///M3 Forum
Old 07-17-2013, 06:50 PM   #1
Bomber500
My Ride: 02 M3 Convertible
Enkei Tenjin 17"...
...is what I would like on the car. I know some don't like the look but I do considering there are very few 17" wheels I can find that I like and that don't cost too much.
However, the offset is 35 and it would be a square setup. After much research, I know they will fit in the rear and may even need a spacer for looks, but the rep at tirerack.com said he is unsure about the front fitting without hitting the fender.
Do you think that with a 25.8-26.0 inch diameter tire on this offset will be ok without any modifications to the fender?
My backup wheel is the TSW Thruxter.
Thanks, and I apologize if I missed the answer to this somewhere else in the forums. I really did check but I saw nothing that made it clear enough for me to pull the trigger on 900 bucks.
Cheers,
Dan
Bomber500 is offline   Reply With Quote
Old 07-17-2013, 07:49 PM   #2
helmutm3
My Ride: 04 m3
No freaking way you want these over oem m3 wheels. 17x8 or 17x9? Either way, Oem 18s are 18x9 with offset of 27 and people use them on the front with no modifications.
helmutm3 is offline   Reply With Quote
