E46 Xi Forum
Old 07-18-2013, 01:27 PM   #1
Stugtz325xi
My Ride: 2003 325xi
Idle dropping Randomly, Anyone???
Hey all. I've got a question. New to the forum, and I've got a 2003 325xi, 123k miles on it..
Problem I'm having is that when the car is idling (Park, Drive, Reverse, dosen't matter) the RPM's drop suddenly about 200 RPM's for about a half second and jump back to normal range.
When its cold.. Does it about 10 - 15 times a min.. When its warmed up.. maybe 1-2 min.
I've read things aboyut Vanos Seals, and the ICV maybe dirty.
Anyone experience this or have any ideas??
Thanks for the help!! Its really annoying.
Stugtz325xi is offline   Reply With Quote
Old 07-18-2013, 01:53 PM   #2
dgknight
My Ride: 02 325xi 5sp 120k
Could DISA valve also cause this? You might try searching or posting in the main E46 forum as there is more traffic there and it will be the same for AWD or RWD cars.
dgknight is offline   Reply With Quote
Old 07-18-2013, 02:38 PM   #3
swordsman11868
My Ride: 2003 325i
Mine did this (but not quite down that low) until I replaced the intake cam position sensor.
The idle is back to normal now.
Search for CPS issues to see if your symptoms match.
-Dan
I'm just here to change the world.
BMW Wiki: http://www.bimmerfest.com/wiki/index.php
E46Fanatics inspiration Robolop: http://forum.e46fanatics.com/showthr...87566&page=101
2016 Beheadings in Saudi Arabia: 92.
swordsman11868 is offline   Reply With Quote
Old 07-18-2013, 03:40 PM   #4
Stugtz325xi
My Ride: 2003 325xi
-Dan
Did your car throw a CEL??
Old 07-18-2013, 03:52 PM   #5
Foxtrot_Uniform
My Ride: 325Xi
Check for codes...
I am not expert but I would think it could be;
Dirty ICV
Bad DISA
CPS
Fuel pump starting to go bad
Foxtrot_Uniform is offline   Reply With Quote
Old 07-18-2013, 04:17 PM   #6
Stugtz325xi
My Ride: 2003 325xi
No CEL or Code of any kind. Wish there was, I'd have a direction to look.
Old 07-18-2013, 05:28 PM   #7
e46alfonso
My Ride: 330xi MT, mustang gt
it could be many things, pre-cat sensors is another one even though there are no codes.
Remove the intake boots and look for cracks, clean ICV, replace disa seal, clean maf, clean electrical connectors. I would replace the cat sensors at this mileage.
Old 07-18-2013, 07:08 PM   #8
Kubica
My Ride: 2003 325xi
Most likely a minor issue:
Check intake boots
Shell 93 + a bottle of techron
Clean ICV
Inspect DISA and CCV
If none of that works go out and wail on the motor and see if that helps. My idle gets a little jumpy if I sit in a lot of traffic.
Old 07-18-2013, 07:54 PM   #9
swordsman11868
My Ride: 2003 325i
No code, ever. Just the common prob of no power until the revs got to 2800 rpm.
Would also happen after fairly long drives - 30+ mins. Actually stalled a few times probably due to heat soak of the sensor.
Hth
Dan
Old 07-18-2013, 07:58 PM   #10
CharlzO
My Ride: 2000 328ci
Mine has done that in the past. However, I can't remember any time it's done it in the last few weeks since changing my cam sensor. So it may be a coincidence, or that might have been my culprit. Mine would throw a code for it every so often though, so I at least had something to go with.
CharlzO is offline   Reply With Quote
