Old 07-18-2013, 11:36 PM   #1
bmw_328ci_e46
My Ride: 328 ci
Bmw e46 alarm beeps only unlock?
Bmw e46 alarm beeps only unlock? I installed the kit today and the siren goes off if you unlock it or hold the trunk button but if i lock it , it may beep one out of ten lock. All the settings in pa soft for the alarm except the rear motion sensor for the vert.
Any ideas?
bmw_328ci_e46 is offline   Reply With Quote
Old 07-19-2013, 12:18 AM   #2
white46
My Ride: e46 323ci
Re: Bmw e46 alarm beeps only unlock?
Open hood and slam close it and try again.
If it works properly after that, then it's the hood sensor need replacing.
white46 is offline   Reply With Quote
Old 07-19-2013, 08:24 AM   #3
Hector45
My Ride: 2002 OB 330i
+1
Mine was starting to go bad and would set the alarm off randomly. After unplugging the hood sensor the problem went away. I think a new sensor is only $16 bucks.
Hector45 is offline   Reply With Quote
Old 07-24-2013, 02:52 PM   #4
LeMansteve
My Ride: '04 330i 6mt ZSP ZPP
Right after I installed and activated my alarm system, it would go off randomly due to a faulty hood switch. It also would not beep every time I locked the car. I replaced the hood switch and that cured the alarm issue, but it still does not beep every time the car is locked. More like every 10-20 times. It does beep every time I unlock the car, though.
Old 07-24-2013, 09:25 PM   #5
tachi1247
My Ride: '04 330i
See the end of this thread http://forum.e46fanatics.com/showthread.php?p=15536661 for a solution that worked for me
tachi1247 is offline   Reply With Quote
Old 08-06-2013, 03:39 AM   #6
bmw_328ci_e46
My Ride: 328 ci
Same here anyone else have suggestions?
Old 08-27-2013, 12:34 AM   #7
bmw_328ci_e46
My Ride: 328 ci
Changed the hoodswitch
Beeps on lock most of the time but sometimes still does not . Anyone?
Old 08-27-2013, 10:25 AM   #8
willsbma
My Ride: 99 323i
I jumped out my hood switch and I still have issues with not always beeping/flashing on lock or unlock. I contributed it to data corruption during the coding, maybe my batt voltage had something to do with it?
Matte Black Kidney Grilles | Smoked Tails & Corners | Mtech II Bumper | Hotchkis Springs | ACS Roof Spoiler | M3 Spoiler | 20% Tint
WTB: Black sun visors & grab handles - PM ME!
I have P.A. Soft and a 20-pin adapter. Only used it a few times but pm me if you need anything coded!
willsbma is offline   Reply With Quote
