///M3 Forum
Old 07-21-2013, 04:18 AM   #1
launch
My Ride: 2001 BMW E46 M3
Fuel not reading full
Hi all,
So I've had some issues recently - I've filled up the car and it won't show full. Needle sits between 1/1 and the right most dot.
I've pushed as much fuel into it as possible to the point that the fuel gun is tripping each time I pull the trigger so I'm guessing it's full.
I've run the diagnostics on the cluster (http://forums.bimmerforums.com/forum...t-Cluster-Test).
Test 6.0. When the car is > 1/4 full it shows 000123 (0L left sensor 12.3L right sensor).
Then I fill it up as much as I can and it shows 192330 (19.2L left sensor 33.0L right sensor).
My guess is the left sensor should show 24.0L at full?
Does this mean my left sensor is dying?
Test 6.2 shows *1 both sensors ok but this could be cause the left sensor is failing and not failed (still within spec)?
launch is offline   Reply With Quote
Old 07-21-2013, 12:04 PM   #2
m3e46freak
My Ride: m Twee lol
One of your leveling sensors could of failed or been corroded.
Rock Hard Abs Racing
ST Coil!
BREMBO
Apex!
Agency Power Headers!
Euro Cats!
Scorza Mufflers!
FRANK!! 311RWHP-260Torque
m3e46freak@yahoo.com for outside contacting
ebay/craigslist verified 100% FEEDBACK
m3forum 96% FEEDBACK
m3post/e46fanantics Great FEEDBACK
zpost/bimmerforum Great FEEDBACK
m3e46freak is offline   Reply With Quote
Old 07-22-2013, 09:49 AM   #3
launch
Thanks for the response. Is there any way to check without pulling it out and doing the multimeter thing? My gut feeling is the left hand one is going (low reading on full tank) but I'm not about to buy a new sensor on a whim...
Old 07-22-2013, 02:33 PM   #4
Grinchxvx
My Ride: 2001 M3, 1998 M3
It could be something to do with your fuel sending unit also. It's on the driver side underneath the back seat and is just like replacing your fuel pump but the part is around 140 I believe. I've heard of people running out of gas early because of it and it sounds like you might be having the same issue.
Grinchxvx is offline   Reply With Quote
Old 07-22-2013, 02:45 PM   #5
m3e46freak
My Ride: m Twee lol
Two points really, fuel sending unit, or connectors on either side. Its pretty simple to check but if you undo the seals I suggest getting new seals.
ST Coil!
BREMBO
Apex!
Euro Cats!
Scorza Mufflers!
Old 07-23-2013, 06:31 AM   #6
Smith1
My Ride: BMW
I've heard of people running out of gas early because of it the people have to face the sound issue
Smith1 is offline   Reply With Quote
Old 07-23-2013, 08:20 AM   #7
launch
Yeah thats what I'm talking about.
Your driver-side = my passenger side (Australia). i.e. LeftHand, LH.
Question is whether there is any way to be certain? Or whether anyone agrees with my reading of the on board diagnostic (which shows left sensor reading low at full tank)?
Old 07-23-2013, 08:22 AM   #8
launch
Connectors on either side: do you mean the wires that connect to the pump/sensor? I've seen pictures of them breaking away but I don't think thats the issue or the diagnostics would show implausible input and my guage would be far more messed up?
Old 07-23-2013, 10:29 AM   #9
braymond141
My Ride: 96 M3, 02 M3, 01 M5
This is most likely a dirty potentiometer on the fuel level sender. Worst case the contacts are worn off (unlikely). Pull sender out and clean the contacts with contact cleaner. If you're not seeing them turn bright silver again, use a pencil eraser (don't get the shavings in your tank), and then clean up with isopropyl alcohol. This can be done on both sides. DON'T bend the brush that sweeps the face, they are a pain to re-bend and get right.(this may not be a big issue with the bmw senders, last one I cleaned was a ford)
(pink arrow)
braymond141 is offline   Reply With Quote
Old 07-29-2013, 08:25 AM   #10
launch
Thanks guys, awesome as always. This really sounds like the issue. Next time I order parts from the states I'll get the rubber gaskets and give it a go.
Old 07-29-2013, 01:24 PM   #11
danwilz
My Ride: E46 M3 Vert 2012 X5
I fixed mine in my 330 with techron fuel treatment there was varnish from fuel built up on the sending rheostat.
danwilz is offline   Reply With Quote
Old 07-30-2013, 04:09 AM   #12
launch
Yeah I'll do this first. I haven't had much luck with the additives and engine cleaner stuff in the past but worth a shot.
Old 07-30-2013, 10:43 AM   #13
MemphisM3
My Ride: 02 PY M3
braymond141: answered
Der Teufel steckt im Detail.
MemphisM3 is offline   Reply With Quote
Old 09-04-2013, 10:36 PM   #14
ashleyk25
My Ride: 323ci
I replaced my fuel pump, and like a lot of people on here my fuel guage started ready wrong. so I replaced the fuel sending unit on the other side of the take. that didn't work. so I then reset my obc. still that didn't work. I need some help
ashleyk25 is offline   Reply With Quote
