Old 07-22-2013, 10:30 AM   #1
sannouni
My Ride: 2005 330XI
grinding sound at start-up with a twist
I've been getting the grinding noise after a cold startup for about a year now... it happens most of the time when the car is cold, and the noise sounds like the starter gear either stays meshed with the flywheel, or that when it retracts back to the starter, it rubs against something
After reading on this forum, it seems really simple, grinding at startup can be narrowed down to a starter... but why is it some times when I put the ignition to position 2, I hear the same grinding noise... it's
there any other motor that starts up when the ignition is at position 2 ?
sannouni is offline   Reply With Quote
Old 07-22-2013, 11:30 AM   #2
jdstrickland
My Ride: '94 325iC & '00 323i
Step 1
Go outside to the car
Step 2
Open the hood
Step 3
Have a helper operate the key
Step 4
Look inside the engine compartment and identify stuff that makes noise
Step 5
Come back and describe the noise and the origins of it better than you have described it so far.
Old 07-22-2013, 11:51 AM   #3
willsbma
My Ride: 99 323i
Sap runs at cold start. Probably just going bad.
Matte Black Kidney Grilles | Smoked Tails & Corners | Mtech II Bumper | Hotchkis Springs | ACS Roof Spoiler | M3 Spoiler | 20% Tint
WTB: Black sun visors & grab handles - PM ME!
I have P.A. Soft and a 20-pin adapter. Only used it a few times but pm me if you need anything coded!
willsbma is offline   Reply With Quote
Old 07-22-2013, 12:01 PM   #4
Zell
Zell's Avatar
My Ride: so turbo wow
Does it kind of go "chirp chirp chirp" a few times and then go away when it's cold? Mine used to do that a lot when it was cold when I bought it, but it has since much diminished. I found that leaving the key turned for an extra half-second after starting seemed to help. Maybe doing that enough times unstuck whatever was stuck in it.
Old 07-22-2013, 12:51 PM   #5
My Ride: Lexus
My brand new 2006 325ci 5-speed manual did this brand new from the factory. Dealer could not replicate. Did it randomly on cold starts. starter sticking. i think the later models just got crappy starters.
seems the late 01s/02s have the highest quality of parts/lowest reports of failures? jfoj says this too.
Old 07-22-2013, 12:56 PM   #6
Zell
Zell's Avatar
Seems to be that way. Either way, when I get my clutch done, I'll have them replace the starter since there's no better access to it.
Old 07-24-2013, 09:45 PM   #7
sannouni
My Ride: 2005 330XI
thanks for the feedback, i ordered a new Bosch starter from ECS, i'll be replacing it along when i change the clutch late August...
General question, can the solenoid fail in such a way that it would spark or allow the starter motor to start turning (hence the noise i heard) prior to even starting the car ?? in any case, i'll be recording the noise
Is there a DIY for replacing starter while changing the clutch, i'm planning to rent a hoist for a day or two and do the work myself... I searched but havent found DIY for the starter while the transmission is out (how do you get access to the electric wires in the back of the starter ?? i have an XI by the way, which makes it almost impossible to gain access from the bottom) any help would be great... i dont want to get stuck...
Old 07-24-2013, 11:29 PM   #8
lszlszx
My Ride: 1.8T, XC70
The solenoid does not receive power until the key is in the start position.
The wires on the starter are within reach once the intake boots are removed.
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 07-28-2013, 12:36 AM   #9
sannouni
My Ride: 2005 330XI
Here is a short video of the noise... i'm going to record the noise upon start-up as well (which to me sounds like a starter grind)
Any input would be appreciated
