Old 07-19-2013, 05:11 PM   #21
aldeghij
My Ride: 2003 330i
Originally Posted by lszlszx View Post
Do a fluid change without dropping the pan, that won't cost you much.
If that won't work - wait a few weeks - find a replacement TC and have it installed. That should be done for about a $1000
Also, visit a few trans shop, ask their opinion to verify it's the TC.
Yeah, maybe i'll do that. If nothing else it'll help me confirm the diagnosis. If it behaves any differently i'll know it's coming from there. I've called one of the more reputable trans shops here in town and he agreed it's probably the TC.
aldeghij is offline   Reply With Quote
Old 08-01-2013, 01:14 PM   #22
aldeghij
My Ride: 2003 330i
Ok, so here we are. Got the diagnosis of Torque Converter, and possible 5th gear issues with my ZF Auto. Quotes from $1950, alllll the way up to $6k to fix it. Found a replacement tranny from a member here on the forum for a good price. Had it put in yesterday, so total i'm into that for $1500. Hopped in the car, took it up to 70, problem is still there. I can still control it w/ the throttle. I know that my front wheel bearings are shot, but this is separate from that. So basically I just PM'd my 109k ZF w/ a 74k ZF. Replacing wheel bearings tonight. But still dunno what the deep moaning sound is. FML.
Fortunately, the transmission does feel more solid, and (knock on wood), I shouldn't have to worry about the reverse issue for a while (knock on wood again). Damn this car.
Old 08-01-2013, 04:23 PM   #23
WDE46
My Ride: '13 128i, '04 330Ci
I wouldn't describe my sound as rumble strip at 70 mph, but I definitely have a hum or slight whine at that speed that increases with engine torque output. I found something a while back about this and there was a BMW notice for it. Mine sounds like it comes from the diff or maybe the CSB. The BMW fix was to add some damping material on a mount somewhere.
I have a dream that one day our children will live in a
nation where they will not be judged by the color of
their skin but by the color of their coolant.
Old 08-01-2013, 07:52 PM   #24
aldeghij
My Ride: 2003 330i
Oh geez. So I've dropped 1500 on transmission + install, 200 on csb/flex disk and I coulda fixed it w/ 10 bucks worth of damping material???
LOL, at least I have a pretty fresh drivetrain now. If you come across that BMW notice, would you mind sending it to me? I'd be eternally grateful. Damn this car + 1.
Old 08-02-2013, 12:34 PM   #25
WDE46
I didn't say that would have fixed it. I was just throwing something out there. I don't even know if we have the same sound...
Old 08-02-2013, 12:47 PM   #26
2003silver330i
My Ride: 03 BMW 330i
Originally Posted by Phoenix330ci View Post
What causes a TC to go bad? Worn parts, low fluid.....
Also without a lift I don't see how you can get the tranny out from under the car. Jack stands or ramps I don't think will get the car high enough so as a DIY for the average DIY'er I don't think it is possible.
There is plenty of room to get the tranny in and out with just two (2 ton) jack stands. The hard part is getting the new transmission lined up on the engine block.
2003silver330i is offline   Reply With Quote
Old 08-06-2013, 12:02 PM   #27
aldeghij
My Ride: 2003 330i
Thanks for the input. I had an Indy shop swap out the transmission w/ the one I bought from a member on here. Problem still exists!!!! Three bad diagnosis from three shops! So now I have a spare zf I gotta sell to recoup some of my $$$.
Old 11-24-2014, 11:45 PM   #28
ksteele
My Ride: 330i
You mentioned that you have a spare ZF transmission...Do you still have it? I am looking for a ZF 5HP19 for a 2003 330i. Let me know if this is what you are selling?
ksteele is offline   Reply With Quote
Old 11-25-2014, 05:00 PM   #29
rsyed07
My Ride: E92 335is, E46 330i
I have one, only problem is it slips in 1st gear only under hard acceleration. I just changed the fluid, filter, and gasket today and the problem still persists. I'm thinking of going manual swap now. PM me if you want to buy it off me. It'll be about a month or so if that's alright.
rsyed07 is offline   Reply With Quote
Old 12-24-2014, 02:32 AM   #30
ksteele
My Ride: 330i
Just checking in again to see if you still have the ZF transmission you wanted to sell. Let me know what model number and what month/year your 330i was built. My car was built 01/03 and is compatible with any 330i built 02/03 or earlier with a ZF 5HP19 transmission.
Old 12-24-2014, 11:34 AM   #31
rsyed07
I'm actually keeping my transmission. It wasn't even slipping. I ended up having a misfire that made it feel like a trannys slip.
no reverse, torque converter, transmission, zf
