Old 07-22-2013, 05:26 PM   #1
Weste46
My Ride: 2001 330ci
Where to buy a PS pump?
Hello, my original power steering pump has a whopping 175k on it, and has been whining for the last year... replacing the fluid did not help (I used the correct fluids), and would now like to upgrade to an LF-30 before this pump bites the bullet.
Where could I buy a remanufactured LF-30 pump for relatively cheap? I can't find any really great deals.
Thanks for any help!
Corbeau FX1 Pro & CR1, Ultimo front coils, Rob43 9-click rear shocks, Swift 10k rear springs, Meyle FCA's, AKG 95a FCA, 75d rear subframe, Powerflex 95a RTA, 95a RCA, ECS 88a diff., ECS SS brake lines, LTW FW, M3 engine mounts, UUC 5sp black mounts, BMW Performance SSK, open-loop EU2 tune, CAI, headers, x-pipe, minus ~180lbs.
Weste46 is offline   Reply With Quote
Old 07-22-2013, 05:30 PM   #2
My Ride: Lexus
you sure your reservoir isn't clogged straining/restricting flow?
Old 07-22-2013, 05:36 PM   #3
2003silver330i
My Ride: 03 BMW 330i
BMAparts and Amazon have some good choices depending on if your looking for just the pump or the pump with bracket.
2003silver330i is offline   Reply With Quote
Old 07-22-2013, 05:36 PM   #4
Weste46
My Ride: 2001 330ci
Re: Where to buy a PS pump?
Honestly, I hadn't even thought of that.. how could I check though?
Old 07-22-2013, 05:40 PM   #5
My Ride: Lexus
Replace the reservoir. It's $17.
Old 07-22-2013, 05:42 PM   #6
Weste46
My Ride: 2001 330ci
Well then, I think I may just do both... honestly, my whole system should be updated in my mind.
Old 07-22-2013, 05:43 PM   #7
Weste46
My Ride: 2001 330ci
I looked on Amazon but I thought I was seeing non-OEM brands. I'll look at BMAparts!
Old 07-22-2013, 05:49 PM   #8
My Ride: Lexus
There's really no such thing as a non-oem brand that i know of or have ever seen. they are simply reman pumps that aftermarket companies refurbish and put their sticker on.
The reservoir has a filter on it that is non-replaceable.
Here is a complete mango list you won't see anywhere else on the net typed out in such a complete manner:
Power steering lines
32416851217 x 1 Power steering reservoir ZF $17
32416764725 x 1 Power steering feed line MTC $44.09 CODAN $91.76
32416750155 x 1 Pressure hose CRP $23.61
32416796390 x 1 Pressure hose w/ crimp COHLINE $33.01
32416796367 x 1 pressure hose Cohline $55.86
Gasket rings for power steering job
32411093597 x 4
64508390601 x 2
32411093596 x 2
It will cost you $250 for everything (not including fluid and universal clamps of various sizes from your local parts store)
Old 07-22-2013, 05:49 PM   #9
2003silver330i
There are two styles and not sure which one you have.
http://www.amazon.com/LuK-W0133-1662...+steering+pump
http://www.amazon.com/LuK-W0133-1662...sim_sbs_auto_4
Old 07-22-2013, 06:00 PM   #10
Weste46
My Ride: 2001 330ci
32411093597 x 4
64508390601 x 2
32411093596 x 2
Well, this is great! Thank you! Are the brackets different between LF-20 and LF-30? I plan on swapping my LF-20 to an LF-30.
Old 07-22-2013, 06:01 PM   #11
Weste46
My Ride: 2001 330ci
Very nice, great prices for new!
Old 07-22-2013, 06:04 PM   #12
My Ride: Lexus
No problem. I'd recommend going with the more expensive of the two brands if given an option for a particular hose. Don't cheap out cause it's a messy job.
Honestly i don't know about the brackets. I don't see why they'd be different.
Old 07-22-2013, 06:06 PM   #13
Weste46
My Ride: 2001 330ci
On eBay, there are a ton of cheap aftermarket ones for sale, around or less than $100, as "new". I wouldn't trust aftermarket, but I'm trying to find my bottom dollar remanufactured pump, to compare to the Amazon deals... still haven't found a good remanufactured pump seller. I'll probably bmaparts tomorrow to see if they have reman.
Old 07-22-2013, 06:21 PM   #14
Sweetness
My Ride: '01 325i
Most hoses come with clamps now, such as my Rein one. Check before hitting Autozone up. And also, check out Atlantic Enterprises for rebuilt (basically new) power steering pumps. I bought my Luk-20 there and they call it the "HD" version because it's beefed up with a wider internal vane for flow.
2001 325i ZCW, ZPP
Titansilber Metallic, Black Interior
The 160,000 mile, clean daily driver
Sweetness is offline   Reply With Quote
Old 07-24-2013, 02:50 AM   #15
Weste46
My Ride: 2001 330ci
Sounds fantastic. What was the price of your pump?
Old 07-24-2013, 07:26 PM   #16
Sweetness
My Ride: '01 325i
I bought the one with brackets, so $210. If you use existing brackets, it was $180 I believe.
2001 325i ZCW, ZPP
Old 07-24-2013, 08:06 PM   #17
NOVAbimmer
My Ride: E60M
I got my pump from advanced auto (Duralast brand). It was about a third the cost of most of the rest of them. It came with a lifetime warranty. I didn't have any problems with it.
NOVAbimmer is offline   Reply With Quote
Old 07-25-2013, 06:29 AM   #18
caryalon
My Ride: 2001 325i
If you switch from an LF-20 to an LF-30, you need to change to the appropriate high pressure hose. All the other hoses and reservoir are common to either pump.
caryalon is offline   Reply With Quote
