Buying a 03' 325xi - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
E46 Xi Forum
Old 07-17-2013, 09:09 AM   #1
Jat007
My Ride: 99' 323i
Buying a 03' 325xi
Hello,
I am thinking of buying this 03' 325xi with 150K miles on the car. The 325xi looks and drives good. This is an used car that is for sale at a small used car lot, so no 27 or 127 points inspection like the bigger stealers advertised.
Currently, I own a 92' 325i e36 and a 99' 323i e46 - so, I sort of know what to look for, but I never owned an xi model. So, I am opne for suggestions and recommendations on what I should look out for. I have always wanted an AWD model due to where I live.
Please help.
Thank you in advance.
Jay
Jat007 is offline   Reply With Quote
Old 07-17-2013, 09:17 AM   #2
SamDoe1
My Ride: 4cyl of fury
Read: http://www.bimmerfest.com/wiki/index...ook_out_for.3F
For Xi specific items it's front axle boot and CV joint failure.
You will need to take the car in for a PPI, make sure it's a good one or else you're going to be in for a lot of fun (read: hell).
Old 07-17-2013, 09:22 AM   #3
Jat007
My Ride: 99' 323i
Yeah, I know what you mean "a lot of fun"... I learned a lot from my recent purchased of the 323i... Thanks!
Old 07-17-2013, 12:05 PM   #4
dgknight
My Ride: 02 325xi 5sp 120k
Yeah, the front cvs are the only real xi specific concern and they are cheap anyway.
The front suspension parts and tie rods wear just like on the i models, but on xis you have to replace the whole control arms to replace the outer ball joints. If it wanders on hitting road grooves and/or under braking all of that stuff is probably needed so factor into the price.
Subframe failures are fortunately rare on xi's, but easy to check for anyway.
Aside from that same considerations as the non-xi. Definitely worth the PPI cost unless you can get it on a lift and know all the things to test.
dgknight is offline   Reply With Quote
Old 07-17-2013, 12:28 PM   #5
bikesandcars
My Ride: 2002 325xi-sport pkg
I recommend you drive it for a while and take it on some highway and moderate road cruising. Suspension (struts, sway bar bushings, control arm bushings, etc) and driveline (cv's, torque converter, axle shafts, etc) all manifest themselves as vibration and clunks.
The engine itself is bullet proof. If all the controls work, the transmission shifts OK and the car is clean there isn't much to say... you're always rolling the dice a little with a 150K auto xmission.
Also make sure they don't do to you what they did to me... they cleared the codes and after I bought the car and drove it 200-ish miles it started throwing cold start and thermostat codes. I figure it couldn't be random so I assume somewhere along the line the previous owner or car dealer cleared the codes. You can run an OBD2 check looking for resets, make sure the car has been driven enough and is OBD2 testable and not throwing any codes.
The biggest issue is vibration, if you get any vibration or clunking a PPI by a BMW mechanic makes a lot of sense. Also review any history or inspect for new parts to see what the maintenance looks like. A simple look under the car tells you about CV damage.
Also, use the AC and make sure that works and isn't "whistling" as that's another common issue.
bikesandcars is offline   Reply With Quote
Old 07-17-2013, 03:10 PM   #6
Jat007
My Ride: 99' 323i
Thank you very much guys!!
Old 07-18-2013, 11:37 AM   #7
Foxtrot_Uniform
My Ride: 325Xi
Personally... Unless you are getting a steal of a price... I'd buy from an enthusiast over a car lot.
Just sayin'...
Foxtrot_Uniform is offline   Reply With Quote
Old 07-18-2013, 11:43 AM   #8
GuiltySpark
My Ride: 02 325xi
Make sure the transfer case and bushing aren't on their way out. A new one is like 2k and from what I hear the bushing is a doable job but a pita.
GuiltySpark is offline   Reply With Quote
