Old 07-17-2013, 07:50 PM   #1
Twin_Turbo_S54
My Ride: M3
S54 9000 rpm valvetrain
S54 valvetrain malfunctions over 8250 rpm on boosted S54s.
Is there any interest for a 9000 rpm revving S54 valvetrain inc valves, retainers, springs ans cams?
What about billet main caps for S54, any interest?
La ilahe illallah = God is one and only
Twin_Turbo_S54 is offline   Reply With Quote
Old 07-17-2013, 10:40 PM   #2
6spd_legend
My Ride: acura legend 6spd
yes to the valvetrain.
2001 LSB M3 Coupe
6spd_legend is offline   Reply With Quote
Old 07-17-2013, 11:52 PM   #3
TerraPhantm
My Ride: M3 & ZHP
This is likely out of my budget so I guess it doesn't matter to me too much... but I think people would be appreciative of some kind of superior rod bearing before revving that high. Stock cars are failing around ~100k miles, I imagine 9k RPMs would accelerate that wear.
Old 07-18-2013, 04:21 AM   #4
Twin_Turbo_S54
My Ride: M3
I ve been revving 9200 rpm with a 97 mm stroke ( 3500 cc) for the last 2 years with zero issues, however I did not test 100.000 miles.
So a 91 mm (3200 cc) will rev easily. I do rev 9000 on my S50 B32 with a 91 mm stroke with zero issues as well.
Those WHO want to rev 9000-9200 rpm will not be after 200.000 mile engine life.
Even if you rev a stock stroke but boosted S54 past 8200 rpm, valve train suffers..
The extra power band between 8000-9000 rpm is for the ones WHO want to make more power out of S54. This kit will basically optimiz S54's output.
Old 07-18-2013, 02:02 PM   #5
BMW WHP
My Ride: 01 330Ci w/ stick
A little more detail on what you're proposing.
Supertech sells upgraded / high RPM valve train stuff, for both non-M and M.
BMW WHP is offline   Reply With Quote
Old 07-18-2013, 05:00 PM   #6
Tiago
My Ride: M3 e46
VAC also has a uprated valvetrain but don't know if its propose is for higher rpm...
ESS VT2-575 / AEM WMI / Supersprint Race System / 3.91 Diff / Stoptech ST60 and ST40 / Bilstein PSS9 / UUC Sways
CLICK HERE FOR PICS OF MY CAR
Tiago is offline   Reply With Quote
Old 07-18-2013, 05:21 PM   #7
Twin_Turbo_S54
My Ride: M3
all the details are as follows:
S54 valve shims leave their seats at over 8200 rpm on boosted S54s.
This problem has been solved on S50 B32 engines with the help of "shim under bucket" system.
A shim under bucket system is not possible on S54 due to the design of the oem system.
I was very willing to solve the shim issue and by 2008 worked on this problem.
In order to rev 8200 + rpm, I have custom made valves which are lighter and more durable for the combustion
chamber heat. Custom made retainers titanium, valve shims and a set of valve springs which allow you to rev till 9200 rpm.
Moreover, a set of custom made camshafts help to make more power through all rpms.
There is a common belief that aftermarket cams make a turbo engine perform worse due to increased overlap.
This is 100 % false.
I ve been testing at least 10 diferent cams in the last 5 years and custom cams spool earlier and make more power throughout the complete power band.
If we put back standard cams without changing anything else, the engine revs slower, builds less boost at earlier engine speeds.
I may put this as a complete set to sell, I wanted to see if the S54 platform wants to optimize boosted S54 engines.
- more boost and more air flow at all engine speeds, meaning more power everywhere.
- ability to rev 9000 rpm (supras rev 10.500 these days). This allows to use a shorter ring and pinion ratio. Or a higher trap speed at each gear...
- valves which can stand the stress / heat of turbo (or nitrous)
Old 07-19-2013, 06:17 PM   #8
Davconelectric
My Ride: 2 dog powered sled
^ good to hear about the cams, regarding overlap and boost.
Davconelectric is offline   Reply With Quote
Old 07-27-2013, 02:05 PM   #9
being3
Modded ///Member
being3's Avatar
My Ride: Turbo M3 7168 27PSI
I'd be interested in billet main caps. Also cams for power throughout rpm range to 8000 max... I would even be interested in cams that would flow only to 7500 for the sake of longevity. I'm not a high horsepower only goal. Mine r to have wide power band and torque with decent HP... With more street drivability and longevity focus
"Horsepower is how fast you hit the wall. Torque is how far you go through it."
being3 is offline   Reply With Quote
Old 07-29-2013, 10:18 PM   #10
Twin_Turbo_S54
My Ride: M3
whats your setup?
compression ratio / fuel / turbo ?
Old 07-29-2013, 10:20 PM   #11
being3
Modded ///Member
being3's Avatar
whats your setup?
9:1 comp forged, pauter rods, 6766 h cover , 94 octane, 50/50 water meth
Old 07-29-2013, 11:11 PM   #12
Commanderwiggin
My Ride: 1000rwhp Turbo M3
I believe the HPF engines have Carrillo Rods; Pauter will be in my next motor.
Old 07-29-2013, 11:27 PM   #13
being3
Modded ///Member
being3's Avatar
That's good to know... I wasn't sure i new HPF sold both. I would like the Pauter titanium rods..
Old 07-30-2013, 01:29 PM   #14
m3sc
My Ride: 06 TurboM3,06 SC C55
I would be interested in purchasing such an upgrade.
m3sc is offline   Reply With Quote
Old 07-30-2013, 02:17 PM   #15
being3
Modded ///Member
being3's Avatar
whats your setup?
So what would u need for a set of ur custom cam shafts ? Do u buildup and regrind the stock ones to ur spec? What would be involved for billet mains? What do u think r bottom end could handle with built mains torques wise? ( I believe torque is the weak point more than HP imop) ur thoughts ?
Old 07-30-2013, 05:26 PM   #16
Twin_Turbo_S54
My Ride: M3
what is your set-up?
the cams are built from ground, so they are not regrind.
camshafts to raise power till 9000 rpm.
valves ( + 1 mm oversize)
you need to port the heads......................to get the most out of it.
valve springs
retainers
main and rod bearings coated
Optional: DLC coated rocker arms
this is what I ve been running since 2008 and been happy with this valvetrain setup.
Building my E46 M3 coupe with the same combination and a 6766 turbo, will be a family commuter.
This valvetrain package allows to broaden the power band.
regarding torque & billet mains: well I think I am the only one WHO has been spraying 250 shot of nitrous on a 3500 cc S54 with 11,5 compression.
I think my S54s made the most torque at lower engine speeds and the billet mains held with no issues.
I ve been using VAC bearings w/o issues as well.
3500 cc
alcohol as the fuel
11,5 compression
custom cams
250 shot nitrous @ 3200 rpm
twin gtx3076
this combination made lots of torque
to be honest, your system does not need billet mains as the 3,2L / 67 mm turbo and low compression will be ok for the stock mains.
you may add L19 main studs.
If you will spray n20 or use alcohol as the main fuel, billet mains are a must. but not with your tq/hp as of now.
Old 07-30-2013, 11:39 PM   #17
being3
Modded ///Member
being3's Avatar
valve springs
retainers
3500 cc
alcohol as the fuel
11,5 compression
custom cams
twin gtx3076
Thanks as for the clarity... Excellent info
Old 04-22-2016, 05:26 PM   #18
jah
My Ride: M3 e36
Mert Dastan can tune an engine without a wideband o2 sensor. He can also rev a s50 until 12k rpm. He's the MAN.
jah is offline   Reply With Quote
Old 04-22-2016, 06:34 PM   #19
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
^ Good to know....
Rob43
SUMMIT POINT WV 1:24:229 SCCA
Old 04-27-2016, 07:26 PM   #20
helgo
My Ride: E46 M3
nice
2004 SMG M3 SG on black / IR.
Mods: 19" iForged Rev 275/285 / BBS CH / Mich Cups 265/19/30
SS Race headers / no cats /Dinan exhaust / SS mid / Brembo 15" with full GC suspension
UUC LTW flywheel / cerametallic clutch [ M5 clutch RIP... ]
**** BOOSTED by VF ****
helgo is offline   Reply With Quote
