and brushed back, but it seems without the reflection it's harder to see from all angles.
Thoughts?
On second thought, If I can paint or color just the face of the front plate, it keeps the reflective inside and keeps it visible.
see?
-Me.
Old 07-18-2013, 05:03 PM   #10
cold m3
My Ride: E46 ///M3
really good job on the update. I pref the one with the sliver backing as i have black grills. and obviously as i said before i pref the oem style text at the bottom.
When your ready to make them i will take a pair!
Photos of My ///M3
Old 07-21-2013, 10:56 PM   #11
BrandXTC
Re: My take on a side grill badge (interested?)
So for fun and a fit check, I printed one on my 3D printer. I only have Barney purple, but it looks like it'll fit just fine.:o
Sent from my SAMSUNG-SGH-I717 using BimmerApp mobile app
Old 07-22-2013, 02:15 AM   #12
Moosecakes
My Ride: 02' SMG M3
Silver one and I'm in! Mine are due for a replacement anyway. and either variation works for me personally!
Old 07-22-2013, 03:07 PM   #13
Ramseyd
My Ride: Bmw e46 M3
Thoughts?
see?
-Me.
I'd take two of the black "M3" in a second if you would sell them
Ramseyd is offline   Reply With Quote
Old 07-22-2013, 05:44 PM   #14
NICKBRUM
My Ride: 2004 M3
The faded and yellowed badges can be made to look new by polishing with tooth paste. I may have spent ten minutes total...good as new.
Current:
2006 E46 M3 ZCP silver gray on black SMG
|Stoptech BBK ST40 X 355mm| Style 219 wheels|
|Ceramic coated euro headers| Custom 200 cell section 1|
|TTFS Motor & SMG tune, 315 whp| GC coil overs |
Previous: Totaled
|Carbon Fiber Intake|AA GEN3|AC Strut Brace|Eibach/Koni's|CSL/SMG Flash|
|Victory UDP's|HPF Sub Frame Plates| PF Subframe Bushings|Rtab Limiters|PFC DD Front Rotors|
NICKBRUM is offline   Reply With Quote
Old 07-22-2013, 08:24 PM   #15
Moosecakes
My Ride: 02' SMG M3
Tooth paste wont help melted badges. Which is OP's problem. Good tip though I may actually try this!
Old 07-22-2013, 09:29 PM   #16
danwilz
My Ride: E46 M3 Vert 2012 X5
Thoughts?
see?
-Me.
In for a set in silver.
danwilz is offline   Reply With Quote
Old 07-22-2013, 09:38 PM   #17
cityjohn
My Ride: 2001 M3
Lol sappy maple. But your product looks great! Might want to get a set myself
cityjohn is offline   Reply With Quote
Old 07-22-2013, 11:40 PM   #18
BrandXTC
Yeah, won't help the staph, but I can use this on my side markets.
Old 07-29-2013, 05:49 PM   #19
BrandXTC
Here it's a sample the laser cutter sent me. This one is aluminum. I brushed it and stuck it in place.
I'm leaving it like this. Lol
Old 07-29-2013, 06:27 PM   #20
Moosecakes
My Ride: 02' SMG M3
Yep, I want, price!!!!!
badge, grill badge, new product
