///M3 Forum
Old 07-19-2013, 08:25 PM   #1
Cayne23
My Ride: 2002 m3 convertible
Um so my brake pad wear indicator came on while I was driving. Pads have plenty of li
Cayne23 is offline   Reply With Quote
Old 07-19-2013, 08:25 PM   #2
Moosecakes
My Ride: 02' SMG M3
so check your sensors? They could be loose or old and weren't replaced at the last change..
Moosecakes is offline   Reply With Quote
Old 07-19-2013, 08:27 PM   #3
Cayne23
Re: Um so my brake pad wear indicator came on while I was driving. Pads have plenty o
Also my passenger side door wont unlock with key press or pushing button inside of car. Also my vert top only opens halfway until I give it a little push. Is it my battery?
Old 07-19-2013, 08:47 PM   #4
Moosecakes
My Ride: 02' SMG M3
Could be? have it tested.. your door issue sounds typical of a failing button. Happens a lot. If your key unlocks the pass door then it isn't your GM5, and sticky vert tops sounds like a common issue IIRC. I don't pay much attention to vert threads since I have a roof lol.
